Nola OD18
Re: Nola OD18
That's what I was thinking
Check out my build----C17---- hit the link https://forums.bateau2.com/viewtopic.php?f=2&t=63575 ,OD18 build link Nola OD18 - Boat Builder Central - Builder Forums
viewtopic.php?t=65341
Re: Nola OD18
Primer will show up any places that aren't fully smooth, you may want to skip that step on the bottom!
Re: Nola OD18
Black graphite will show those spots x100 ... it's all in how you want it finished I guess.
I consider high build primer part of the fairing process. If you're not looking for perfection, then move on. If you don't want that black bottom to show every dip & skip that's left, then you may want to primer, guide coat, & sand some more.
Re: Nola OD18
I suggest you do a couple coats of primer to sort of protect the bottom if you scrape through the graphite and I have. I can see where I have scraped through. Dang rough concrete docks up here.
Re: Nola OD18
It may be the fact that I abhor painting, stink at it, that the primers suggested for use below the waterline are expensive and finicky, but I cant see how paint is going to protect the hull from scratching when an epoxy/graphite mix failed to do so. I also feel like epoxy/graphite will adhere better to the epoxy/compound on the bottom than it will to primer. In my mind, each layer added is an additional point of adhesion failure.
I still vote no primer.
Ymmv.
Re: Nola OD18
So I went ahead and did the graphite then did the primer came out fine .She is now ready to be flipped
Re: Nola OD18
Nice work Salty!!! Jeff
Re: Nola OD18
Milestone time!
Re: Nola OD18
Nice work Salty! Looks great!
Re: Nola OD18
Trailered
Users browsing this forum: Ahrefs [Bot], WMF Stefan and 8 guests
