I had the same thing happen with my V-12. No problems bending the panels. I would say don't worry about it until it becomes a problem.
Cheers
Baba’s FL14: MadMax in Toronto
I am thinking if one side of the panel is stiffer than the other...that might cause the boat to be lopsided... should I double the mistake and to the same Sh*t to the other side...Gubbs wrote:I had the same thing happen with my V-12. No problems bending the panels. I would say don't worry about it until it becomes a problem.
Cheers
I.e a super thin coat of Epoxy on one half of the other panel...
You could epoxy the other side but I don't think that it will make a big difference. If you do the panels differently just look and see that the shape that is produced on both sides is fair amd similar. If not take it apart and epoxy and reassemble. I think you will find however that the difference is slight.
With the relatively thin 1/4" ply, and the number of frames on the FL14, I doubt you will have a problem. Look for smooth curves and a fair hull. The small boats such as the FL series are very forgiving of errors. It is not a planing hull, so shape will be somewhat less important than on a bigger one that planes. I would not worry about it. Rick
I cut all my pieces using a circular saw with a min 100 tooth blade. Set the blade depth just enough to go through the wood, you can cut most of the curves with the circular saw. For really tight curves I would use the jigsaw.This ply splintered quite badly when cutting across the grains..changing to different types of Jig Saw blades did not help.
Remember, peanut butter for fillets and molasses for glue.Long panels are now bonded...kept thinking about peanut butter consistency...looked more like melted Toffee when I applied it...I don't know if it was too much or too little...
-- Benjamin Franklin
"Molasses"...emmm so its more dilute than Peanut butter...Is that somewhere in the tutorials...?ArizonaBuilder wrote:Remember, peanut butter for fillets and molasses for glue.
I put a thin layer on each side...enough to make the grains disapear...and the consistancy was like peanut butter...Will I get a strong bond...?
HALALOOYA.... I am on a ROLL guys...Gubbs wrote:Pre-coat ply with unthickened epoxy. then thin layer of peanut butter or molasses. press together. wait. won't be able to pull apart.
Cheers
Users browsing this forum: Ahrefs [Bot] and 10 guests
