SB18 in the Philippines
- chicagoross
- chicagoross
Good start, pretty soon it'll be looking like a boat! Where are you planning to use this one? Ocean? Where do you launch? I'm hoping to get back to our house in Imus this summer, where I have a 40 hp Merc with only about 25 hours on it waiting for my next build...haven't figured out what design yet, though...or financing...
Hi Ross. The boat will be based in Taal most of the time, our CR13 lives there. On occasion we'll take her out to sea. I expect she'll cross to Puerto Galera and hopefully will be capable of island hopping to Boracay and even Palawan. We'll see.
Financing? Granted the materials here aren't the best, it is surely hard to beat the prices. Drop us a line when you do get here.
And she goes 3D .... ha ha I did not take a picture of her full body .. this will have to do:
Stitching the bow .. taking my sweet time here.
How I got the frames level
How I got the angled cabin bulkhead into position:
Thanks Greg for pointing me in the right direction.
Discovered another mistake in my frames
Aside from this "big" error, I'm seeing a lot of small errors - gaps between the frames and the hull panels. I'm going to trust the hull panels and later get the frames to fit.
It was the frame Ross. I spent the morning stitching and doing as you mentioned: pushing and pulling but I still have a big issue with Frame F. It is just not fitting itself to the hull at the first and second chines. I've remeasured the frame and I've not found any error. I also checked the frame spacing and those dimensions checked out too. I'll check the panels next. I suspect I may have done the bow wrong. Good thing tomorrow is Sunday.
- Evan_Gatehouse
I spent most of Sunday realigning all the frames. Everything is A-OK now. I still have small gaps, 10mm or less at Frame F but they're symmetrical, and the hull is fair as far as I can tell.
One thing was I measured the position of Frame F from the wrong side so it was 9mm too close to Frame E. Also, Frame F wasn't standing up straight because the struts holding it upright were rather small being must 1x2 and would bend towards Frame E. After adding those two horizontal braces that are level with the bottom edge of the boat's cabin sole beams, the gaps at the 2nd chine reduced to about 10mm.
By the late afternoon, I had masking tape on all the seams and started filleting. Got a third done.
Yeah I wasn't gentle enough and broke the tip of the lower side panel. To fix it, after the tack welds are hard enough, I'll chop off about 30mm from the lower side panels and the bottom panel and glue piece of wood there which I will eventually shape into the tip of the bow.
