FL12 - NW Trout - ***SPLASHED***
Re: FL12 - NW Trout
Thats some nice clean work there. Boat is looking great. You'll be proud to go out in her, I know I would
Completed: FL14, OD18
Re: FL12 - NW Trout
Really looking good!
- gstanfield
Re: FL12 - NW Trout
Looks great. I build the FL14 with the intent to use it as a small lake boat and drift boat on the north Platte river. When you build the drift boat, be sure to show us some pics of it, I'm sure it will turn out very nice as well.
George
George
Current build: FL14 (+10%)
Re: FL12 - NW Trout
Good choice.to give the hull coat a full week of cure time before flipping.
Re: FL12 - NW Trout
Latest updates.
Waited 8 days before flipping the hull. Went easy since its light and the neighbor's college boy is healthy!
Working up / drawing out ideas for breasthook. Its' a 1/4 ply glued to a 3/8 ply. Same for the knees
Breasthook cut out.
Glue and clamping wood corner molding. It works as the wire conduit between the transom and mid-seat.
Taking advantage of a rare 70+ degree day to speed the cure of wire conduit gluing and overall coat of epoxy on remaining interior raw wood.
Matthew priming the bow compartment prior to gluing seat top.
Bow seat primed and ready for gluing.
Completed conduit. Turned out well IMHO.
First pass on quikfair and sanding. Unfaired spots in foot wells will be done with no-slip texture to help hide my cheapness. Did one more, sanded and currently has two coats of primer on. Now I can see my misses and pinholes. Will hit that with more QF and primer again later.
And I think we've finally settled on a name. Play on old family name from Mom's side of the tree. And Matthew would have been called Ketch if I was closer on my guess for his birth weight.
Hope to get last bit of primer on today and then spend Father's Day starting roll-n-tip.
Breasthook cut out.
-John
aka NW Trout
Seattle, WA
aka NW Trout
Seattle, WA
Re: FL12 - NW Trout
Man you are working quickly now! Looking sharp...looking sharp. Love the conduits.
- gstanfield
Re: FL12 - NW Trout
Looking good, nice application of child labor
Re: FL12 - NW Trout
Well.. outside of a bit of touch up here and there... We're calling Ketch'Em done.
I'm pleased with how the boat turned out. I know all the flaws, drips, runs, etc of it and I'm okay with it. I'll likely do some touch up to fix one or two things but I've learned alot that hopefully will be put to use on the next boat project
Side shot with S3's Shaw Blue strip.
Bow detail (a bit of 3m 5200 sealant showing under the cleat).
Bow eye is a bit lower than I like. Sealed it well. May redo next winter.
Rear seat detail. Thru-hull is used to allow pass thru of MinnKota QuickConnect.
Mid seat showing other end of battery wires, battery tie down and another mistake. In recessing the hinges in the seat lid, the screws protrude thru the remain thickness of the plywood. I'll like epoxy some small pads and cut out the frame battens for clearance next fall.
Oar pad and lock detail.
Need to rework the name design for the decal. Lines are a bit too fine for cut vinyl.
Bird's eye view
The builders: Brian (lead inspector), John (laborer), Matthew (lead assistant)
Thanks to Jacque, Shine and all those at Bateau for their insight, design, comments, etc.
Thanks to all the forum members for sharing their builds, successes, fails, opinions, suggestions, positive comments and encouragement.
thanks... now... onto making bunks for the trailer and hoping to get this splashed Friday or Saturday.
Bird's eye view
-John
aka NW Trout
Seattle, WA
aka NW Trout
Seattle, WA
- sitandfish
Re: FL12 - NW Trout - Done!
Great looking! Love the blue stripe next to the bright work rail. Nicely detailed. Now... get to fishing.
Really looks good!
Cut vinyl for the name... then paint the rest... very carefully. You might even be able to screen on the rest, but I don't know how well the textile ink/paint would grip the topcoat paint. Is that all S3 LPU?
