Page 1 of 49
Panga 20 West Central Florida
Posted: Wed Mar 09, 2005 11:25 am
by JASmine
The offical clock has started!!
Ordered the epoxy and precut kits on 3/4/05. Epoxy arrived 3/7!!!!
Built model to find out where the "difficult" areas of the hull might be...it's the BOW!! There are a couple of pics in my album of the model. I learned alot from building it...and I really like the shape..just the right combination of sharp entry and flat stern for my fishing needs..in Tampa Bay and the surrounding intercoastal areas.
Posted: Thu Mar 17, 2005 2:56 pm
by JASmine
Moved supplies and tools to a vacant garage a few miles from home over the last few days.
Completed the strongback this morning...
Just got the call from the freight company..they will deliver the precut kit tomorrow!
It's going to be a busy weekend..
I've also been watching Dynamo's progress and hopefully learning how to make the big camber bends..
Stay tuned..
Posted: Thu Mar 17, 2005 3:35 pm
I may go to Tarpon Springs on April 16th. If I go that way, I would love to stop by and see the assembly.
I should know more about that trip to the West Coast within 2 weeks.
Posted: Thu Mar 17, 2005 4:45 pm
by JASmine
WOW!!!!!...a possible visit from the head guy!!!
Seriously, Jacques, that would be fantastic if it fit's your schedule. Email me when you know...or call if it's more convienient.
John
Boy will this provide motivation
Posted: Thu Mar 17, 2005 5:36 pm
by smilinmatt
Jacques,
You're welcome to stop by my place and help me finish glassing in my stringers.
Posted: Fri Mar 18, 2005 7:38 pm
by JASmine
Precut kit arrived this afternoon. In 2 1/2 hrs all the parts were cut free and laid out in the driveway..it looks good! Epoxied two layers of the transom so far..later tonight will add the third layer. Tomorrow I'll start assembling the frames on the strongback.
Posted: Sat Mar 19, 2005 7:53 pm
by JASmine
Started around 9:00 this morning and worked until 6:30 (less 1 hr for some lunch and a trip to Home Depot). Learned alot thru mistakes but eventually I got the hang of setting up the verticals and aligning the frames on the strongback. Got the transom,F,E, and D set, aligned, and braced. Spliced the stringers for an overnight setup.
Found one small cutting error but nothing serious.
Will try and place A, B, and C tomorrow along with gluing the 2 stringer sides together.
Next big item is figuring out how set the small end pieces of the center frames (see my gallery for some pics).
Posted: Sun Mar 20, 2005 8:46 pm
by JASmine
Was able to get in a few hours today. Got all the stations mounted and aligned. Everything went together easily after yesterday's learning experience (mistakes!!). Glued one stringer set together for an overnight cure. I may be able to get the outside arms of frames C, D, and E set up tomorrow.
Posted: Sun Mar 20, 2005 8:47 pm
by JASmine
Sorry for the duplicate entry
Posted: Mon Mar 21, 2005 6:02 pm
by JASmine
Worked for a few hours this afternoon. Cut the starboard notch in station F and lined up the stringer. Placed the starboard-side outside frame pieces (will mount them solidly tomorrow). Glued the Port-side stringer pieces for an overnite cure.
