Here is an easy solution to your problem. Start with 3 layers of Graphite/epoxy mixed with Milled Glass Fibers from the Store at $5.95 a pound. It is called liquid fiberglass. Make as a thick mix as you can to apply it. Put on 3 layers. Then for cosmetics if you don't like that put on a Graphite/epoxy at a 30% graphite to epoxy mix. Most people use to thin a graphite mix. Use two coats. I don't know what you used but my friend in Savanah never had that kind of problems on his oyster bars and he loved his oysters.
Well good luck which ever way you go. Oysters are nasty on the bottom of a boat.
Texas Flats Boat
Re: Texas Flats Boat
Tom, how think is the bottom on CL's boats? I think I'm maybe 1/16" thick (three coats) on the v12, and sailing into a bed at 2kn puts a BIG gouge in it. The cement ramps are just as bad (I have lots of glass under it so not too worried.
I'm wondering if CL's idea of think is much thicker than my idea of think.
Yea CL always over did every thing so my big problem is the concrete boat ramp and I can get a 1/16" gouge in it and still have graphite. As I recall he put about 5 coats on, maybe 6 because of the oyster bars. And he mixed it with as much graphite as possible, up to about 30% maybe only 25%. I tell you that heavy boat on concrete does not stand a chance, I always have some scrapes.Jaysen wrote: ↑Thu Sep 17, 2020 3:36 pm Tom, how think is the bottom on CL's boats? I think I'm maybe 1/16" thick (three coats) on the v12, and sailing into a bed at 2kn puts a BIG gouge in it. The cement ramps are just as bad (I have lots of glass under it so not too worried.
- Explorer 19TV
I wouldn't sweat it, I too have a tendency to overthink it... put 5-6 coats on it and build on. The thing about graphite is it super easy to repair.
On another note how's that sanding coming.
I like that plan. Think that's exactly what I'll do. Regarding sanding - my fatherinlaw who helped with the fiber glassing asked me to save him an area to practice on, so he's going to do the sides this weekend (really had to twist my arm on that one!). This past weekend I tried to sharpen the rear edges using milled fiberglass and silica or microballoons (don't recall which - it was left over from the last build). It worked great when I did it the time before. I used a sheetrock corner tool that I slightly modified (will send photo next time I think to take one) and applied the material straight to the edges without a form. It held up just like cake icing. Can't take credit for the idea - pretty sure Reid made the recommendation.
Well this time around I didn't thicken it enough and the corners wouldn't hold their shape. Ended up abandoning that attempt and had to sand it off the next day! That was about 4 hours lost. But I'm a slow learner and will try it again today or tomorrow
- BB Sig
That stinks. I've wasted a lot of 4 hours!
Try to get a video of this process. I don't need it but I like to learn!
Something else that might have contributed to the failure is the cooler weather we've been having. I'm using slow hardener and am used to working in 90-95 degree weather. These days in the 70s-80s likely caused the epoxy to not set up like it has in the past. So with that in mind, I might hold off on the second attempt for now!
wwsmith, did you do OK with the storm?? Looks like a major flood event for Houston and Galveston!! Jeff
BB, here's a photo of the tool I mentioned. Going to wait until the weather warms up next week to try it again.
Jeff, thanks for checking in. Other than cancelling a fishing trip, we were pretty unaffected. Far enough inland where we only got light showers. It's unusually green around here for this time of year. Had several late summer rain events to keep things looking good. Feel sorry for the upper coastal areas. Looks pretty soggy.
Users browsing this forum: Bing [Bot] and 10 guests
