CV 16 Caravelle - Wyvern
Posted: Fri Sep 10, 2004 10:37 am
by chrisobee
Please meet my new boat. She will be called Wyvern after a mythological winged dragon commonly found in coat of arms. I feel that she can now be called a boat as she can no longer be stacked against the wall.
I have in my possession the mast kit, sail kit and all the cordage and most of the hardware required to complete the boat. Fear, doubt, injury and bad luck have cost me more than a year. I have finally convinced myself to just go the garage and get started. I find it astounding how much mental discipline was required to start this project. I have never been so uncertain about anything before in my life.
This week I starting to making significant progress. A few weeks ago I got the panels all cut out and butt blocked. Then I suffered a long delay because I was concerned that the panels would not fit together well. This week I finished cutting out the frames. I am now putting the pieces all together. I am looking forward to getting the hull stitched, turned and the fillets started this weekend.
Don't let the messy garage background fool you.... I have pasted in messy garage background so as not to intimidate anyone.
Posted: Fri Sep 10, 2004 12:39 pm
by Jonnas
How did you get a photo of my own messy garage to use as a background
Well done Chris! It's looking good and I'm sure you'll be building a beautifull sailboat.
I'm bit jealous. I should have started mine already, but unfortunately life sometimes isn't exactly as we would like it to be ...
Please keep on posting pictures.
Best regards.
JG
Posted: Thu Jan 27, 2005 3:04 pm
by ks8
Time to update the post. I know no one builds slower than me!
ks
Posted: Thu Jan 27, 2005 6:01 pm
by chrisobee
ks8 wrote:Time to update the post. I know no one builds slower than me!
ks
Touche' I admit to complete inaction. I am currently putting work into my Home to keep the little woman sane and loving me. Quite the battle actually, every job I take on in the house keeps the boat in the garage just that much longer...... sigh.....
Posted: Fri Jan 28, 2005 1:11 pm
by ks8
See if she will help with the boat when the kitchen is finished! Hopefully yes? She can vacuum up the dust while you're making it!
But I wouldn't give her a respirator for valentine's day!
ks
Posted: Fri Jan 28, 2005 2:32 pm
by chrisobee
ks8 wrote:See if she will help with the boat when the kitchen is finished! Hopefully yes? She can vacuum up the dust while you're making it!
ks
How about epoxy..... would that be OK?
That reminds me of one of my coworkers who told me once that she would still be married today except that her husband at the time bought her a vacume cleaner as a birthday gift.
Posted: Fri Jan 28, 2005 3:33 pm
by ks8
That reminds me of one of my coworkers who told me once that she would still be married today except that her husband at the time bought her a vacume cleaner as a birthday gift. Back to top
I don't think epoxy is a good idea, unless you tell her the boat is hers when you are finished building it...
does she enjoy boating, or would she turn it into a planter, or a jacuzzi???
ks
Re: CV 16 Caravelle - Wyvern
Posted: Mon Sep 05, 2005 2:54 am
by Leon_Steyns
Chris,
Congratulations on your progress so far! It looks very good to me. As for your comments I quoted here, I can relate to you completely...
I had exactly the same feelings and will probably get some more, but once you're out on the water it will all get blown away!!! I spent the better part of four (yes, that's "4"!) years to build my Caravelle in my back yard. At some point I seriously considered terminating my project, reversing to a Stich&Glue bookshelf (glad I didn't)...
I like the name "Wyvern" and the story behind it. And don't worry about the clean garage workshop: too clean a workplace means no work is being done!
Posted: Wed Sep 07, 2005 10:30 am
by ks8
AH, the small victories lead to the final one. I'm glad I finally put some primer on the CB case. Maybe by this weekend it will be painted and in the boat???
Four years... sounds familiar.
Bright finishing slows things down very much and at least doubles the masking required. Getting closer...
Are you going to play catch up ChrisObee, or like everyone else, is your's already floating?
Sincerely,
ks
Posted: Wed Sep 07, 2005 1:01 pm
by chrisobee
ks8 wrote:AH, the small victories lead to the final one. I'm glad I finally put some primer on the CB case. Maybe by this weekend it will be painted and in the boat???
Sincerely,
ks
No not floating.
I have a long way to go. I do however feel a burst of determination coming on. My problems are self doubt and time availability. I just have to suck it up and start moving.
Concerning the center board I am nearly convinced that I will go for the simpler dagger board rather than the center board.
Posted: Wed Sep 07, 2005 3:53 pm
by ks8
It should be a MUCH quicker build with the dagger board, but I think you definitely want to bring those mid frames up to reinforce it, as on the plans detail.
Here's the CB case being test fit...
http://gallery.bateau2.com/displayimage ... =244&pos=1
http://gallery.bateau2.com/displayimage ... =244&pos=2
http://gallery.bateau2.com/displayimage ... =244&pos=3
That large hole in the battery box area is for the wires to the Battery. Did the hole have to be that large? No. But I also use the large hole to stick my hand in there and inspect or tighten a clamp on the midframe under the seat. The clamp holds clear tubing which serves as electrical conduit (I can tell quickly if water found its way into the system). An access plate is bolted over the hole with a small 5200 sealed passage for the wires.
Since you are not doing any of this sort of thing, be encouraged! Your boat should go together much quicker, much much quicker, especially if you do a quick seal under the seats and use the foam. I spent a lot of time glassing under there and sealing it very well (yikes) so I can inspect and wash it well. The foam makes all that unnecessary. If you want yours done, forget the brightwork, unless you 5200 on some simple trim of thin stock. There are many such things I would do differently, but this one must be finished as is first. I would bolt on more extras rather than laminating them on. All those curves and joints take time to finsih! Keep your boat basically stock and it will go together fast. If you want to be a mad modifier like me, you can always do that after having gone for a sail, and fishing. If you like my mods, we'll chat about how you can do the same more easily, after you've painted it and splashed it.
Have fun finding time. It surely finds us.
ks
Posted: Wed Sep 07, 2005 4:21 pm
by Leon_Steyns
KS,
I'm going to say it again: you're not building a boat. It's a sculpture, a piece of contemporary art pretending to be a boat! Just look at that glossy finish! Which, by the way, you keep referring to as "primer"
Don't pay any attention to my comments: I'm just jealous...
Posted: Wed Sep 07, 2005 8:57 pm
by ks8
I'm going to hand the thread back to ChrisObee. I'll add to my thread later. Leon... but it is primer...
ks
