Vagabond 23 building in Kansas
Posted: Mon May 15, 2006 1:47 am
I started my Vagabond 23 about March 1st.
It is of course taking longer than expected, but isn't that to be expected?
This picture is a couple of weeks old, but at least I have some evidence that I'm building:
The bulkheads are dry fit in this picture. I have some modifications, but no bulkhead have been moved or reduced. You can see the bridgedeck, also bulkhead E is cut high for additional counterspace on the starboard side, (now the boat only sleeps 3).
Right now I'm glassing the inside, next I'll tab in the stringers & bulkheads.
Does anyone have thoughts about puting an FB11 dink on the foredeck of a V23? Consider:
1) The dink nests to L 5'5" x B 4'2" x H 1'6" and mine weighs maybe 80lb?
2) The V23 will cruise around 3,800lb, has 3'0" of freeboard and a flush deck, distance between mast & stem is 9' and I intend to use a high-cut jib. With the dink on there, the deck space will be only around 6" on each side at the bottleneck.
3) I know it fits, but because of weight, windage, visiblity, working space on the foredeck... I'm not sure if it is smart for both coastal & offshore cruising.
What do you guys think? I'm die hard about a hard dinghy.
