Doc_Dyer's V10
Posted: Tue Aug 31, 2010 1:59 pm
by Doc_Dyer
hello all,
now I wont feel guilty for attending the annual boat meets anymore...
its official i've started my V10
using bs1088 Meranti,
already had a few snapfu's which is to be expected
one of my butt joints slid apart on one edge. had to chisel off the plywood and sand down to the orig ply.
got the front bow section together within 1/8" even with the Meranti.
learned that you need to do the bottom panels first and from the bow to stern (used a few hundred zip ties) on and off ...etc.
well enough of the talk here is the boat porn ( yes I used a lot of ties )
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 2:33 pm
by ks8
Ahhh, that is nice BS1088.
Making me hungry....
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 3:39 pm
Looks real good Bradley, but I think you need some more cable ties
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 4:58 pm
by tech_support
Nice cuts on the panles too, very fair
Needs more zip ties though
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 6:15 pm
by gk108
Looks good to me. At that stage, I had way more used zip ties on the floor than on the boat.
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 6:19 pm
by gstanfield
Looking good! I'm not sure if anyone asked, but is there a reason you went so sparingly with the cable ties? I'd have used more if I were you, just to be on the safe side
George
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 9:26 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 10:08 pm
by sitandfish
I already looked at your picture gallery. I understand.
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 10:14 pm
by Doc_Dyer
ok,
you wanted to know why so many zip ties
Meranti is a little stiffer than Okoume.
this is some serious wood torture
I was filling the last of my drill holes with ezfilet on the transom when I hear
BANG
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 10:16 pm
by Doc_Dyer
ohh well just another day of zipping... hope I have enough ties
Bradley
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 10:24 pm
by gstanfield
Dang it man, that sucks
You do know we were all just kidding with you in fun right?
FWIW, I had the same issue using my cheap exterior wood on my FL14. I also thought I would be smart and save some money on zip ties and buy a bag of cheap ones instead of using my "good" ones. Well it was about 20degrees F in the shop when I stitched it. I then turned on the heater and went back inside for a couple hours. When I came back to the shop I had plywood on the ground and broken ties everywhere. Luckily I had not put any glue on it yet
I wasn't going to tell anyone about that, but didn't want you to feel alone so there you go, you're not the only one to have issues wth tie breakage
Looks good now though
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 10:30 pm
by Doc_Dyer
no worries about the kidding... I have VERY thick skin... one must when one jabs as much as I do
yea it sucks, but it is not the end of the world or the end of this boat...
got to go to dance lessons for my wedding in 2 weeks...
but must make SWMBO happy...
thursday I will clean her up a little and rezip her.. this time put some fillet on the interior of the bow.
I plan on making a sailing version so the whole bow will be filled with foam and enclosed
Bradley
edit: well the rest of the boat looks great and is holding fine
Re: Doc_Dyer's V10
Posted: Tue Aug 31, 2010 11:34 pm
by gk108
If you can, try to pull the panels as close to being in place as you can while you wait for Thursday. That will make them easier to pull into final position when you get back to it.
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 2:28 am
by ks8
I had to *train* my Doug Fir panels for two weeks with humidty and jigs and weights, before they would make the bends to the bow transom and stay put without ripping stove wire out through the drilled holes. There's four wrappings still in there under all the glass and goo. I just think of them as permanent internal stitches. There's also around 4 layers overlapped in those areas now, and that's just on the outside. If something fails, that won't be it.
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 6:34 am
by SmokyMountain
I think you said "dance lessons" and your boat puked
. HA HA HA HA ...
I woud put a few fiberglass strips to along with the fillets just for a little extra peace of mind. Let me know if you need help.
Andrew
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 11:43 am
by alexbalex
http://gallery.bateau2.com/displayimage ... 985&pos=12
That's how mine looked like - 5 mm Okoume plywood for the hull panels, wetted them with water and used copper wires. Well, mine is a V-12 and the bending is not so severe
But you will manage to get it in shape, just keep trying
Alex
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 1:11 pm
BANG
Dangit man. I think I'd cut a short piece of 2X4 to match the stem angle from the inside, and shoot a couple of drywall screws in it.
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 1:26 pm
by ks8
II like CL's idea, maybe using flathead screws with fender washers, so they don't pull through the plywood under the strain. Since I'm planning a V12 or C12, I've got to remember this myself.
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 2:05 pm
by Doc_Dyer
ill try my arms first, if that doesn't work, then I'll try
CL's fix with the wood backing. but if I get it in place then I will glass the front with some temp glass strips
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 3:41 pm
by tech_support
wow, that's a surprise. A bow mold would help, we used one on the FS12 which was 6mm mernati. I was looking for a picture of it, bu the only one I found was this, you can barely see it up there in the bow
We attached it to a scrap 2x4 screwed to the first mold/frame.
You can also use some copper wire, which is more the old school way of doing it
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 9:00 pm
by gk108
You can see from this picture that I didn't get the gap totally closed on mine.
There was maybe a ¼" gap where the 4 panels met.
After a couple of tries, I finally figured out what was going on when the plywood is bending in one plane and twisting in another. I could get the centerline stitches to work OK, but the chine just refused to cooperate when I tried to pull the stitches tight.
I finally made it fall in place with temp cleats on the inside pulled with only one screw on each. That worked to pull the bottom panels in while applying equal force pulling the side panels out.
Tightening the chine stitches at the bow tended to pull the panels into an overlap before the panel edges met. Using the cleat and screw method, I could apply the twisting force without pulling the seam closed.
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 11:31 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Sep 01, 2010 11:35 pm
by Doc_Dyer
this is using aircraft saftey wire, doubled and in one joint 4 wires thick to help prevent wood pull through
one more day
and I will have it back like it should be
Bradley
Re: Doc_Dyer's V10
Posted: Thu Sep 02, 2010 12:05 am
by Aripeka Angler
Congratulations on kicking off your build
Best wishes with your wedding as well. You are doing pretty good since you hit 52...
Re: Doc_Dyer's V10
Posted: Thu Sep 02, 2010 12:08 am
by Doc_Dyer
thanks, its been a rough start but I will prevail
for those who don't know.. the 52 is an inside joke
i'm only 41
Bradley
Re: Doc_Dyer's V10
Posted: Thu Sep 02, 2010 12:42 am
by ks8
Now I won't be able to sleep, or will get chased by a big 52 in my dreams.
score on the back nine?
the buoy you hit?
I will not think about 52 ... I will not think about 52 ... .... 52 ... 52 ..........
Re: Doc_Dyer's V10
Posted: Thu Sep 02, 2010 12:05 pm
by Doc_Dyer
ok I think you have waited long enough
last fishing trip with Richard and Larry me and Sonner were driving down I-75 and got off the interstate onto hwy 52 so I texted Richard and told him that I was hitting 52. he replied that he didnt know it was my birthday
it took me and Sonner about 5 min to figure out what in the hell Richard was talking about?
so now you can get some sleep
Re: Doc_Dyer's V10
Posted: Thu Sep 02, 2010 12:50 pm
by ks8
Except its a little after noon. Can I save the sleep for later? Though, that never seems to work, does it?
Re: Doc_Dyer's V10
Posted: Sat Sep 04, 2010 3:58 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Sat Sep 04, 2010 5:11 pm
by SmokyMountain
Look'en good!! You've got a boat.
I guess the bow came together all right?
Re: Doc_Dyer's V10
Posted: Sat Sep 04, 2010 6:01 pm
It might be too late, but I usually wrap a ratchet strap around the bow to pull it tight. Clamp a small block of wood on the outside of each gunwale, a foot or so behind the bow, so the strap won't slip, and crank her into a position of submission
Re: Doc_Dyer's V10
Posted: Sat Sep 04, 2010 8:34 pm
by ks8
I'm not sure, since I don't have those plans, but I think what it means by flush with top of sheer line, is that instead of the curve top of the frame there, the sailing version has a straight top across. Maybe this is because of the way the mast partner will mate to it? Gary built one (gk108). Maybe he will jump in here with some clarification.
Re: Doc_Dyer's V10
Posted: Sun Sep 05, 2010 1:17 am
by Doc_Dyer
ks8 wrote:I'm not sure, since I don't have those plans, but I think what it means by flush with top of sheer line, is that instead of the curve top of the frame there, the sailing version has a straight top across. Maybe this is because of the way the mast partner will mate to it? Gary built one (gk108). Maybe he will jump in here with some clarification.
Yes I know it is to be flush with the sheer, i'm asking about veering from the plans and make front deck curved
The mast partner will be aft of the bulkhead
Bradley
Re: Doc_Dyer's V10
Posted: Sun Sep 05, 2010 9:08 am
by gk108
Looking good! Two things about the front deck and frame...That's a small triangle of plywood and it will be difficult to bend too much of a radius in the deck, unless you are planning on strip planking it. The other thing is that the mast may need to be longer to give you the same amount of length below the sail so that you can still bend it on and tighten the luff without running out of room.
Re: Doc_Dyer's V10
Posted: Sun Sep 05, 2010 10:51 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Sun Sep 05, 2010 11:13 am
by gk108
Assuming you will be making a mast partner to match the camber of the deck, the mast needs to be lengthened by the amount of the camber. That way, your sail still fits the mast and you have room below the tack to rig a downhaul. If you go for a rotating mast (highly recommended), you'll want to cleat the snotter on the mast. That's also a place where you will probably want a fairlead for the brailing line. It gets crowded right in that part of the mast, something I didn't compensate enough for when changing my rig to leg o mutton, with it's longer luff. The new CF mast will be 3" or 4" longer to correct that.
Re: Doc_Dyer's V10
Posted: Sun Sep 05, 2010 12:59 pm
by Doc_Dyer
Drawing or picture
Not a sailor help with terminology
The mast partner is a piece of 3/8" flat plywood from rubrail to rubrail
The mast partner is flush with the sheer.....behind the front bulkhead
The mast center is 3" behind the bulkhead
So unless the sail is past 90 degrees it will not hit the curved bow deck
how often is sail forward of 90 degrees....I would think on a downwind run
Bradley
Edit: I was thinking 1/4" with 4oz glass for foredeck
Re: Doc_Dyer's V10
Posted: Sun Sep 05, 2010 6:37 pm
by gk108
I don't seem to have any good pictures of that part of my boat.
If you go with the mast partner as drawn, there shouldn't be any trouble. For some reason, I was picturing a nice steam bent arcing partner, similar to what I've seen on certain drift boats.
You are right, the sail will go past 90° on a downwind run. I'm still getting used to the downwind lift from a rotating mast. I like it, though. 6.1 mph tops and I think I can get a little more. Beats the heck out of hanging a sail out like a parachute and going slow.
Lessee...
Snotter - Line that runs up the mast, through a block or fairlead and down to the bottom end of the sprit. Trims the sail shape for different conditions.
Tack(of sail) - The bottom front corner of the sail.
Downhaul - Pulls the leading edge of the sail taut, otherwise the sail will creep up the mast and have a scalloped leading edge. Usually attached to or run through the tack grommet. Mine runs from the grommet, through an eye on the mast, back through the grommet to a cleat to give a 2:1 pull.
Brailing line - Made fast about midway up one side of the mast, runs to the backside of the sail, through a grommet and back to a fairlead on the other side of the mast and down to a handy place to grab. Pulling the brailing line will douse the sail quickly.
Re: Doc_Dyer's V10
Posted: Sun Sep 05, 2010 9:39 pm
by Doc_Dyer
Thanks that helped a lot
I was going to make a steam bent mast partner but decided not to
No need in racing with Ks8
Let's get this done and fishing/sailing/tooling around
Got outside hull sanded, taped, glassed today.... Worked all day
No pics till Tuesday. When I sync my iPhone
Having a blast
Bradley
Re: Doc_Dyer's V10
Posted: Mon Sep 06, 2010 10:56 pm
by Doc_Dyer
wow got a lot done over the holiday weekend
flipped after taping the interior,
sanded outside ezfilet,
taped seams,
glassed 4oz both sides
appiled ezfairing
started sanding faring
Here is the BOAT PORN
enjoy
Bradley
Re: Doc_Dyer's V10
Posted: Tue Sep 07, 2010 7:53 am
Great progress for a weekend Bradley
Glass work looks real good!
Re: Doc_Dyer's V10
Posted: Mon Sep 13, 2010 7:51 am
by SmokyMountain
I want to say congratulations to Bradley. He finally found the right one and got married this weekend. It was a very nice outdoor wedding (the tux was hot
) and the bachelor party was profitable...at least for me
. Though the resulting headache lasted most of the next day...
He and his wonderful bride are having a short but intense
honeymoon over in Bryson City, N.C. area.
Now that I think about it ..... this may be a stealth honeymoon to go check on Tom's progress on his boat
... Tom if you see somebody peaking in your shop window, please, just shoot to wound
In all seriousness, I wish you a long and happy / fruitful marriage.
Andy
Re: Doc_Dyer's V10
Posted: Mon Sep 13, 2010 8:45 am
Congrats Bradley
Re: Doc_Dyer's V10
Posted: Mon Sep 13, 2010 10:00 am
by tech_support
congratulations on the wedding and also you faring skills
The fairing job is a great example of how to not waste material
Fill the lows only and use a long board
this is what fairing application should look like
Re: Doc_Dyer's V10
Posted: Mon Sep 13, 2010 1:43 pm
by TomW
Congratulations, Bradley!
Re: Doc_Dyer's V10
Posted: Mon Sep 13, 2010 4:59 pm
by Doc_Dyer
Thanks everyone
Tom.. Sorry but I didn't get around to getting pics
Already home... Ready to start back on the v10
Bradley
Re: Doc_Dyer's V10
Posted: Tue Sep 14, 2010 7:03 pm
by Biker B.O.B.
Congrats on the wedding. May you enjoy many happy years together. Which might be more likely since she knew about the boat building before saying her vows.
The boat is looking good too. Can't wait to see it finished.
Re: Doc_Dyer's V10
Posted: Wed Sep 15, 2010 12:44 pm
by Doc_Dyer
shine wrote:Nice cuts on the panles too, very fair
ahhhhh, looks like i learned from bateau
found this today
kettle
Re: Doc_Dyer's V10
Posted: Wed Sep 15, 2010 4:58 pm
by ks8
Congratulations on the marriage!
Now you've got someone to help make course corrections at 3am on VRegatta....
Re: Doc_Dyer's V10
Posted: Wed Sep 15, 2010 6:10 pm
by stickystuff
Congrats on the marriage. come Nov. 27 the wife and I will hit 45 yrs. will be up in your neck of the woods around Oct.18,19,20 and 21. Got to see the leaves releave themselves. Haven't seen them since I lived in Tenn. back in 79. Lived in Sparta for 5 yrs. Send me phone # and address. If I can get by will stop in for a few. would love to see your build.
Ken
Re: Doc_Dyer's V10
Posted: Wed Jan 05, 2011 1:34 pm
by Doc_Dyer
update....
have to get this thing done for the meet this June...I will NOT be there for the THIRD year in a row with a PLASTIC boat
I have modified my front deck to be curved instead of flat like the plans say
it is 2 layers of 1/8 mahogany plywood with the whole bow filled with Foam
first layer
another view
and finally the back seat cleats..... the center divider section is also my design, I plan on having a screw type access hatch
for access to bottom rudder bolts and a place to put wallet and cell phone while on water.
THE brace in the middle is temporary to hold pressure on the cleat on the transom.. it has been removed
as well as the outer bays now have foam in them, I started glassing the box in the middle
but no pics yet
Re: Doc_Dyer's V10
Posted: Wed Jan 05, 2011 2:08 pm
by TomW
Nice bow Doc, I like the change.
Re: Doc_Dyer's V10
Posted: Wed Jan 05, 2011 2:10 pm
by Doc_Dyer
Thanks TomW
plans show to cut front bulkhead to top of sheer line. see following pictures
I believe that the sheer line is NOT where it is pointed to on the plans
[/quote]
Re: Doc_Dyer's V10
Posted: Thu Jan 06, 2011 8:13 am
by topwater
Doc nice bow mod
Re: Doc_Dyer's V10
Posted: Thu Jan 06, 2011 1:32 pm
by ks8
Looking forward to how you implement the mast partner.
Re: Doc_Dyer's V10
Posted: Fri Jan 07, 2011 7:45 pm
by gk108
My 1994 version of the V10 plans has that frame drawn correctly
Re: Doc_Dyer's V10
Posted: Sat Jan 08, 2011 7:50 pm
by Doc_Dyer
What is the dim between top and frame height?
The vertical one blacked out
Re: Doc_Dyer's V10
Posted: Sun Jan 09, 2011 9:47 pm
by gk108
Base line to frame top is 3-3/8". Does your version of the plans include a table of offsets?
Re: Doc_Dyer's V10
Posted: Mon Jan 10, 2011 10:44 am
by Doc_Dyer
no, i was just wondering how tall my curve was...
update:
sanded down storage box and repainted
cut out rear seat
cut out for rear hatch
screwed in hatch, flipped over filled in gaps where I cut with jig saw
designed mast step, glued pieces together
finalized mast partner design....its a secret...
Re: Doc_Dyer's V10
Posted: Mon Jan 10, 2011 11:05 am
by gk108
Looks good. Don't forget that mast rake is set by the distance between partner hole and frame at the designed frame height. It will be a bit different at the top of the hump. Maybe not enough to matter much, though.
Re: Doc_Dyer's V10
Posted: Mon Jan 10, 2011 12:17 pm
by Doc_Dyer
thanks,
the mast partner is as designed... flat..
I was thinking of steaming a curved one... but decided against it.
Bradley
Re: Doc_Dyer's V10
Posted: Mon Jan 10, 2011 12:27 pm
by gk108
Either way will look good. Kinda has a little SB18 look to it with the hump.
Re: Doc_Dyer's V10
Posted: Mon Jan 10, 2011 7:46 pm
by Biker B.O.B.
Now you've got my curiosity wound up. Hope you get that built soon so I can see this secret.
BTW, the boat is looking good.
Re: Doc_Dyer's V10
Posted: Mon Jan 10, 2011 11:41 pm
by Doc_Dyer
Thanks all,
The secret is I can not find the species of wood wide enough for the mast partner, so I will have to splice
Two pieces together
You will see the joint...
So.............
Sorry Its soon on the list :
Standby
Bradley
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 10:11 am
by gk108
It took me a while to find the plank for my partner. I was just about to go plywood, but I finally ended up paying too much for one on ebay.
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 10:35 am
What kind and size of plank do yall need?
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 11:44 am
by Aripeka Angler
Yeah, let us know. I or we might be able to help
Your boat is looking sweet btw....
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 1:43 pm
by TomW
Yep let me know I have some nice walnut that might work.
I'll even deliver if the snow doesn't stop me.
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 1:59 pm
by Doc_Dyer
alright....
I need a piece of 3/4"x8"x43"
lacewood.
anyone find me some? Please...
Jefferies woodworks is out and dosent know when they will get more in.
anyhelp would be apreciated...
Bradley
TomW if you can get it.... Ill drive over and get it...I promise I will not bring a camera...
but would like to see your build
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 2:41 pm
by TomW
Sorry Bradley I just have the walnut in that size no lacewood unfortunately
Here's another source I have used in the past
http://www.advantagelumber.com/lacewood.htm for small puchases.
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 2:49 pm
I had to look it up to figure out what it is
Sorry Brad, no lacewood here either. I called my local supplier and he laughed at me
He suggested woodcraft.com as a possible source. I looked there and they only seem to offer it in veneers.
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 3:48 pm
by Doc_Dyer
yea, Im wanting to get the partner done so I guess ill have to splice the pieces that I have
it should turn out ok...we will see
Larry if you have never seen lacewood bright finished in the sun...... WOW the little lighter sections glimmer like gold bars
truly amazing
Bradley
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 4:49 pm
by TomW
Doc if you have enough do at least a partial scarf joint even a 60 degree angle will make the joint less conspicuous.
Re: Doc_Dyer's V10
Posted: Tue Jan 11, 2011 5:36 pm
by Aripeka Angler
Bradley, if a week isn't too long to wait I should be able to hook you up with a chunk of lacewood. Let me know if you want me to get it for you...
Re: Doc_Dyer's V10
Posted: Thu Jan 13, 2011 6:01 pm
by Aripeka Angler
Re: Doc_Dyer's V10
Posted: Thu Jan 13, 2011 6:15 pm
Wow, that is some pretty wood. Richard, you are the man
Re: Doc_Dyer's V10
Posted: Thu Jan 13, 2011 6:22 pm
by TomW
Very nice!!!!
Re: Doc_Dyer's V10
Posted: Thu Jan 13, 2011 7:10 pm
by Doc_Dyer
Outstanding Richard
Thank you sooooo much
I'm so thankful to have met such wonderful friends here on the forum
The V-10 aka " Brandi Gale" will shine with such beautiful wood
Bradley
Re: Doc_Dyer's V10
Posted: Thu Jan 13, 2011 7:44 pm
by wegcagle
WOW
That's amazing wood, and it's not even varnished yet
She'll do right by the Brandi Gale.
Will
Re: Doc_Dyer's V10
Posted: Thu Jan 13, 2011 9:09 pm
by Aripeka Angler
Thanks guys
Pictures do the wood no justice, it looks much better than the poor light over the work bench would let my camera capture. The flecking in the wood is supposed to shimmer like diamonds when you finish it and get it into bright sunlight. It started off the day as a 2x8 that weighed probably 8-10 lbs per linear foot. I resawed it and ran it through a big 52 inch wide auto-feed belt sander. It ended up 13/16 thick and 7 inches wide. Interesting how I aquired it...
I struck up a conversation with the guy that had the 16 foot board and asked him if he would cut me off a 4 foot piece. He really didn't want to at first. For some reason he told me he was from Alaska
I told him I spent a couple of weeks up there this summer and whipped out my I-phone to prove it. He spotted some halibut in one of the pics and asked me if I had brought any back. Of course I said yes as he picking up the board to cut me off a chunk
Anyway, I traded the board for 4 lbs. of Alaska halibut
Me too Bradley...
Re: Doc_Dyer's V10
Posted: Fri Jan 14, 2011 12:27 am
Me too Bradley...
Amen
Re: Doc_Dyer's V10
Posted: Fri Jan 14, 2011 7:54 am
by tech_support
I have never seen wood like that, very pretty, cant wait to see it bright finished.
Re: Doc_Dyer's V10
Posted: Tue Jan 18, 2011 2:13 pm
by Doc_Dyer
yeee hawwww,
lookie what UPS brought me today...
Thanks Richard
here is a pic of it moistened with a damp cloth
have a meeting tonight but will start on it tomorrow night
can not wait to see a mast going through it
Bradley
Re: Doc_Dyer's V10
Posted: Tue Jan 18, 2011 3:41 pm
Measure 3 times, cut once
That's beautiful stuff
Re: Doc_Dyer's V10
Posted: Tue Jan 18, 2011 6:49 pm
by TomW
Doc sounds like you have used this wood before. If not cut off what you are not going to be using and drill and experiment with it. The African and South American woods can be as tame as our maple or cherry or they can present special problems when machining them.
Re: Doc_Dyer's V10
Posted: Tue Jan 18, 2011 9:20 pm
by Doc_Dyer
yes TomW,
I have used this wood before on my jet boat that I built from scratch.....plans and all..
I however did not know of this forum. therefore I failed at some critical points. which led to my boats demise
my front decorative board and also my dash were made from lacewood.
The lace parts shimmer like gold bars in the sunlight
Bradley
Re: Doc_Dyer's V10
Posted: Wed Jan 19, 2011 3:31 am
by TomW
No question about it Doc, it is one pretty wood! It should shine on your V10.
Re: Doc_Dyer's V10
Posted: Mon Jan 24, 2011 2:34 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon Jan 24, 2011 4:28 pm
by Prarie Dog
Doc, am really pleased to see that boatbuilders everywhere have figured out the correct use for barbells. That is a beautiful piece of wood, really pretty work.
Re: Doc_Dyer's V10
Posted: Fri Jan 28, 2011 11:56 am
by Joe H
I'm not one to usually comment on another guys wood but yours seems to be getting a lot of attention, so......nice wood.
The Boats looking great, very nice work.
Joe H
Re: Doc_Dyer's V10
Posted: Fri Jan 28, 2011 12:59 pm
LMAO
Joe, you ain't right!
Re: Doc_Dyer's V10
Posted: Fri Jan 28, 2011 3:11 pm
by wegcagle
Now that's funny. Kinda makes me blush for having commented
Will
Re: Doc_Dyer's V10
Posted: Tue Feb 01, 2011 12:28 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Tue Feb 01, 2011 2:24 pm
by Aripeka Angler
That looks very, very nice
you still on target for the event? BTW, Andy says you need to hurry up so you can help finish the Phantom
Re: Doc_Dyer's V10
Posted: Tue Feb 01, 2011 2:28 pm
by Doc_Dyer
Aripeka Angler wrote:That looks very, very nice
thx should be, still got 4 months
no doubt...but its a waiting game now
boat has to dry for a week before you can sit it on trailer
Re: Doc_Dyer's V10
Posted: Tue Feb 01, 2011 2:33 pm
by Aripeka Angler
I would throw some wax paper on the bunks even after a week. That white paint looks mighty nice. I would hate to see it stick...
Re: Doc_Dyer's V10
Posted: Tue Feb 01, 2011 2:41 pm
by Prarie Dog
Doc, are you going to put a "NO STEP" sticker on that Lacewood? If I had something that pretty on my boat someone would step on it on it's maiden voyage.
Re: Doc_Dyer's V10
Posted: Wed Feb 02, 2011 1:43 pm
by Doc_Dyer
PD,
it would be hard to get a foot up on it I think...
it is fairly strong wood also
update:
got hole cut in boat for dagger board box and ROUGH cut my skeg still need to smooth the curve and router the edges round
Re: Doc_Dyer's V10
Posted: Fri Feb 04, 2011 10:58 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Fri Feb 04, 2011 11:05 am
by cape man
You're getting really good at that laminating stuff! That looks solid as hell!
Re: Doc_Dyer's V10
Posted: Fri Feb 04, 2011 11:22 am
by Doc_Dyer
well the topic on making a skeg disposable got me thinking
also I plan on using this boat on the beach in June with the my wife, and SmokyMountains Family
so it will get beached a lot in a week....
so I wanted it to be bullet proof.... painting with graphite also
Bradley
Re: Doc_Dyer's V10
Posted: Fri Feb 04, 2011 11:34 am
by cape man
That'll do it! You bringing it to Boca? Richard and I are planning to bring two canoes as well.
Re: Doc_Dyer's V10
Posted: Fri Feb 04, 2011 1:18 pm
by Doc_Dyer
yes, dont know if ill splash her in boca, but me and Andrew and our families are headed to Port Saint Joe for a week after we leave Boca..
It Will Be Done, by Boca trip......yes it will be there
Bradley
Re: Doc_Dyer's V10
Posted: Fri Feb 04, 2011 4:03 pm
by cape man
Re: Doc_Dyer's V10
Posted: Sat Feb 05, 2011 8:41 am
by gk108
St. Joe Bay will be fun in a V10.
Re: Doc_Dyer's V10
Posted: Sat Feb 05, 2011 12:17 pm
by ks8
I think we can safely say that your skeg is now a permanent part of the boat.
You won't regret fairing that well.
http://gallery.bateau2.com/displayimage ... 44&pos=112
Re: Doc_Dyer's V10
Posted: Sat Feb 05, 2011 5:39 pm
by stickystuff
Our first Bateau Rendezvois was in or at St.Joe bay. Beautiful place. If I remember Jim Wright and myself were the only ones to have a finished boat. Another builder had a sail boat on the trailer unfinished. Can't remember his name.Couple more people without boats. Beautiful bay and flat calm perfect weather. Jacques was there. At this time Shine didn't work for bateau. This was ten or eleven yrs. ago.
Re: Doc_Dyer's V10
Posted: Mon Feb 14, 2011 9:54 am
by Doc_Dyer
progress
stern seat started fairing,
mid-ship layer of 4oz glass
rounded Mast step, still not glued in yet
played around with a V' bit not the right one....Got the right ones today
glued it up, found out it is a bear to hold and glue all of the pieces together till you have them all in
Re: Doc_Dyer's V10
Posted: Mon Feb 14, 2011 10:02 am
by cape man
I like the way you did the mast step and mast. Thanks for the pics!
Re: Doc_Dyer's V10
Posted: Mon Feb 14, 2011 10:13 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon Feb 14, 2011 10:45 am
by gk108
Very cool
What kind of wood will you use for the mast?
Re: Doc_Dyer's V10
Posted: Mon Feb 14, 2011 10:50 am
by Doc_Dyer
I would love to use Spruce or douglas fir,
Re: Doc_Dyer's V10
Posted: Mon Feb 14, 2011 11:02 am
by Aripeka Angler
Doc_Dyer wrote:I would love to use Spruce or douglas fir,
Whheeww! I was sweating bullets. I thought you were going to say you that you were looking for some ping-pong zebrawood or something...
Nice work! You guys have alot going on up there right now
Re: Doc_Dyer's V10
Posted: Mon Feb 14, 2011 1:17 pm
by Doc_Dyer
Aripeka Angler wrote: ping-pong zebrawood or something...
thats funny
that is with 3/4" wide and 1/2" deep wood
I believe that I can reduce that down to 3/4" and 3/8"
which will get me a little larger Inside Diameter and shave a lot of weight.
will try again tonight with the correct router bits and 3/8" thick wood.
Bradley
Re: Doc_Dyer's V10
Posted: Mon Feb 14, 2011 5:41 pm
by stickystuff
Thats a cool set of bits. I thought I had a bunch. Must have missed those. Looks great.
Re: Doc_Dyer's V10
Posted: Tue Feb 15, 2011 8:47 am
by Doc_Dyer
Ken, actually that is a V bit that I had in one of my router bit boxes
not the new ones this is with one of the new bits
this is 3/8"x3/4"ping pong zebrawood Vs 1/2"x3/4" Ash
Re: Doc_Dyer's V10
Posted: Tue Feb 15, 2011 9:56 am
Very cool Bradley. Nice work
Re: Doc_Dyer's V10
Posted: Tue Feb 15, 2011 9:12 pm
by gk108
Mighty fine! Are you using a lathe to clean up the outside?
Re: Doc_Dyer's V10
Posted: Tue Feb 15, 2011 9:38 pm
by Aripeka Angler
gk108 wrote:Mighty fine! Are you using a lathe to clean up the outside?
I was wondering the same thing myself
Here is a pic Doc sent me via text that got me curious...
I am about to buy a lathe myself for the canoe paddles. I think I will buy a used metal lathe in lieu of a wood lathe. It will be much more useful...
Re: Doc_Dyer's V10
Posted: Tue Feb 15, 2011 11:09 pm
by Doc_Dyer
Actually,
That is just about 3 min with a block plane ONLY
I wouldn't believe it either till I sat down and started
Plan on building a crude lathe type setup to do the 8'6" mast
Bradley
Re: Doc_Dyer's V10
Posted: Wed Feb 16, 2011 8:31 am
I love a good block plane, one of my favorite tools
I'm thinking it would take a dang big lathe to turn a sailboat mast
Re: Doc_Dyer's V10
Posted: Wed Feb 16, 2011 9:00 am
by gk108
I considered a few different ways when I made my wooden mast and the drill motor/wheels rig that I came up with seemed to be the easiest to throw together.
A 50 grit disk on the grinder took care of fast stock removal, fine tuned with the belt sander, then an inside-out sanding belt. As you can see, it was a sawdust intensive operation.
Re: Doc_Dyer's V10
Posted: Wed Feb 16, 2011 9:04 am
Very inventive Gary
Re: Doc_Dyer's V10
Posted: Wed Feb 16, 2011 9:15 am
by Doc_Dyer
I knew I had seen that picture somewhere before,
thanks for keeping me from digging
Bradley
Re: Doc_Dyer's V10
Posted: Mon Feb 21, 2011 10:08 am
by Doc_Dyer
update:
sanded some more on mid section and aft section
made ash mast... dont like...
put some epoxy on test mast.... like...
cut wood for new mast .... out of ping-pong zebra wood
actually Lacewood
first coat of poxy on mast partner
Re: Doc_Dyer's V10
Posted: Mon Feb 21, 2011 10:17 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon Feb 21, 2011 10:20 am
by Aripeka Angler
That looks great
I was wondering what you were going to use the oops piece of wood for...
Re: Doc_Dyer's V10
Posted: Mon Feb 21, 2011 2:46 pm
by cape man
I like that...The Oops Piece of Wood...Perhaps we have a new blogger abreviation - OPW.
Re: Doc_Dyer's V10
Posted: Mon Feb 21, 2011 5:47 pm
by Aripeka Angler
cape man wrote:I like that...The Oops Piece of Wood...Perhaps we have a new blogger abreviation - OPW.
Here now, I must set the record straight
I sent Bradley the OPW just in case there was an oops. I had 8 lf. of lacewood and he only needed 4. I thought about keeping the extra 4 foot I got when I resawed it, but couldn't figure out what I would use it for
I like the new abbreviation though
So Bradley, how did that wood cut and rout for you?
Re: Doc_Dyer's V10
Posted: Mon Feb 21, 2011 6:49 pm
by stickystuff
The hand built lathe is some of the finest afroengineering I have ever seen. Great idea. I will remember that.
Re: Doc_Dyer's V10
Posted: Tue Feb 22, 2011 10:00 am
by Doc_Dyer
Richard,
Lacewood cuts like butter, very easy to cut and router
Thanks again for sending the OPW as you can see it will not gather dust in a wood pile, but be a part of my V-10
Bradley
Re: Doc_Dyer's V10
Posted: Wed Feb 23, 2011 8:39 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Feb 23, 2011 9:00 am
by Doc_Dyer
now before anyone gets excited.....
this is a DRY mock up, just to see if all the little pieces fit to make a 8'6" mast
it does
will epoxy together on Friday
also found a way to put the last layer of my rubrail on so I don't have any screw holes in the finish board
the bottom wants to pull away from boat. so I did this...THIS is also a dry run...will epoxy this on tonight
along with the other side
I can fill these holes and you would have never known they were there
Re: Doc_Dyer's V10
Posted: Wed Feb 23, 2011 9:24 am
That's going to be a fine looking mast Bradley
What are you going to make the sprit from?
Re: Doc_Dyer's V10
Posted: Wed Feb 23, 2011 9:33 am
by Doc_Dyer
good question,
need to see if I can make one that small,
I believe it is 1.5" tapering to 1"
my mast is 2" ish
Lacewood (oops sorry I meant PING-PONG ZEBRAWOOD
Re: Doc_Dyer's V10
Posted: Wed Feb 23, 2011 10:28 am
by gk108
That's a cool looking mast. How did you do that, hold this with one hand while you put these parts on with your other hand and tape together with your third hand while you stand at the other end and eyeball for straightness?
Re: Doc_Dyer's V10
Posted: Wed Feb 23, 2011 11:05 am
by Doc_Dyer
straightness will come when I epoxy together then tape then lay on floor and beat the hell out of the ends to square it up
then take a block plane and get it close before I build the lathe that was posted earlier to get it to the final shape
and yes it was a bear to get together, that is the reason it is not glued yet....
need at least a half a day to get everything ready, I have to number the pieces so it goes back like this..
maybe Friday
Re: Doc_Dyer's V10
Posted: Thu Feb 24, 2011 2:34 pm
by Doc_Dyer
Rubrail = 1/4x1/4 Ash ontop of plywood edge, 1/4x1-1/2 Mahogany, 1/4x1-1/2 Ash, 1/4x1-1/2 Mahogany
port side not glued yet, starboard side stern finished, need to put outermost piece on midway to bow
decided to leave rubrail straight and jut fill in on the bow, just needed a little filler
Re: Doc_Dyer's V10
Posted: Thu Feb 24, 2011 2:39 pm
The boat is looking great
But the fine print really cracks me up
Re: Doc_Dyer's V10
Posted: Thu Feb 24, 2011 2:53 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Thu Feb 24, 2011 4:35 pm
by wegcagle
Boats looking good doc. I too was laughing my way home from work today
Will
Re: Doc_Dyer's V10
Posted: Thu Feb 24, 2011 9:41 pm
by majorgator
I like the updates to the fine print...
seth
Re: Doc_Dyer's V10
Posted: Mon Feb 28, 2011 10:46 am
by Doc_Dyer
boat porn
decorative cap so no exposed plywood edges, all layers of rubrail are on
started to final finish rear seat area with tinted epoxy seal layer over faring compound
used some ingenuity on putting front rubrail on since I didn't want any screw holes on outer most layer
Re: Doc_Dyer's V10
Posted: Tue Mar 01, 2011 9:42 am
by topwater
Looking good Doc, She will be pretty
Re: Doc_Dyer's V10
Posted: Tue Mar 01, 2011 10:42 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Tue Mar 01, 2011 11:55 am
by gk108
That's gonna be a good looking rubrail. While you are gluing little strips, I want to mention something that you may want to consider. Are you planning on a coaming or rail on the foredeck? When beating upwind in a good chop, I get a lot of spray that lands on my foredeck. With my flat deck, the partner acts as a coaming and directs the water overboard and saves a lot of bailing. Your deck may have enough camber to help out with that, but when heeled, you'll have more surface area that is near level from side to side than a flat deck, which would have no level area when heeled. With every rise of the bow, water in that nearly level area will run right towards the captain.
Re: Doc_Dyer's V10
Posted: Tue Mar 01, 2011 12:59 pm
by Doc_Dyer
thanks, GK
but Im used to sailing a Phantom (moonfish, Sailfish....etc..)
so It will be a LOT drier than Im used to
no plans yet, will have to sail her and see... if shes too wet I'll add something later
Bradley
Re: Doc_Dyer's V10
Posted: Tue Mar 01, 2011 9:53 pm
by gk108
Doc_Dyer wrote:but Im used to sailing a Phantom (moonfish, Sailfish....etc..)
You got that right! I once rented one of those for an afternoon. Sorta fun, but no drinkholders.
Re: Doc_Dyer's V10
Posted: Wed Mar 02, 2011 10:11 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Mar 02, 2011 10:19 am
by SmokyMountain
Looks great!
Definitely go with the ash divider.
Re: Doc_Dyer's V10
Posted: Wed Mar 02, 2011 10:28 am
by Aripeka Angler
Nice, I really like the rubrail
I think you really are going to get it done. What size kicker you gonna put on it?
Re: Doc_Dyer's V10
Posted: Wed Mar 02, 2011 11:20 am
by Doc_Dyer
Merc 3.3
dont know if im putting oar locks on her yet?
what did you think of the OPW... ie Ping-Pong ZebraWood
Re: Doc_Dyer's V10
Posted: Wed Mar 02, 2011 11:39 am
by Aripeka Angler
I think it looks cool as all get out
Did you buy more
Merc 3.3
Nice! Do you already have it? I got my reasons for asking...
Re: Doc_Dyer's V10
Posted: Wed Mar 02, 2011 12:36 pm
by Doc_Dyer
no I had some narrow stuff...
the wood you got me went into the Mast Partner, Knees, and Transom doubler, and connecting pieces between knees and doubler
the mast is made up of pieces ranging from 6" to 48" all pieced together to make a 8'6" Mast
Thank you again..
Dad has one that he is giving me...
Dads are cool like that
Re: Doc_Dyer's V10
Posted: Wed Mar 02, 2011 1:03 pm
by Aripeka Angler
And so are their children who appreciate them
I'll probably just put the almost new 2.5 hp four stroke Yamaha that I no longer need on the market then. It worked good on my boy's old Gheenoe, too small for for his GF-12....
Re: Doc_Dyer's V10
Posted: Sun Mar 06, 2011 9:15 pm
by cape man
Wow! That is some very pretty wood!!!
Re: Doc_Dyer's V10
Posted: Mon Mar 07, 2011 9:26 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon Mar 07, 2011 2:49 pm
by cape man
You need to warn us when you post stuff like that!!! I'm at work! What if someone had walked by and seen or heard me!!!
GORGEOUS!!!!
Re: Doc_Dyer's V10
Posted: Mon Mar 07, 2011 11:31 pm
by Doc_Dyer
Thanks Craig
More porn soon
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 8:41 am
by topwater
Doc That ping pong wood is goreous
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 8:46 am
by Doc_Dyer
thanks,
the pictures are not showing the depth of brilliance in the wood, hope you get to see it in person in the florida sun !!!
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 8:51 am
by wegcagle
Absolutely amazing. That's some pretty wood
Will
Re: Doc_Dyer's V10
by topwater
I'll be there , wouldnt miss it
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 9:03 am
by Doc_Dyer
Porn
sanded off most of primer with a guide coat of black spraycan
you can see where most of my woes will be... the corners
enjoy
and this is my mast made from Ping Pong Zebrawood (ie Lacewood)
with first coat of epoxy on
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 10:12 am
by cape man
Dang!!! That mast came out sweet!
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 11:15 am
by gk108
That is a nice looking stick. Any idea how much it weighs?
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 11:17 am
by Doc_Dyer
before epoxy coat, it weighed 4 lbs 8 oz
its 8'6" long and about 2" diameter
just ordered a light fiberglass sleeve to put on the mast
hopefully it will be light enough when Im done
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 11:31 am
by gk108
Excellent.
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 12:29 pm
by Aripeka Angler
NOW, I see why you were ordering the fiberglass sleeve
I was scared that you were starting over with a fiberglass mast
The wood looks sweet!! Almost too sweet to clamp an outboard on
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 12:36 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 1:33 pm
by Doc_Dyer
played a little in paintshop on computer.
here is Sterling SeaMist Green and Green KiwiGrip
what yall think?
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 5:05 pm
Nah, I don't like it
What color is that, avocado
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 6:17 pm
by Doc_Dyer
No it's sea mist green by sterling
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 6:22 pm
I still don't like it, looks like the color I painted my mother's kitchen. Of course, it ain't my boat either
Did you want to know what I think, or did you just want me to agree with you?
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 6:24 pm
by wegcagle
I like the color, but I don't think it works well with all of that beautiful wood work. I think you need something closer to white to really bring out the lacewood. Just my thoughts.
Will
Keep up the boat porn
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 6:35 pm
Exactly, it detracts from the wood.
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 6:46 pm
by Doc_Dyer
Thanks, wasn't looking for yes men
I like honesty
But thought it looked like an earth tone color
And complemented the wood great
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 7:15 pm
by wegcagle
One of my favorite interior designers (and parent
) always said that if you want things to match then pick colors on the same side of the color wheel. If you want it to match AND bring out a specific feature then pick colors on the exact opposite side of the color wheel. That's what I was thinking when I said a white-ish color for the insides. It will accentuate all of that lacewood
I will say that I have NO training in design, and this is simply an opinion.
Lookin' good,
Will
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 7:42 pm
by stickystuff
You,ve been watching to much HGTV. c'mon doc. Get back to nature. Just think of all the beautif water you will be sailing.think of something that looks like Seaweed.
Not a bed sheet. Other than that what more could I say?You do some beautifl work.
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 8:12 pm
by cape man
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 9:06 pm
Thank ya Craig
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 10:08 pm
by Doc_Dyer
EASY
It was just a thought
Good thing it was only Photoshop and not 100.00 a quart paint
For the record I still think it would look killer ........BUT......
That is some good beer
I will paint it another color
I think a poll is in order... Standby one
Bradley
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 10:20 pm
by Doc_Dyer
http://www.boatbuildercentral.com/Sterl ... _chart.pdf
Ok here is the chart
Replies on what color
And no butt ugly ones .... Need to drink beer in Boca
Re: Doc_Dyer's V10
Posted: Tue Mar 08, 2011 10:40 pm
by Aripeka Angler
I would go with Sterling cream. Kiwi has a matching color. Paint the outside of the hull green, that would be cool in more ways than one
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 6:02 am
by cape man
She's your boat. Dress her like you want. If she comes out ugly I'll give you 6 beers. They all look good after 6 beers.
Edited: I like light earth tones with wood like that. Cream would be nice.
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 6:43 am
by SmokyMountain
After thinking about it, I think cream would be a better choice for the interior too. (I keep thinking of a Easter egg when I think of the green...) You could go a little more crazy on the hull..... Like the e-tec... I wanted one but got talked out of it....
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 8:53 am
by steve292
JMO....but I like colours
.....I think blue mist on the outside & ice blue on the inside, with blue kiwigrip would look fantastic on that hull.
Steve
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 9:53 am
by gstanfield
I like the "moon dust" color on that chat myself, but it's not my boat.
The work so far looks very nice so go with what works for you
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 9:56 am
by Aripeka Angler
Cream?
Too bad you are out of easy driving range, I probably have 2 and a half quarts of leftover Sterling in that color.
Pencil in weekend of August 13th for the fishing trip we were talking about...
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 11:16 am
by Doc_Dyer
done, caint wait
ok, here is Khaki, MoonDust, and SeaMist
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 11:40 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 12:32 pm
by Joe H
Bradley,
I don't think Photoshop does any of the colors justice, maybe it's just me.
Love the wood!
Joe H
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 4:32 pm
by TomW
Doc, go to Shermin Williams or one of the other stores that sell samples of there paints for like a $1 or 2. Get there highest gloss or what ever gloss you want. I myself like the Cream, Light Blue and Sea Mist in that order. Put a couple of swaths of the test paint on, next to the wood over the epoxy so you can sand it off easily.
It's your boat guy and if you want Sea Mist go for it I sort of like it. Green and wood has always gone together. Another option which I'm now doing in finishing in my basement, but is not usually available in boat paint is a yellow/orange color, it really pops the wood.
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 4:46 pm
by wegcagle
I a fan of the cream or the white. Cream will hide dirt alittle better. Plus free sure is hard
To beat
Will
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 6:27 pm
Bradley, my vote is the Whisper Gray for the inside. Fleet blue or Astro blue for the outside
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 6:53 pm
by stickystuff
I,m with larry on this one.
Re: Doc_Dyer's V10
Posted: Wed Mar 09, 2011 7:09 pm
deleted, emoticon didn't work
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 6:32 am
by cape man
I like the Moon dust.
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 12:55 pm
by Doc_Dyer
more Porn
got back section reprimed after a little quickfair, yet to be sanded
started front seat cleats and glassing interior of front section
Transom doubler is just sitting there, no glue yet
Changing the front seat design
decide to build another bulkhead forward and make seat straight equal to daggerboard box
then make two bench seats like Gk's
probably make out of Ping Pong Zebra Wood
(Lacewood and Ash)
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 1:05 pm
by Doc_Dyer
I have never sailed a Dingy with this type sail. I need a little
with the rigging
I know I need a pulley about 3/4 way up mast (snotter
) to raise the spar
I will have a line going to the rear most lower corner of sail.... where do I attach this ... my hand only?????
or can I put a couple of those pull cleats thingy on the knees?
something about a line going around sail that you could pull in case of trouble to colapse the sail????
where do all these go?
Thanks,
Bradley
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 2:11 pm
by Doc_Dyer
here ya go Larry
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 2:15 pm
by Doc_Dyer
fleet blue and whisper gray
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 3:00 pm
by Aripeka Angler
Two questions...
1) Do all V-10's have the bow deck?
2) Why not paint that bow deck the light color?
No matter color of cream you put on there, I gotta tell you that she is looking nice
Do you need another hit of ping-pong zebrawood yet
You have to be running low by now...
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 3:19 pm
by Doc_Dyer
Aripeka Angler wrote:Two questions...
The Sailing versions do, but it was to be flat not curved like mine
I believe it is too prominent and would look weird
Not yet, Thanks again
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 3:33 pm
with the rigging
Sounds like it
) to raise the spar
Yes, the snotter is the line that raises the sprit.
That's the main sheet. It will first run to a traveler arrangement across the transom, then forward to you. In a small dingy they are usually hand held, you are making continuous adjustments to it, but they can be tied off if the wind is light and steady. If it's gusty you need to be able to let it out quickly, or over you go
I don't know anything about that. Just point the boat into the wind or release the sheet to de-power the sail, release the halyard and gravity will drop it. You might have to tug it some. I'm not an expert on rigging sprit sails, and each boat is different. I know GK has spent a lot of time fine tuning his, I'm sure he'll give you the particulars. I've got some pics I took of him sailing that might help, I'll find them for you.
I think so too, and I like the darker blue and the lighter gray
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 3:56 pm
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 8:54 pm
by Doc_Dyer
Thanks Larry,
But that is a different main sheet setup
Than listed in study plans???
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 9:09 pm
by ks8
Maybe what you are asking about, to *collapse the sail*, if not to actually *lower it*, is a brailing line? A brailing line pulls the sprit and the sail against the mast, thereby getting it quickly out of the way and certainly depowering the sail. Makes it easy to then row or launch or beach. That picture of Gary rowing shows his sail and sprit/boom pulled up against the mast and secured... most likely with a brailing line, but then again, looking at his setup, I don't think he accomplished that with a one step pull on a brailing line. Depending on the configuration of the rig, using a brailing line may be very easy to set up and use, or not quite as easy, and some rigs don't really enable it to be a practical option. Maybe the builder of that fine V-10 will link to a page where he already documented his setup... or if he's busy... you can probably check his build thread or
gallery. gk108
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 9:18 pm
by Aripeka Angler
That picture of Craig rowing
That's Gary aka gk in the pic..
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 9:20 pm
by ks8
Long day.... should've caught that right away... no event horizon around the boat....
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 9:37 pm
by gk108
While my sail is a totally different shape than the one in the plans, it shares the exact same rigging components. They just attach at different places.
The vertical location of the snotter block will need some adjustability. This arrangement works well for me and I'll probably carry over something like it to the new CF mast.
Short spliced a loop of 3 strand with a block captured on the bight. You could make it a really large quoit type rope grommet if you can keep it neat looking.
Pull the loop tight with the block at the low end and wrap around the mast, tuck the top of the loop under the last wrap, then pull the block through the top loop. Any tension on the block only tightens the grip on the mast, but it is easily adjusted with no tension. For a rotating mast, the snotter should cleat to the mast so it doesn't restrict rotation.
My mainsheet traveller is a rope horse. I drilled holes in my knees and secure the horse with a figure eight knot under each knee.
I use a traveller block on it to help get a 2:1 purchase, which makes holding on to the sheet all the time a little easier, but uses a lot of line to do it. Simpler arrangements can be nothing more than a brass ring on the horse to turn the sheet, but that makes friction and wears the sheet.
Your original sail plan shows a grommet on the leech of the sail for a brailing line to collapse the sail and pull it and the sprit up to the mast. The brailing line is made fast to one side of the mast, run through the grommet on the leech, back to a block on the opposite side of the mast, down to the deck where it can be cleated. Vertical location of the tie point and block might best be determined after the rest of the rigging is set up. The proper arrangement should allow brailing without the need to loosen the snotter. My depowering arrangement is probably closer to furling than brailing, since the line pulls the boom up to the mast and the sail goes with it. That can all be done by pulling one line, but gathering and securing the sail has to be done by hand with toggle bungees.
This book helped me figure out some stuff.
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 9:44 pm
Thanks Larry,
I know but the principle is the same. Lots of ways to do it
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 10:18 pm
by Doc_Dyer
Ok
Why does the snotter need to be adjustable
Seems to me that once you locate the proper position
You wouldn't need to adjust again?????
Re: Doc_Dyer's V10
Posted: Fri Mar 11, 2011 11:32 pm
by gk108
You know, I'd really have to defer to someone who has experience with a four sided sail for that one.
Adjusting mine controls foot tension vs. leech tension as the snotter is taken up. Lower wind speeds usually get less foot tension and more leech tension with the snotter eased to put some belly in the sail. 15 mph winds get a taut foot from a lower sprit angle with the snotter pulled tight enough to force a little bend in the mast to flatten the sail, which depowers it. It's all about manipulating variables.
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 8:23 am
It controls the leech tension on the sail
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 8:53 am
by Doc_Dyer
Thanks y'all
That pic helps a lot Larry,
Now I see, but still don't see why the snotter would move
More tension on spirit making it taller would control the leech would it not????
Thanks for taking the time to teach a land lubber
Do I need a piece of wood at the foot? (what I call a boom)
Bradley
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 10:06 am
Yes, but the snotter is what tensions the sprit, therefore it has to be adjustable. Sailing to windward you want the sail tight and flat, sailing off the wind you want to set it fuller with more bag in it.
From Wikipedia, the free encyclopedia
Jump to: navigation, search
A snotter is a rope or tackle used in sailing to tension the sprit on a spritsail, or a sprit boom on a sprit-boomed sail.
Yep, the rest of us call it a boom too. It can be rigged either way. Without the boom it's called a loose footed sail. The advantage is simplicity and no boom to smack you in the head. A boom will make it sail much more efficiently, allowing better control of foot tension and sail trim, especially to windward. If it were mine I'd use a boom. The sail needs to be designed for one or the other, it will be cut differently for each method.
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 10:22 am
by gk108
If you stick with the original sail plan, there's no need for a boom since the sheeting angle will be almost perfect. You'll probably want to dial in the length of the horse while reaching and running. That will help get the best sheeting angle for those points of sail. When close hauled it will have about the same (almost perfect) sheet angle no matter what the length of the horse is, within reason of course.
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 12:01 pm
by Doc_Dyer
So the spirit is not adjustable on the go?
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 2:28 pm
by ks8
You can make it adjustable from your sailing position by running the line to a cleat at the helm. Bring it down to a turning block on the mast partner and then run it aft to the helm. With a rotating mast, you might need to exercise a bit more ingenuity so that the tension on the snotter line to the turning block does not interfere or *bias* the natural rotating forces on the mast. If I'd do this, I would probably run the snotter control line (snot line?) to a cam cleat with a fairlead, and tie a stopper knot in the line. Then, if it gets away from you, it won't come completely undone as it will be stopped at the fairlead. Lots of options. Enjoy!
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 5:30 pm
Yes, it needs to be adjustable on the go. I done told you it should be adjustable, that means while you are sailing
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 6:54 pm
by Doc_Dyer
Yea I remember
But I was confused
Y'all said snotter should be adjustable
Snotter is rope thingy on mast
My big ass caint adjust that moving
Through the water
That's why I was confused
Re: Doc_Dyer's V10
Posted: Sat Mar 12, 2011 8:00 pm
by AussieBoater
Doc_Dyer wrote:Yea I remember
But I was confused
Through the water
That and the fact KS seems to be using a different language...
Re: Doc_Dyer's V10
Posted: Sun Mar 13, 2011 9:24 am
I noticed that too
That's redundant, the snotter is the line that controls the sprit. It's just called a snotter, like a sheet is a sheet and a halyard is a halyard and a guy is a guy.
Through the water
Well, you cain't go ashore every time you need to adjust the sails, that just ain't practical
Therefore you run the line to where you can reach it from the cockpit
Re: Doc_Dyer's V10
Posted: Sun Mar 13, 2011 9:36 am
by Doc_Dyer
Mornin Cl
I think I found my confusion
The snotter BLOCK being adjustable is the center of my confusion
Why would the block need to be adjusted I know why the snotter needs to move ( to adjust the leech )
But I couldn't understand why the block couldn't be made permanent to mast
That's my final question
Thanks all for the
Re: Doc_Dyer's V10
Posted: Sun Mar 13, 2011 10:55 am
by gk108
You'll probably only need to adjust the snotter block height initially to find the sweet spot. Looking at the book I linked to, full time adjustability for your sail shape is needed for reefing more than anything else. Reefing is not much of an option on the V10. You'll probably still need to put the block on a short pendant of some sort so it can find its own best lead angle under constantly changing conditions of wind direction and speed. Before I came up with the choker type thing I use, I tried a swivel block temporarily clamped up close to the mast and found that it would not behave for me.
Re: Doc_Dyer's V10
Posted: Sun Mar 13, 2011 12:29 pm
by gk108
I don't know if this will help or not, but this is the sail plan from my 1994 edition V10 plans. It shows a 32 sq. ft. sail and the new version should show a 35 sq. ft. sail. In spite of the difference, it's closer than what my rig is for the purposes of this discussion.
Re: Doc_Dyer's V10
Posted: Sun Mar 13, 2011 2:30 pm
by ks8
All this isn't that great a mystery of language, well, usually.
For starters secure your snotter to a cleat on the mast itself. It is very easy and one less complication while simply learning to make the boat get to where you want to go.
As soon as you want to get a little more control of things and try to get a little more speed out of the rig, you could add a turning block and cam cleat later to experiment with that. When you get to that stage, maybe the following will help make that a little more understandable:
A *turning block* simply changes the direction in which a line or sheet or *snotter* is being pulled or directed. One of these could be bolted to the mast partner on the left or right side of the mast *hole* (depending on how you rig the snotter *block* up on the mast). The snotter then comes down from the mast and runs through one of these types of blocks on the mast partner so that the direction of the snotter is then straight back to where you want it to run, to *where you are sitting while sailing* (the helm).
Here's a couple of example of smaller turning blocks that would be plenty for your snotter.
In this picture, it looks like the halyard is run in front of the mast, probably to a cleat that is out of view. Also note the very simple and adequate arrangement of having the snotter cleated directly to the mast.
I saw a photo of another V10 that ran the halyard the same way, in front of the mast, but then ran it under the mast partner and back to a cleat on the mid seat. That allows the skipper to trim (tighten) or ease (loosen) the halyard from the *helm* position without having to get up or move around. Someone may want to do that to adjust sail shape, or drop the main altogether, without having to move around. That other rig (not pictured here) did not have a snotter or sprit, but was a three sided sail. Adjusting sail shape won't be a priority your first few times out. It will be more of a *set it and forget it*. But the day will come when you'll enjoy doing this well. Securing the halyard on a small simple rig, to a cleat on something other than the mast itself, also helps keep the mast in the boat if you turtle. If halyard and snotter are secured to cleats on a free standing mast itself, then what is holding the mast in the boat? Details.
But back to the snotter.... in this picture (above), you see the snotter run down the port side of the mast to a cleat on the port side of the mast itself. What I am here suggesting is that, if you *do* want to adjust the snotter while actually sailing, then instead of running it to a cleat on the mast, you put one of those *turning block* thingies on the mast partner so it *turns* the direction of the snotter back to the helm, where you can cleat it maybe on the mid seat somewhere.
Here is Paul using a different implementation of the same idea on his CK17. He uses two turning blocks on his mast partner. One is for the halyard, and one is for the snotter. The turning blocks allow him to run each to starboard, to cleats. From the cockpit, he could easily adjust halyard and snotter to alter sail shape for strong or light wind, or for whether he is sailing close to the wind, or on a run with the wind at his back, if those were cam cleats. It looks here like they might be conventional cleats, and he just secures those lines and then enjoys sailing without too much adjusting, but it is hard for me to tell in these pictures.
The two cleats on the port side, I'm assuming are the halyard and snotter for the forward mast, since his CK17 is a cat/ketch rig with two masts. I would have used a simpler picture, more like your rig, if I had found one quickly, to keep this simpler, but I think you can get the point from these pictures of Paul's CK17 setup.
By using turning blocks and/or fairleads, you can run your snotter to a convenient location for you at the helm. A turning block at the mast partner with have less friction than a simple fairlead. Fairleads are those simple *guides* through which the forward mast halyard and snotter are run in this picture (below), along the inside of the port rail. The *rail* is the top edge of the side of the boat. You might hear a sailboat skipper say that he *dipped the rail* and *shipped some sea*.
What I am suggesting for you for your snotter is the same thing, except instead of running the snotter to port or starboard along the mast partner, like Paul did (he did that because he has two of them), you instead mount the turning block so you can run the snotter straight back to your helm, to a cleat. I like cam cleats for any sheet or line that is going to be adjusted often.
In my larger cockpit CV16 with bench seating, I have two cam cleats on either side, depending on where the helmsman in sitting (which way the boat is heeling), for easy securing of the main sheet and jib sheet, also easily released (small boat... big gust... ker-splash)! I have simple, but strong fairleads for the jib sheets on the rails (seen here also), and the friction through them, instead of through blocks, is acceptable for me, and simpler.
You probably could just use a properly rated fairlead to *turn* the snotter back to the helm, but a proper turning block will have a smoother feel while adjusting the snotter, and is designed to better handle a 90° *vertical* load through its mounting.
If your mast will NOT be able to rotate, ignore this final paragraph completely. I meant that. Ignore the following if your mast will NOT rotate during normal sailing. --- Yes, I must add this final note, so it will be even easier for some to say I'm complicating this too much.
Your mast, if it is round, may twist or rotate in the mast step and mast partner. Some people want that, and make some sort of delrin bearing for the mast step and partner to make it rotate even more freely, because, depending on how they rig things, it can make the sail a *little* more efficient.
If your mast will NOT rotate, you should not be reading this!
If your mast will rotate, hmmm, to make this simple... If you do NOT rig the snotter block directly to the mast... ignore all this, since the arrangement gk108 spoke of has some slack with which the sprit can somewhat find its *happy place* on either tack. But, if you rig your snotter block on the mast itself so that it is not free floating on the end of a pendant, then if it is mounted on the left (port) side of the mast, mount your turning block on the left (port) side of the mast partner hole. If right side, then right side. In other words,
with the mast position centered (not rotated to the left or right), have the snotter have, as much as possible,
a straight drop down to the turning block, without it twisting around the mast at all. This way, when you tack one way of the other, and the mast rotates one way or the other, the snotter will equally loosen (as the mast centers) and then tighten again on either tack. If the drop is not a straight drop, but twists halfway around the mast to the turning block, when the mast is centered, then, depending on how you rigged it, when you go from one tack to the other, you will either be loosening your snotter automatically as the mast rotates, or, you will put a strain on *things* if the snotter was already very tight, as the mast rotates even tighter to the new tack, and then, *things might happen*. Simply said, in conclusion, to avoid any unplanned strain or *things happening*.... with the mast rotation position *centered*, rig your snotter block (the one on the mast), and the snotter turning block (the one on the mast partner), so that the downward run before the turning block is as straight a vertical drop as possible, without the snotter twisting around the mast at all on its way to the turning block. It becomes more important if you use a very low stretch line for the snotter. Just what might *happen* if you don't do this? Hopefully... nothing...
but it is good rigging practice to so rig things such that loads will be the same on either tack, when possible. A snotter that twists to the other side of the mast on its drop to a turning block, when the rotating mast is centered, will not be balancing snotter loads equally on either tack. And, even if your snotter block is on the end of a pendant (and is not directly mounted to the mast itself), providing as straight a drop as possible to the turning block, when the rotating mast is centered, is still good practice.
It's the rotating mast that suggests considering some of these other sorts of rigging details. That's it, I'm done. Mock away!
Re: Doc_Dyer's V10
Posted: Sun Mar 13, 2011 9:07 pm
Mornin Cl
Good evening
Oh, you're talking about the snotter BLOCK, not the snotter. That's why I was confused
Yes, it can be permanently mounted once it's ideal location is determined. It's just like a halyard block, the location is fixed. Only the line needs adjusting.
Re: Doc_Dyer's V10
Posted: Sun Mar 13, 2011 9:49 pm
by Doc_Dyer
GK108, and Ks8 and you too Larry
This has helped me a lot
Once I got my head outa my ass and realized I was referring to the snotter block
Hopefully I will be rigging soon
Gluing last few pieces of wood this week
Then making her shine
Hopefully to a little better than workboat finish
Bradley
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 9:03 am
Nothing wrong with that explanation
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 10:13 am
by Doc_Dyer
exactly CL
that was a down to earth explanation for the non sailer
ok boat porn
I HAVE MODIFIED THE DESIGN OF THE FRONT SEAT
I decided that I wanted the bench seats like Gk108 did on his V-10
and I wanted the benches to go from bulkhead to bulkhead
the original seat split the forward bulkhead in the middle, I moved the seat forward and built a new bulkhead
also got this in mail today.....fiberglass sleeve for my Ping-Pong ZebraWood Mast
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 11:38 am
by ks8
Did you keep the daggerboard trunk position and just move the seat around it? The position of the daggerboard in relation to the sail is important for the boat to sail well.
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 12:18 pm
by gk108
The frame and DB slot look to be in the right place. Moving the seat forward for the side benches will work well. I spend most of my time half on the thwart seat and half on the bench.
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 12:41 pm
by ks8
So... most = half...
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 12:54 pm
by gk108
Well, I wanted to give a more "cheeky" reference, but...
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 1:28 pm
by Doc_Dyer
yes I didnt move them, just added one forward, I already had everything as per plan till it was time to put seat top on
Bradley
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 1:59 pm
by Aripeka Angler
Looking good Bradley
Have you practice laminated a scrap of that sleeve yet?
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 2:08 pm
by Doc_Dyer
no just got it today,
busy tonight and tomorrow night
may try tonight late.... its killing me sitting here looking at it rolled up
have you tried it yet...or am I going to be the test subject?
Bradley
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 2:29 pm
by Aripeka Angler
I haven't tried it yet.I am still trying to decide how much to stretch the sock when I pull it over the mandrel
I can't wait to see the mast laminated. Are you going to try a teeny piece first on a piece of SCRAP wood?
Re: Doc_Dyer's V10
Posted: Mon Mar 14, 2011 2:34 pm
by Doc_Dyer
no I wasn't but since you mention it I believe ill try it on this first
Re: Doc_Dyer's V10
Posted: Tue Mar 15, 2011 9:02 am
by Doc_Dyer
I believe that I will order the heat shrink tubing before I do the mast
not as clear as I would like, the cloth is a little heavy for light
will see when I get a heavier coat of epoxy on the trail piece
Re: Doc_Dyer's V10
Posted: Tue Mar 15, 2011 10:17 am
by gk108
The heat shrink will really make the weave lay flat, so that's probably what you need. I didn't read well enough to realize that you didn't get some with the glass.
Re: Doc_Dyer's V10
Posted: Tue Mar 15, 2011 12:57 pm
by Aripeka Angler
I was afraid of that, that was why I was nudging you to do a test. Do you think you could stretch a 1.5" sleeve over the mast? Maybe try that and do the heat shrink too
This is new to me too, but I am learning from you
Are you using Silvertip?
Re: Doc_Dyer's V10
Posted: Tue Mar 15, 2011 1:01 pm
by Doc_Dyer
yes that is silvertip
dont think I could stretch 1.5"
ordered heat shrink today
will try to put more resin on tonight to see if the wood grain shows better
Re: Doc_Dyer's V10
Posted: Tue Mar 15, 2011 1:10 pm
by Aripeka Angler
Cool, I am sure you will get better results with the heat shrink (based on reading the tutorial a dozen times but with no practical experience
) I think I am ready to give the CF a try now. I am about over hand sanding on the inside of the canoe and ready to try something new
Re: Doc_Dyer's V10
Posted: Tue Mar 15, 2011 1:14 pm
by Doc_Dyer
just ordered 20 feet of 1.5"
just to see if it will stretch
we'll see
Re: Doc_Dyer's V10
Posted: Tue Mar 15, 2011 1:19 pm
by Aripeka Angler
Extra cool
A 6 pack says it will work
Maybe grind a really smooth taper on the tip of the mast so the sleeve doesn't snag when you are pulling it over the wood. You can always trim the mast off square again after it cures...
Re: Doc_Dyer's V10
Posted: Tue Mar 15, 2011 9:09 pm
by cape man
lightly sand it and fill the weave and I think the wood will pop out. The visible weave is hiding it.
Re: Doc_Dyer's V10
Posted: Wed Mar 16, 2011 10:32 am
by ks8
You might also have *index of refraction* stuff going on with the glass epoxy buildup over the wood. Hopefully the grain patterns will still do their thing once all is flat and glossy. Looking forward to your results.
Re: Doc_Dyer's V10
Posted: Mon Mar 21, 2011 4:00 pm
by Doc_Dyer
well UPS didnt leave my package friday so NO mast work.
I did however manage to put in the new bulkhead/frame and get it cleated and taped
made template for seat top and cut out and bottom glassed
marked template for 2 more round hatches for storage/ floatation
Porn
Re: Doc_Dyer's V10
Posted: Mon Apr 04, 2011 9:24 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon Apr 04, 2011 9:28 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon Apr 04, 2011 10:33 am
by Aripeka Angler
You are not me messing around
Fast, but very nice work too!!
I am curious, do you have a game plan for building the sail yet?
Re: Doc_Dyer's V10
Posted: Mon Apr 04, 2011 10:45 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 11:07 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 1:31 pm
by Doc_Dyer
Birthday Present from my Parents ( Thanks )
Bradley
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 2:08 pm
Good present
Happy birthday
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 2:10 pm
by Prarie Dog
Real nice looking work Bradley.
Curious, why would a fly fisherman build a sail boat?
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 2:14 pm
I think because his wife would rather go sailing
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 2:27 pm
by Doc_Dyer
you are correct Larry
and I need a fishing boat for my river notice this?
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 2:28 pm
by Doc_Dyer
Cracker Larry wrote:Good present
Happy birthday
Thanks Larry,
Boca is getting closer...
when is the Cobia run in you area?
I can feel a flyfishing trip in my future
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 2:50 pm
by Prarie Dog
Cracker Larry wrote:I think because his wife would rather go sailing
Funny how that works.
With the kicker she should be a good river fishing boat.
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 2:58 pm
Cobia run inshore should start within the next 2-3 weeks. We caught a dozen whiting a few days ago in Broad River, along with some nice crabs. The cobia are usually right behind them. No catches reported yet but soon come, I hope. I'll let you know when they show up. Last years run was just a trickle, maybe this year will be back to normal
Water is warming early this spring. Redfishing is generally good, hit and miss with the weather, one day we catch 5 and the next day 75. Ya never know
Trout and flounder ain't doing much yet, but that will soon pick up too. Plenty of sharks if you're just looking for a fight
Come on down, I'll take you fishing for your birthday. Be glad to have yall
I'd recommend live whiting and crab for cobia bait on the flyrod though, and live shrimp, or pogies for the redfish, trout and flounder. Same recommendation I made to Steve and Leroy. Dang purists
Some people are perfectly satisfied in pursuit of fish, but me, I like to put meat on the hook and fish in the boat
If you want to wave those feathers around in the air, it's OK with me
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 7:10 pm
by ks8
My Merc 4hp 4 stroke is plenty for the CV16, a very heavy CV16
. That 3.3 is, I'm guessing half the weight. Yep, that'll do and then some! Guesstimate you'll never need to run it up past half throttle. Experiment with angles of heel, even when not sailing. You may get another couple tenths of a knot out of the hull. I'm actually considering changing props to get better fuel efficiency. Motoring for 8 hours at 5 knots+, I'm burning almost two gallons for the day. I think I can bring that down a bit.
Once the V10 is launched, let us know what you burn for a full day out fishing. (following the break-in period first of course)
If that was your birthday present... Happy Birthday!
How much did you beef up the transom to drive the hull with a 3.3? (Concern is also the bumping around in transit on the trailer...)
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 9:02 pm
by Aripeka Angler
Happy birthday again
I love your latest boat pics and the birthday present is really cool
Of the four boats under construction that may be done for the meet, I think yours is a sure bet to be there
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 9:08 pm
by Doc_Dyer
Aripeka Angler wrote: Of the four boats under construction that may be done for the meet, I think yours is a sure bet to be there
COME HELL OR HIGH WATER ......
Brandi Gale Will be there
Re: Doc_Dyer's V10
Posted: Wed Apr 13, 2011 11:34 pm
by gk108
Happy Birthday.
I don't know if you have started buying hardware yet, but
here's something I wish I'd found to go along with my other bronze parts.
Re: Doc_Dyer's V10
Posted: Thu Apr 14, 2011 3:33 pm
by Doc_Dyer
gk108 wrote:Happy Birthday.
yes I bought the hardware from Here
didnt like the price...
but it had to be done
didnt get to finish sanding the top I glued down last night due to company
will finish sanding and then tape and glass top tomorrow.
Mast step needs to be finalized and then on to bench seats, and rudder and daggerboard
Re: Doc_Dyer's V10
Posted: Fri Apr 15, 2011 9:02 pm
by Joe H
Happy Birthday, can't wait to see her in Boca, you can do it!
Joe H
Re: Doc_Dyer's V10
Posted: Fri Apr 15, 2011 9:14 pm
by wegcagle
Solid work Doc. This is one beautiful little sailboat/flyfishing boat
Will
Re: Doc_Dyer's V10
Posted: Mon Apr 18, 2011 9:28 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon Apr 18, 2011 9:55 am
by Doc_Dyer
ok so I decided to build my Spirit Boom ( or whatever its called )
it is made of 1/4" x 5/8" x 7'5" of Ping Pong ZebraWood ( Lacewood )
it is 1 1/2" tapered to 1" on the ends.... birdsmouth
I cut the ppzw into strips then used the birdsmouth router bit to make "V" cuts into one side, then needed to taper them
so I built a jig to hold all the strips, there are 9 (one extra)
it is flush in the middle and raised 1/4" on the end
I then took a belt sander and sanded till the jig was polished meaning that the wood was flush
weighed it this morning after shaping and first coat of epoxy.
2 lbs 1 oz
Re: Doc_Dyer's V10
Posted: Mon Apr 18, 2011 10:02 am
by SmokyMountain
That's nice
!! Love that taper. This boat will be to pretty to sail!!
Re: Doc_Dyer's V10
Posted: Mon Apr 18, 2011 10:34 am
First class Bradley
That carpenter work is out of my league.
Re: Doc_Dyer's V10
Posted: Mon Apr 18, 2011 6:10 pm
by gk108
Nice work, especially the tapering jig. Your method makes a nice transition from straight to taper, no abrupt angle.
2 lbs 1 oz
Worth every bit of the effort.
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 8:31 am
by Doc_Dyer
ignore the finger in the photo, she took another pic without the finger, but I wasnt smiling
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 10:33 am
by cape man
Wow...are you smiling in that picture?
Looking good! Can't wait to see her on the water at Boca.
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 10:57 am
by Aripeka Angler
Nice looking work Bradley
Maybe I could build my cf mandrel with your technology?
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 11:27 am
by Prarie Dog
Bradley, that's some first class looking work. Real advanced wood working I wouldn't even attempt. I was going to try to get you to give me a flyfishing lesson down at the Texas Builders Meet but looking at your pic, I don't know if my GF18 will float with both of us on it.
Larry is right, you are a large fellow
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 11:36 am
by SmokyMountain
That looks great, can't wait to see her healed over in the surf
... but that's not much of a smile...
Prarie Dog, If Bradley can't give lessons, I can... I should be a little lighter by August
I'm only about 5 lbs now..
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 11:38 am
by Doc_Dyer
SmokyMountain wrote: I'm only about 5 lbs now..
that is just your poker ego
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 11:58 am
by Prarie Dog
SmokyMountain wrote:Prarie Dog, If Bradley can't give lessons, I can... I should be a little lighter by August
I was jokin guys.
My GF18 will float fine with three or four large people in it. As a matter of fact I ran a speed test with appx. 750 lbs of people, a full baitwell and full of fuel and it would still run 28mph. The cockpit won't self drain but no problem. I'll put one of you guys on the front deck, one on the back and I'll sit and watch, hope I don't need a helmet.
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 12:51 pm
by Aripeka Angler
You won't need a helmet Paul, I have seen "em in action
Doc is good enough to probably floss your teeth on the backcast without even hooking a gum...
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 12:59 pm
by SmokyMountain
I meant only 5 pounds lighter than Bradley..
Re: Doc_Dyer's V10
by Doc_Dyer
it also helps that Andrew is left handed and I being right handed, just put the boat floating the right way and we are good
however if you have the boat the wrong way EVERYONE needs to duck
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 1:01 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 1:03 pm
Andy ain't no little fellow either
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 1:04 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 1:08 pm
by SmokyMountain
That's the truth
!! but tring to get smaller. ....
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 1:12 pm
Yeah, I've watched them myself. I'll second that
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 1:20 pm
by ks8
Real nice job on the sprit.
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 1:38 pm
by Doc_Dyer
thanks, the ends are not coated yet due to the rollers
only one light coat of epoxy on spirit, will finish with a couple of light coats of epoxy then varnish
that will be a few weeks, one of the last things to do..
I do have a question tho,
the spirit attachment to the sail is just a sewn loop of sail material
what do I need to put on the end of the spirit to attach to sail?
a j hook of some sort, rope? zip tie?.....etc?
I was thinking of inserting a piece of Ash into the end and epoxy, then drill for a eyebolt or something
Bradley
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 3:27 pm
by gk108
The simplest way would be a spike straight out of the end, similar to the one in the lower picture
here. That's assuming that there is a brass grommet on the sail. Without a grommet, a softer method may need to be considered. Let me know if you want to go with the spike. I have some 3/8" fiberglass rod I can send you.
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 3:45 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Tue Apr 19, 2011 4:02 pm
by gk108
Got a close-up pix?
Re: Doc_Dyer's V10
Posted: Wed Apr 20, 2011 12:52 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Apr 20, 2011 1:37 pm
by sitandfish
That loop slips over a button (or spike or tapered point) at the end of the sprit.
If the sprit is blunt at the end you can lash it. Requires drilling a hole at the tip of the sprit to pass the lashing.
Re: Doc_Dyer's V10
Posted: Wed Apr 20, 2011 1:40 pm
I agree.
Re: Doc_Dyer's V10
by sitandfish
Here is another version showing the same loop as yours. Picture is too big to post so here is the link.
http://www.cautionwater.com/uploads/Rig ... ing-11.jpg
Re: Doc_Dyer's V10
Posted: Wed Apr 20, 2011 10:08 pm
by gk108
Cracker Larry wrote:That loop slips over a button (or spike or tapered point) at the end of the sprit.
I agree.
Yep.
Re: Doc_Dyer's V10
Posted: Wed Apr 27, 2011 3:21 pm
by Doc_Dyer
first coat
Re: Doc_Dyer's V10
Posted: Wed Apr 27, 2011 4:33 pm
by tech_support
is that the sterling primer?
Re: Doc_Dyer's V10
Posted: Wed Apr 27, 2011 4:41 pm
by Doc_Dyer
no silvertip high build
why did i do something wrong?
Re: Doc_Dyer's V10
Posted: Wed Apr 27, 2011 4:45 pm
by tech_support
Im afraid it will need to be sanded off............
Just kidding
Looks fine to me. It just looks almost white in color, the sterling finish primer is white. must be the picture.
Re: Doc_Dyer's V10
Posted: Thu Apr 28, 2011 10:58 am
by gk108
That white look is probably the 'auto white balance' feature of the camera. It decides that the lightest shade in the picture is white and adjusts the whole color balance based on that. Since there's no actual white in that picture, the camera assumed a few things for you and white looking primer is the result in the picture. It's OK, you won't have to sand all of it off. You can stop when you only have most of it sanded off.
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 3:42 pm
by Doc_Dyer
agrrggghhhh
Im tired of looking at the interoir
running out of time
still have to seal dagger board box top and bottom,
graphite bottom boat
build the rudder
build the dagger board
build the ping pong zebra wood bench seats
couple more coats of epoxy on masts, then varnish
paint boat
wow
only 4 weekends left to do it all
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 3:51 pm
by cape man
Go Baby Go!
If you run out of time use one of these and get a coat of paint on quick!
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 3:59 pm
by ks8
I still haven't painted over much of the primer in the CV16 interior, but been using it for a few years now.
If all you want is a launchable V10, you're almost there! I made sure the outside priming and painting was done, and the inside at least primed, and 4200 on any through hull hardware that would be close to the waterline or under it, before the first splash. No regrets.
Go for a good seal on all surfaces, and the necessary appendages also sealed, and have a blast launching and sailing, even if it isn't painted all proper by Boca. This gave me a kick to do some painting this month too.
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 5:15 pm
by Doc_Dyer
no she WILL be done for BOCA
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 6:35 pm
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 7:18 pm
by cape man
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 8:03 pm
by ks8
I won't hold you to any particular definition of *done*...
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 8:11 pm
by Aripeka Angler
I'm expecting perfection, anything less will be a unacceptable
Looking very nice Doc...
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 8:21 pm
by ks8
perfection = meeting the requirements of what it needs to be. Ambiguity is in the mind of the reader.
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 9:06 pm
by Aripeka Angler
ks8 wrote:perfection = meeting the requirements of what it needs to be. Ambiguity is in the mind of the reader.
I was poking fun because of some words of wisdom I got via text today
Perfection is unachievable. Good is good
I say let good be good enough, you are way past that Doc
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 9:09 pm
by gstanfield
...only 4 weekends left to do it all
Don't limit yourself to weekends, quit your job if necessary, but the boat takes top priority at this point in the game
Re: Doc_Dyer's V10
Posted: Tue May 03, 2011 9:44 pm
by Prarie Dog
Looking real nice Doc. I usually get flak for asking questions like this, but could you explain what "ping pong zebra wood" is. I don't have a clue. I've already been chided, whipped and beaten over terms like SWMBO and Kitchen Pass so if I have to take another beating over this new term. I'm ready.
Thanks, Paul
Re: Doc_Dyer's V10
Posted: Wed May 04, 2011 8:45 am
by Doc_Dyer
Aripeka Angler wrote:Doc_Dyer wrote:I would love to use Spruce or douglas fir,
Here you go Prarie Dog,
it is a joke between me and Richard, it all started in the above quote, and I have been referring Lacewood as Ping-Pong Zebrawood ever since
Thanks all,
Bradley
Re: Doc_Dyer's V10
Posted: Wed May 04, 2011 10:03 am
by Prarie Dog
Cool, thanks for clearing that up.
Re: Doc_Dyer's V10
Posted: Thu May 12, 2011 9:11 am
by Doc_Dyer
just for the record...
i hope to be ready for Boca
Re: Doc_Dyer's V10
Posted: Thu May 12, 2011 9:52 am
Re: Doc_Dyer's V10
Posted: Thu May 12, 2011 9:58 am
by Doc_Dyer
I could be wrong
just a hunch but I have a lot of work to do in 21 days
Re: Doc_Dyer's V10
Posted: Thu May 12, 2011 10:02 am
I had one too. Yall notice how quiet and pleasant things have been around here lately?
Re: Doc_Dyer's V10
Posted: Thu May 12, 2011 10:12 am
by Aripeka Angler
You'll get it done Brad
Re: Doc_Dyer's V10
Posted: Thu May 12, 2011 10:28 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Thu May 12, 2011 1:08 pm
by SmokyMountain
Lookin good...go go go go!!!
Re: Doc_Dyer's V10
Posted: Fri May 13, 2011 10:06 am
Nice job Bradley
You might make it if you don't stop to tie flies.
Your BS detector works as well as mine
Re: Doc_Dyer's V10
Posted: Fri May 13, 2011 5:42 pm
by Doc_Dyer
Cracker Larry wrote:Nice job Bradley
Thanks, yea it's a fine tuned machine
My line of work allows for some great time To tie flies
Numb wait 10-15 min go tie a fly
Bradley
Re: Doc_Dyer's V10
Posted: Fri May 13, 2011 8:38 pm
by cape man
I hope you're ready already! Now the boat making it may be something different! But don't sweat it. She'll be done when she is.
Re: Doc_Dyer's V10
Posted: Fri May 13, 2011 11:16 pm
by Doc_Dyer
Ohh, I'm ready
This is going to be a GREAT meet
boat will be there,
As to the completeness,
we will see
Bradley
Re: Doc_Dyer's V10
Posted: Sat May 14, 2011 1:04 pm
by ks8
For the sake of a launch, aim at having the final primer get a good solid week of cure before she hits the water. Even if fairing isn't finished and hardware isn't all installed, with a well cured seal of primer, she's at least safe to get wet.
All my hatches aren't finished yet (almost), so for now, if I'm out on a day or night when it may rain, I've got clear packing tape over them to make a water and splash proof barrier. Works great. It's rainy today. After some paperwork, I think I'll go work on some hatches ...
Re: Doc_Dyer's V10
Posted: Tue May 17, 2011 10:56 am
by Doc_Dyer
wow, boat sides look like shat
after first coat of primer, AND have meeting to go to tonight so may not get faring done till tomorrow
which means that have to paint next wed and let it dry for a week, for her splash in boca
Nothing like a little pressure to get the ball rolling
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 9:30 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 9:31 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 10:15 am
by cape man
I like the pictures in your new gallery! Sucks to have lost all the others, but those sure look sweet now. Soon...very soon. She's begging for water at this point.
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 10:36 am
Well for those who dont know this
your entire gallery can be gone in one click of the mouse
I could have told ya how easy it was
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 12:35 pm
by ks8
I better be careful!
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 4:43 pm
by Doc_Dyer
well worked all day on my gallery,
have all but the first 4 pages done on the V-10
then on to the FL-14 pics..
did I mention this SUCKS
no ties flied today
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 5:00 pm
by wegcagle
Nice progress. (Sucks about your gallery
I don't think I'd have the patience to put them all back in) You're gonna have her done for Boca yet
Will
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 5:42 pm
I hear you, I feel your pain, but it ain't nothing but a thing
no ties flied today
Dang Doc, don't get so stressed. If you ain't got no ties flied when you get to Boca Grande, I plan on catching us some live bait first thing. I'm gonna use some real shrimp, to catch some real pinfish, and then plan to use those for bigger and better things. So don't worry about flying the ties, you only got a week, no time for that
Focus on the important
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 7:13 pm
by Joe H
Yeah, me too, it sucks.
Joe H
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 7:28 pm
by ks8
Really, don't even worry about the gallery stuff. Unless you're waiting for paint to dry anyway...
This looks sweet!
1888
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 10:02 pm
by Aripeka Angler
Man that graphite turned out good! You were worrying for nothing. And, you will replace those lost pics with even better ones
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 10:15 pm
by cape man
That is one pretty bottom! Wow! Great job.
Re: Doc_Dyer's V10
Posted: Mon May 23, 2011 11:13 pm
by Doc_Dyer
Thanks everyone
Wondering how much other V-10's weigh
This thing is HEAVY
So much it has me wondering if she will float
Will put her in the river before I paint her, no cents
putting 400 worth of sterling if she floats at the gunnels
Re: Doc_Dyer's V10
Posted: Tue May 24, 2011 7:23 pm
by gk108
I never did get around to weighing mine. I'll see if I can take it over to Clem's bait shop and hang it from the deer scales. My wild guess for now is right around 100 lbs. for the bare hull but I could be wrong.
Re: Doc_Dyer's V10
Posted: Tue May 24, 2011 8:00 pm
by ks8
Doc_Dyer wrote:Wondering how much other V-10's weigh
This thing is HEAVY
I've got to alert the US Geological Survey every time I move my CV16. But she sure has a comfortable ride as regards motion.
Re: Doc_Dyer's V10
Posted: Tue May 24, 2011 10:13 pm
by Doc_Dyer
gk108 wrote:I never did get around to weighing mine. I'll see if I can take it over to Clem's bait shop and hang it from the deer scales. My wild guess for now is right around 100 lbs. for the bare hull but I could be wrong.
WOW mine is twice that she is HEAVY
Did you use meranti?
Re: Doc_Dyer's V10
Posted: Tue May 24, 2011 10:14 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed May 25, 2011 8:44 am
by Doc_Dyer
well she has her first coat on
Re: Doc_Dyer's V10
Posted: Wed May 25, 2011 8:59 am
by gk108
I used meranti for the frames and okoume for the ¼" parts. I can see a few extra pounds on yours from the foam and extra dividers for it, but that's about it. Like I said, mine is a wild guess.
That blue looks good!
Re: Doc_Dyer's V10
Posted: Wed May 25, 2011 10:17 am
by tech_support
that is pretty good coverage for one coat
Re: Doc_Dyer's V10
Posted: Wed May 25, 2011 1:01 pm
by JGB
The blue looks good. What type of paint is it?
Re: Doc_Dyer's V10
Posted: Wed May 25, 2011 1:47 pm
by Doc_Dyer
interlux brightside I believe
had a can sitting at the house thought I would give it a try.
Im not happy with my faring, but ran out of time. one week today leaving for florida
so this fall I will sand down and paint with sterling
Bradley
Re: Doc_Dyer's V10
Posted: Wed May 25, 2011 7:28 pm
by gk108
Did I mention that I was making a wild guess about the weight of my V10?
155 lbs for my empty hull.
Re: Doc_Dyer's V10
Posted: Wed May 25, 2011 9:53 pm
by cape man
Go Baby Go!!!
Re: Doc_Dyer's V10
Posted: Thu May 26, 2011 8:56 am
by topwater
Looking good Doc
I like the the blue paint, you could name it Blew-By-You .
Re: Doc_Dyer's V10
Posted: Thu May 26, 2011 10:28 am
by Doc_Dyer
topwater wrote:Looking good Doc
yea, but I already named her "Brandi Gale" after my wife
VERY unhappy with my faring of the exterior
she has 2 coats of paint on her but will be sanded back down after the summer
hopefully I did a better job on the interior
Re: Doc_Dyer's V10
Posted: Thu May 26, 2011 10:44 am
by ks8
She'll float... and she'll sail.
Re: Doc_Dyer's V10
Posted: Fri May 27, 2011 11:57 am
by cali123
Dont beat yourself up. You might see some minor flaws but the picture shows really good work overall. I have worked with many auto body repair techs.,with a dozen years of experience, that could not come close to what you have done. Keep up the good work
Re: Doc_Dyer's V10
Posted: Fri May 27, 2011 3:29 pm
by Doc_Dyer
thanks for the kind words, Cali123
man I ran out of time, but i'm still plugging away
guide coat
first coat, ( I see what you mean now Shine, much thinner than the blue)
Re: Doc_Dyer's V10
Posted: Fri May 27, 2011 4:59 pm
by cape man
Go Baby Go!
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 3:40 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 4:04 pm
by gstanfield
Looking good
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 4:12 pm
Aren't you leaving tomorrow? When are you tying flys
Good thing I've got some fresh caught shrimp in the freezer!
Willie Makeit
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 4:34 pm
by Doc_Dyer
yes, leaving at 4:00 PM driving till we caint drive another mile, crashing at a hotel, getting up and doing it again on thurs
Damn it a LONG way down there
yes, I tied 4 today
willie says Hell YEA.... she aint purdy but she will float
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 4:39 pm
So you and Andy are driving 2 vehicles down?
Betty Dont
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 4:48 pm
by Doc_Dyer
that all depends on if I can fit the V-10 in the bed of the truck with the plastic boat behind in tow
if not then Andrew will tote it on its trailer, and leave his boat home
Betty Dont Myass its Betty Wyll
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 5:13 pm
Both of yall are going to look real funny fly fishing from a V10
Camera, check...
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 5:27 pm
by Doc_Dyer
I believe that me and Andrew COULD flyfish in a V-10,
wouldn't be very comfortable but Im pretty sure we could do it....
maybe a Wager??????
Betty Loosesthatbet
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 5:35 pm
Betty Dont take that bet
That reminds me, poker chips
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 8:49 pm
by Aripeka Angler
Cracker Larry wrote:That reminds me, poker chips
That reminds me too, don't forget the onions
I got the limes....
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 10:17 pm
by cape man
You're an animal!
Re: Doc_Dyer's V10
Posted: Tue May 31, 2011 11:25 pm
by Doc_Dyer
DONE and loaded up
Wow Betty sleepsgood tonight
Nothing like procrastination
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 5:38 am
by stickystuff
Loading up RV today and heading out in the morning. Looking forward to seeing the old and the new.Andrew, flyrod will be packed .. Looking for some good tutering from you hillbillies. GO VOLS>
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 7:02 am
by SmokyMountain
Mine are packed too.
Excellent!!
I'll do my best. Looking forward to a great weekend!!
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 8:57 am
Andy, if you've got chips packed, I'll leave mine home
See yall tomorrow, I'm loading and leaving now.
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 9:55 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 10:31 am
by gk108
She looks great on the water!
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 12:01 pm
by gstanfield
Congrats on the splash, nice looking patch of water there too
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 12:50 pm
by ks8
Congratulations on the splash!
Pictures under sail from Boca?
Looks at home on the water.
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 12:52 pm
by Doc_Dyer
yes, im sure CL, or Richard, or any of the bunch of people there will get a pic of her under sail,
still have some rigging to do, but I figure I can do that there
Bradley
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 1:50 pm
by cape man
Can't wait to see her in person! Congrats!
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 2:28 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 2:48 pm
by Prarie Dog
Good job Doc.
She looks real good and fairly fast with the outboard. How heavy is she?
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 2:52 pm
by gstanfield
Very nice back yard. I see you put a 4BT in your jeep, sweet conversion. When I get in the new house and get settled in I'm probably doing a 4BT swap into my Sport Trac. Always did like those engines
Re: Doc_Dyer's V10
Posted: Wed Jun 01, 2011 5:53 pm
by peter-curacao
Doc_Dyer wrote:gstanfield wrote:, nice looking patch of water there too
yea thats my back yard
lucky bastard
Re: Doc_Dyer's V10
Posted: Thu Jun 02, 2011 12:44 am
by Doc_Dyer
Peter,
Uhhh don't you live on a carribean island
Well me and smokymountain made it to lake city Florida
Only 5 more hours on the road tomorrow
Re: Doc_Dyer's V10
Posted: Thu Jun 02, 2011 1:34 am
by cali123
Looking good.
Re: Doc_Dyer's V10
Posted: Thu Jun 02, 2011 6:53 am
by majorgator
You should have rode another half-hour to Gator Country. If you get on the road this morning and you need breakfast, stop in at exit 382 (Williston Road) in Gainesville, and directly across from the exit ramp is 43rd Street Deli. Its not too shabby.
seth
Re: Doc_Dyer's V10
Posted: Tue Jun 07, 2011 9:01 am
Pics documenting the first sail of the Brandi-Gale are posted at
http://forums.bateau2.com/viewtopic.php ... 98#p248798
Great job Bradley
Re: Doc_Dyer's V10
Posted: Tue Jun 14, 2011 5:31 pm
So Bradley, or is that TWH, we want to hear a sailing report and see some pics of yalls trip to the panhandle
Re: Doc_Dyer's V10
Posted: Tue Jun 14, 2011 6:51 pm
by Prarie Dog
I want to see pics of that bad boy in the Everglades Challenge.
Re: Doc_Dyer's V10
Posted: Tue Jun 14, 2011 7:11 pm
by peter-curacao
Prarie Dog wrote:I want to see pics of that bad boy in the Everglades Challenge.
I want to see pics of those bikini girls in Boca Grande
Re: Doc_Dyer's V10
Posted: Tue Jun 14, 2011 8:11 pm
by gstanfield
Me too Peter, me too
Re: Doc_Dyer's V10
Posted: Tue Jun 14, 2011 11:26 pm
by Doc_Dyer
peter-curacao wrote:Prarie Dog wrote:I want to see pics of that bad boy in the Everglades Challenge.
Peter,
me and Andrew would have liked to see the bikini's also, but we didnt make it out to the pass
BUT....
Just about all I saw was under the cowl of my motor...DRAINING my fuel filter of WATER....over and over and over and over..
as far as the TWH comment ...
ok back to boat building...
sailing report.....
My V-10 is UNSINKABLE
you all know that im not a small guy
well my nephew is almost as big as me.
I had some sand on the curved bow, so I think well Ill just push it under the water and wash it.....NOT
me and my nephew both on either side of the bow could not push it under enough to wash the damn thing off
I intentionally swamped the boat in the surf.... even with my weight pushing the boat under i could not fill the boat to the gunnels, there was still 8" of boat above water. I got in and she sailed full of water
now for the sailing report
she will NOT sail into the wind, she will sail perpendicular out and back but she will not go into the wind.
she gets pushed sideways...
possible fixes I have thought of
... larger rudder or and lower rudder a couple of inches.
....Longer daggerboard
NOW this could be do to my sailing ability but I think not
Now this is still an awesome boat and would recommend to anyone.
Discaimer..... I know that this is a DIngy and not a dedicated sailboat
but I would like it to at least go a little into the wind
I will try to get some pics, If the V-10 was sailing, by me or my nephew or Andrew, I was in the water.
my sister got some pics of us sailing, I will try to get them
Bradley
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 9:41 am
I think the problem is probably more related to sail trim and position. Even an optimist pram goes to windward fairly well. To sail into the wind, the sail must be trimmed almost flat. You have to tighten the halyard, downhaul or snotter line to get the leading edge tight, and typically you would tighten the outhaul to get the foot of the sail tight. Since you don't have a boom and are sailing it loose footed, the sail is carrying a big belly in it, therefore the lift it is generating is to the side, rather than forward. The sail is just like the wing of a plane and must form the correct airfoil shape to generate lift in the required direction. It needs to be stretched almost flat to go to windward, release the tensions to sail downwind. It also needs to be trimmed to the center line of the boat, and with the loose footed sail that is hard to accomplish.
The other consideration is sail positioning fore and aft. Center of effort versus center of lateral resistance. Using a sailboard (windsurfer) as an example, it does not even have a rudder. It is steered only by tilting the sail forward or back. If you lean the sail forward, the boat turns downwind. If you lean the sail back, the boat heads upwind. Just like a weather vane. Same with your boat, or any boat. You can tie the rudder amidships and steer the boat just by tilting the mast. Racing sailboats have adjustable fore stays and back stays. When going to windward they slacken the fore stay and tighten the back stay, and reverse it for sailing off the wind. No amount of rudder or centerboard can overcome the weather vane effect. If the mast is too far forward, the boat will never go to windward.
I would think about doing 2 things, add a boom so you can tension the foot and trim the sail to the center line of the boat. And try to figure how to lean that mast back a little bit. Maybe a slot through the partner, rather than a round hole, with a wedge to hold it in position. Or maybe another hole. If you can get that sail flat and tight, trimmed to the center line, and the mast back just a little, she will go to windward.
See this
http://www.northsailsod.com/class/optim ... uning.html
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 1:04 pm
by Doc_Dyer
thanks, Larry
the sail is VERY tight and on the centerline, there is NO slack in the sail at all, I actually pull on the sheet before the ring that goes from knee to knee, (sorry for non sailing lingo) while pulling the other end, I can make the sail VERY tight and on the centerline
I will try to move the mast, I was planning on putting a ring on top of the partner anyway, because of the scratches from the
spirit boom, when you take the sail down, I will enlarge the hole and try to move the mast aft.
OR I could tow it to Cylo and see what a Master sailor can do with her
maybe even get to fish off of NO EXCUSE for some reds
Bradley
edit, one of the reasons for the enlarged rudder comment is when sailing windward, the rudder is a about 30 degrees and of little effect
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 1:47 pm
by PJPiercey
One correction in regards to sailing into the wind. If the wind is light, you do NOT want a "flat" sail. Ease off on the snotter. You can even ease off on the halyard. Don't sheet in on the main sheet too tightly. The end of your boom should be pointing outside of the stern corner of the boat. Now, sail across the wind and slowly start heading up closer to the wind. When you see the leading edge of the mainsail starting to "luff", (the part of the sail directly behind the mast), head just a little bit down wind and the sail should fill back in along the luff. Then, head back up wind just a little bit until you can just barely detect the sail starting to luff. Now, sheet in just a couple of inches and see if the boat can sail into the wind a little more. Don't expect the boat to sail as fast into the wind as it does across the wind.
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 3:41 pm
by ks8
The slower the boat is moving forward, the less effective the rudder becomes. Bear away to get a little more speed, then nudge your way upwind bit by bit doing the sail trim recommendations. If the rudder seems to be ineffective through 30°, you may be too slow for its effectiveness and possibly have stalled it. It too is a wing. With a GPS, you can better determine at what speed the rudder begins to stall when you throw it over too far, or, basically, have positioned it with too great an angle of attack in relation to the water flowing over it. These boats are not like the high performance virtual boats in the virtual regatta game. You will not get full hullspeed when sailing 50° into the wind, but I'm thinking the V10 can be coaxed up 50°, maybe more, at perhaps half your *reaching* (90° to the wind) top speed. The rudder needs a proper flow of water over it to work properly. Unlike with a tillered engine, you can't force the boat to turn as hard as you'd like with a rudder, if you haven't sufficient water flow over the rudder from leading edge to trailing edge. The rudder, like the sail, is a *wing*, and not just a board sticking down in the water. It needs water flowing over it from leading edge to trailing edge, at a sufficient speed, for it to do its thing most effectively. Same thing for the Daggerboard. If you try to *force* the boat to windward when it is barely moving forward, things get gushy and don't respond *alive*. If you do manage to get the boat headed straight into the wind, with not enough speed on the boat to make it through to a proper close hauled course, you may get *stuck in irons*, with the mains'l luffing straight into the wind, an ineffective rudder, and maybe even starting to blow backwards (which if you are not careful may break something about the rudder if its too big). If you do get stuck *in irons*, you don't want things trimmed to tight as you paddle or otherwise force yourself off the wind more. If it is trimmed to tight as you *bear away* (more away from the wind), the sail may really catch the wind while you are not yet moving forward enough, and give you a swim.
All of this comes together after a few more times out and some *messing about*.
Bear away to get moving about 2.5 or 3 knots, and then *mess about* to slowly trim and head up. Having a gps to give you your speed is very helpful when first getting the feel of it all. Where you position your own weight on different points of sail also plays into getting all things in proper trim. Once you've got it all worked out, you'll barely be conscious of it as it becomes more reflexive and natural, but you can be very conscious of it if you want to, and have a blast squeaking out every tenth of a knot and every degree to windward.
REgarding the sailing terms, ask what something is called as it becomes an issue, and someone is sure to give you the terminology. Enjoy those first weeks of messing about, and remember that you may also need to shift your weight forward or back for different points of sail, to find a sweet spot for weight trim in addition to sail trim. I get an additional two tenths of a knot out of my CV16 by finding just the right spot to sit forward or back in the boat, so the hull form presented to the water is most friction free. With crew along, I ask them to move forward or back slightly while I watch the gps speed. It at first seems odd that sliding forward or back can make that a big a difference, but over time, you and the boat will start communicating with one another with a more subtle language.
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 4:15 pm
by Doc_Dyer
a little more time messing about in her?
I spent multiple times a day, everyday of last week sailing her on the beach with a steady wind coming from the same direction.
although I do not know all the "correct" terminology I have sailed before.
nothing big but I am quite proficient in getting the boat to go where I want.
I have tried everything everyone is suggesting, except changing the angle of the mast.
I am the type of person who doesnt like to fail at anything,
and will spend hours experimenting different things till i figure it out.
and yes i tried building up speed before turning into the wind.... NO EFFECT
and yes I know that you need air or water moving over a surface to make something change direction
thanks everyone for their answers
I apologize for the rant, but the answers, to me seem
that this is the first time on a sailboat, and I am clueless about how to operate the sailboat.
I'll be ok after I get home and have some Flor De Cana
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 4:41 pm
I'll be ok after I get home and have some Flora De Cana
You mean you still have some left over
Craig and I could have taken care of that about 0400 Saturday
If the sail is cut properly, it will still maintain it's airfoil even with the halyard and foot pulled tight. We crank them down with a big ass winch and still maintain shape
The belly is designed into the sail cut. You can never make a good sail "flat" no matter how much you tension it. To windward it needs to be a lot flatter than off the wind, but this doesn't mean flat, just relatively flatter.
30 degrees is not an excessive rudder angle, probably about normal for windward sailing. You have to force a boat to go to windward, it doesn't want to on it's own. It's not called beating for nothing
Since you say you can flatten (relatively speaking) the sail and trim it to the center line, I really think we are back to mast position. CE versus CLR. Let me ask you this, if you are trying to sail to windward and let go of the tiller, does the boat turn itself downwind, or upwind? If you get hit by a stronger gust, does the boat try to turn downwind or upwind. If it turns downwind, that is called lee helm, and the mast is too far forward. Ideal is a slight amount of weather helm, in that if you get a strong gust the boat tries to turn itself into the wind.
That is a good point, with Docs size in a small boat, it will make a big difference. Generally speaking you want the weight aft when sailing off the wind, and more forward sailing to windward.
Anytime Bradley, you know that
I'm booked the first 2 weeks of July, but any other time is good. Got a spare room and No Excuse is always ready to fish. I'll join you in that drink, but must settle for Mount Gay today
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 4:57 pm
by Doc_Dyer
Nope it a new bottle
yup I tried moving my weight all around to get her going upwind thats a lot of weight moving around
just might make a weekend trip down,
I would love to be proven a Dumbass
not really
but if its me i'll man up and say that Im a dumbass and the boat is perfect
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 5:03 pm
Doc, I know you, and I know you ain't no dumb ass. If the boat could go to windward I'm sure you could make it do so. If it won't, there is a problem somewhere.
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 5:29 pm
by Doc_Dyer
Thanks Larry
That means a lot to me
I will get this figured out
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 5:40 pm
by ks8
Apologies for my presumption Doc. I wasn't quite sure what to do with this...
I actually pull on the sheet before the ring that goes from knee to knee, (sorry for non sailing lingo) while pulling the other end...
... and since many new sailors may have this post come up if they do a search on *upwind*, I did aim at answering more generally to a beginner. No offense intended, and apology offered. I've been taking the CV16 out for a few years now... and I'm still a beginner.
Definitely sounds like a plan to see if you've got extreme lee helm. But then, you may know already from those sea trials. Looking forward to how this works out. You built one purdy boat, and I'm sure she will sail well with the rig tweaked, and her capable builder at the helm.
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 5:57 pm
by gk108
Did you try shortening the horse? I noticed the pictures showed it a little longer than I would have it. The change in the sheeting angle that would result will tighten the leech and reduce the twist at the head of the sail.
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 6:12 pm
by Doc_Dyer
gk108 wrote:Did you try shortening the horse? I noticed the pictures showed it a little longer than I would have it. The change in the sheeting angle that would result will tighten the leech and reduce the twist at the head of the sail.
it depends on which picture you are looking at, after the initial launch, I shortened it considerably
after it quits raining ( good for the garden tho ) I will take a recent picture
Bradley
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 6:30 pm
by Doc_Dyer
ks8 wrote:Apologies for my presumption Doc. I wasn't quite sure what to do with this...
I guess since I own a sailboat now, I have to learn the language, to keep from offending the professionals
apology accepted
its all ok it
just struck me odd,
Bradley
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 7:57 pm
That's called the traveler
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 10:03 pm
by SmokyMountain
Not to muddy up the waters, I had the same problem as Bradley tacking up wind with a constant 10-15 knot wind. I used to sail quite a bit as a kid.. I'm no expert and the terminology has mostly been forgotten, but tacking up wind with no luff in the sails and the sail tight she wanted to drift to the side not staying on track and you always had to keep correcting and was a chore. My thought, which is proabaly wrong ,that she is dingy that you can put a sail on, but still a dingy (I'm not talking about anybody wife
) just my 2 cents... Still i had a blasting sailing her and she a fine looking boat!!
Larry,
If I get done this fall, I may have to come down to Beaufort and babtize the Phantom with some salt and redfish slime!!
Andrew
Re: Doc_Dyer's V10
Posted: Wed Jun 15, 2011 11:41 pm
by gk108
I know the boat is capable of going upwind because mine will do it.
Here's a GPS track from last month. SW wind 1-5 mph. A couple of the port tacks were with 1-2 mph wind and the boat didn't point well at all, but it did better when it picked up.
Re: Doc_Dyer's V10
Posted: Thu Jun 16, 2011 12:07 pm
Larry,
Bring it on, Andy
Come down this fall even if it's not finished. Fall is my favorite time for fishing around here.
Re: Doc_Dyer's V10
Posted: Thu Jun 16, 2011 4:00 pm
by PJPiercey
SmokyMountain wrote:tacking up wind with no luff in the sails and the sail tight she wanted to drift to the side not staying on track and you always had to keep correcting and was a chore
Your exactly correct Andrew. You need "draft" in the sail in order to generate the lift necessary to pull a vessel to windward. Most dingy sails do not have a lot of draft, if any, built into them so you have to be careful not to over tighten the sail and eliminate the draft. Also, 30 degrees of weather helm is waaaayyy too much for a dingy.
Re: Doc_Dyer's V10
Posted: Thu Jun 16, 2011 6:02 pm
There is a revelation
I've seen the sail and it is cut with plenty of draft
Re: Doc_Dyer's V10
Posted: Thu Jun 16, 2011 6:52 pm
by PJPiercey
Cracker Larry wrote:You need "draft" in the sail in order to generate the lift necessary to pull a vessel to windward.
We talking about the same sail
Re: Doc_Dyer's V10
Posted: Thu Jun 16, 2011 6:57 pm
by PJPiercey
Proper sail shape:
Re: Doc_Dyer's V10
Posted: Thu Jun 16, 2011 8:46 pm
Yes, there was 1 kt of wind in that picture, it was the maiden voyage. The boat was drifting in the current, it wasn't sailing, Doc was paddling
I was there. The boat you picture is on a broad reach in some wind, it is not sailing to windward, not even close to the same. It is a larger boat, different rig, different point of sail, and it had some wind. That boat also has a boom, it is not loose footed. No way you can match trim with a loose footed sail._
And what would you contructively suggest we do to correct this problem other than to criticize the sailor? Or do you just like to troll behind me like TomW?
Here is Bradley's boat on the same point of sail you picture, in much less wind. The trim is perfect.
Re: Doc_Dyer's V10
Posted: Fri Jun 17, 2011 9:46 am
by ks8
If he hadn't read the SE boater's meet posts on the maiden voyage, I can understand how Paul would make those comments based on that picture alone. Now he has the info from CL, which clears up that picture completely.
peace.
Re: Doc_Dyer's V10
Posted: Fri Jun 17, 2011 11:11 am
by PJPiercey
Behave yourself Larry
My original post:
And my next post:
Larry:
My contructive suggestion to you, Larry, is: Don't be so defensive. Accept contructive suggestions.
Really
That's my daughter sailing, and me riding in, the V12 I built to teach her how to sail. She most definitely is going to windward.
Re: Doc_Dyer's V10
Posted: Fri Jun 17, 2011 11:30 am
I've been sailing long enough to know the difference between a broad reach and a close reach, and a beat. That boat is at best on a beam reach.
Have a good life, PJ. I don't waste mine arguing with jerks.
Re: Doc_Dyer's V10
Posted: Fri Jun 17, 2011 12:43 pm
by Doc_Dyer
PJPiercey wrote:
Larry:
PJ,
nowhere in my thread did I say, can anyone explain to me how to sail my boat into the wind!!!
I dont need instructions on how to sail, and my close friend Larry is also tired of this response
constructive suggestions, would be what I can change on the boat to make it sail better into the wind, ie like Larry, change the angle of the mast. Not telling me how to adjust the sail, based on one picture.
Bradley
Re: Doc_Dyer's V10
Posted: Fri Jun 17, 2011 7:28 pm
by PJPiercey
Bradley,
I fully understand. My responses were to comments that were, IMHO, attempting to tell you how to incorrectly adjust your sail.
Such as:
thanks, Larry the sail is VERY tight and on the centerline, there is NO slack in the sail at all,
Having been a member of this public forum since 2002 I will chime in when I see information that IMHO needs clarification or correction. Not just to help you.
Have fun with the V10!
Re: Doc_Dyer's V10
Posted: Sat Jun 18, 2011 12:58 pm
by majorgator
...know the difference between a broad reach and a close reach, and a beat.
...best on a beam reach.
All this terminology makes me happy to own a an outboard-powered boat
seth
Re: Doc_Dyer's V10
Posted: Sat Jun 18, 2011 1:56 pm
by ks8
got the graphic from here:
http://terrax.org/sailing/glossary/glossary.aspx
There are quite a few websites with sailing glossaries.
Re: Doc_Dyer's V10
Posted: Sat Jun 18, 2011 7:20 pm
Notice the center line position of the sail when close hauled
Based on that diagram, what point of sail would you say this boat is on?
Wrong answer
Re: Doc_Dyer's V10
Posted: Sat Jun 18, 2011 8:33 pm
by PJPiercey
Cracker Larry wrote:Notice the center line position of the sail when close hauled
Wrong answer
Larry, I'll take a moment here to give a little sailing lesson. Now, if you read carefully, and put your thinking cap on, I think you will have an "AH HA
" moment. When sailing my V12, as my daughter and I are in the above picture, to windward, the end of the boom NEVER is sheeted inside the stern corner of the boat. I'll try to make this very simple for you.....
Single sail "cat" rigged sailboats only have one sail to provide a lifting force forward. Sloop rigged sailboats have a head sail and a main sail. Would you ever trim a headsail to the centerline?
If you think of the loose footed mainsail of a V10 as a headsail I think you will have a much less frustrated experience if you ever find yourself in one.
The diagram referenced above is a simplistic theoretical illustration. A V10 with a loose footed main will not sail close hauled with the sail sheeted into the centerline.
Re: Doc_Dyer's V10
Posted: Sun Jun 19, 2011 12:08 am
by PJPiercey
Hey Larry,
I found a great video for you on YouTube: Notice how NONE of the boats have their booms sheeted to center going to windward. Just like my daughter and I in the above picture
http://www.youtube.com/watch?v=ClWlxjeG ... re=related
If you do get a chance to sail a dingy some day, I hope this helps.
Good luck! And remember to easy off on the main!
Re: Doc_Dyer's V10
Posted: Sun Jun 19, 2011 8:57 am
by cape man
Re: Doc_Dyer's V10
Posted: Sun Jun 19, 2011 1:27 pm
That's funny right there, and very presumptuous.
Still being a jerk, I see.
Uh huh. Just for the record of the spectators, I've taught sailing for over 40 years. I am certified by 3 different national and international organizations as a sailing instructor. In some boat classes I'm certified to certify instructors. I've taught 100s of people to sail, in everything from Optimist prams to 60' IOR racers. I've taught dinghy sailing at the Miami Yacht Club and the Savannah Yacht Club, for the American Red Cross and the Boy Scouts of America. I teach sailing for boys and girls homes. In our beginner children classes I teach basic points of sail. You might be interested PJ?
I'm also a Mistral certified master instructor in sailboards, and have a USCG Masters license in sail, up to 100 tons, and endorsed for all oceans. I served on the 1996 Summer Olympic sailing committee as a judge and race committee official in the Olympic dinghy racing events. They probably wouldn't have let me do that if I didn't know something about sailing dinghys
Any further suggestions I make to Bradley, I'll do it by phone to keep the trolls out of here.
And before you tell me I am wrong again, please share with us your sailing credentials. How many days a year can you even sail an open dinghy in Alaska?
Re: Doc_Dyer's V10
Posted: Sun Jun 19, 2011 3:24 pm
by PJPiercey
Yea, yea Larry,
Then you should know better than to make some of the bonehead statements in your earlier posts.
I don't live in Alaska.
6th renewal on my 100 ton master power and sail. Have my name on the Seattle Iceberg Regatta trophy for first place. Very prestigious race here in the northwest. You know that saying; if you can't do it you might as well teach it
Re: Doc_Dyer's V10
Posted: Sun Jun 19, 2011 3:33 pm
by peter-curacao
If I may say so ,can we please respect the man's thread?
Doc_Dyer wrote:
PJ,
I dont need instructions on how to sail, ..............Bradley
Re: Doc_Dyer's V10
Posted: Sun Jun 19, 2011 7:12 pm
Paul
Still a jerk.
Is that your sailing credentials? I didn't bother to list my trophies, but there are a lot more than 1
Re: Doc_Dyer's V10
Posted: Mon Jun 20, 2011 9:06 pm
by ks8
Re: Doc_Dyer's V10
Posted: Mon Jun 20, 2011 9:26 pm
by peter-curacao
Here you go ks8 a new avatar for you
Re: Doc_Dyer's V10
Posted: Mon Jun 20, 2011 11:27 pm
by ks8
Saved that one Peter. Thanks
And now back to our regularly scheduled Builder's thread....
Bradley... have you got some closeups of the rigging of your snotter?
Re: Doc_Dyer's V10
Posted: Tue Jun 21, 2011 12:03 pm
by Doc_Dyer
no but I can get some tonight
Re: Doc_Dyer's V10
Posted: Tue Jun 21, 2011 1:05 pm
by ks8
Thank you much. I appreciate it.
Re: Doc_Dyer's V10
Posted: Thu Jun 23, 2011 11:01 am
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Thu Jun 23, 2011 1:02 pm
by ks8
Thank you Bradley.
Re: Doc_Dyer's V10
Posted: Thu Jun 23, 2011 1:04 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Thu Jun 23, 2011 1:14 pm
by bratzcpa
Wow. quite a thread here with some of the responses flying back and forth.
Yikes!
I'm just a rookie and don't know anything about anything - - - - so hope no one is offended by my simple questions. A sailing lesson for me would be fine. grin
I am working on a D5 - coming along well. Plan to use it primarily as a tender for my big (to me) boat, and to sail some too (just for fun). Trying to decide on sail design. In your pictures here, Doc, I see that the foot has no boom - - it's just loose, with a sheet at the Clew. Other designs show a boom across the foot. I am interested in your thoughts as to why? and which is better? easier??
Also, my plans show design for both a Sprit and a Marconi rig. any thoughts on preference? Did you have the same options too? But again would welcome your thoughts on why you chose the said design that you did.
thank you,
~markb
Re: Doc_Dyer's V10
Posted: Thu Jun 23, 2011 1:18 pm
by Doc_Dyer
bratzcpa wrote:Wow. quite a thread here with some of the responses flying back and forth.
Yikes!
thank you,
~markb
this is the sail I bought from Bateau, it is the only one listed in my plans
I believe that there are a few to choose from, but this is what Bateau sells
sorry Im not a more experienced sailor to tell you which is better
Bradley
Re: Doc_Dyer's V10
Posted: Thu Jun 23, 2011 1:52 pm
by ks8
I'm not a snotter expert, but it looks fine.
Only other thought I had was whether or not, on this sort of thing, it is popular to sew some leather around the sprit in the contact area with the mast, for chafe reasons. I might knock out a D5 some day (no mods...
) and am gathering ideas for if I use a sprit sail / snotter arrangement. Thanks for posting the pictures.
Re: Doc_Dyer's V10
Posted: Thu Jun 23, 2011 1:55 pm
by Doc_Dyer
well that was a " I saw a pic on the net, now how in the hell do I tie this?"
as I was sitting in Boca 5 min after we unloaded the truck
it held and did its job, not sure it is correct, and up to nautical spec's
but it worked good enough
Re: Doc_Dyer's V10
Posted: Fri Jun 24, 2011 2:34 pm
by sds
Looks good to me, but I'm not an expert either.
Maybe CL and PJ have an opinion?
Re: Doc_Dyer's V10
Posted: Fri Jun 24, 2011 4:13 pm
by gk108
The sail isn't attached in an optimum fashion. Notice the way the sprit pulls the head away from the mast.
At the top of the mast, there should be a hard point (eyebolt) or a short loop of line to connect the head of the sail to the mast at a fixed position. There should be a downhaul at the front bottom corner (tack) to tighten the front edge of the sail (luff). I usually run my downhaul from the tack grommet down through an eye, back up through the grommet, then tied off to get a 3:1 pull. 3:1 pull makes tying that knot easier. I don't find much reason to adjust mine after rigging the boat, sometimes it's tied looser in light wind and tighter in stronger wind.
Re: Doc_Dyer's V10
Posted: Fri Jun 24, 2011 4:48 pm
Not me, I don't know nuthin bout it
Listen to GK, his goes to windward, I've seen him do it
Re: Doc_Dyer's V10
Posted: Sat Jun 25, 2011 2:22 pm
by Doc_Dyer
Re: Doc_Dyer's V10
Posted: Wed Jun 29, 2011 9:08 am
Did the new rudder help?
Re: Doc_Dyer's V10
Posted: Wed Jun 29, 2011 9:27 am
by Doc_Dyer
been trying to catch up on life after my vacation,
just about there, had to redo my deck railing on the house.
8 years for regular wood, stained is pretty good.
this time put pressure treated, It wont stain as well, but should last longer
Bradley
Re: Doc_Dyer's V10
Posted: Wed Jun 29, 2011 9:59 am
by SmokyMountain
Pretty garden. Is the okra ready pick yet?
Re: Doc_Dyer's V10
Posted: Wed Jun 29, 2011 10:23 am
by Doc_Dyer
nope, not yet, but there should be plenty this year
like you have ever picked anything out of my garden,
all you do is say man I would like some okra, or some of those turkey beans
and wolla they magically appear at you house
Re: Doc_Dyer's V10
Posted: Wed Jun 29, 2011 10:36 pm
by SmokyMountain
I think that a great setup!!!
I'll get Alex and EB to come over and pick
Caught a 24-25 incher over at the pond yesterday on a beetle
. The breaks are starting up, in a couple of weeks it might be the best year in the last 5 or so.
Re: Doc_Dyer's V10
Posted: Sat Jul 02, 2011 7:06 am
by majorgator
Funny, here in the mid-90's heat of FL, my okra is DONE. Picked the last bucket full about 2 weeks ago, mowed it down last weekend. It doesn't take long for a garden to come and go here in the FL spring and early summer
seth
Re: Doc_Dyer's V10
Posted: Fri Feb 03, 2012 6:56 am
by ajstokes8
This is all very entertaining gentlemen
