Please let us know once you tested one, I'm very curious to it.Dougster wrote: There's a Hobie rental place nearby so I think I'll give it a try once the weather cools.
Aripeka Angler's PY12 Build
- peter-curacao
Re: Aripeka Angler's PY12 Build
Larry, I am cutting the plywood the old fashioned way. This ply is so thin that my vacuum pods have a hard time sucking it down evenly.Cracker Larry wrote:Good start Did you cut that out with your CNC machine, or do it the old fashion way?
That's a really nice looking little kayak. I might have to build one after I get the FS18 finished.
Are you making hurricane preps yet? Looks like it's going to be very wet there in a couple of days. Let me know if you need any help with the boats or filling sandbags.
As for storm, I believe it may clip the Keys and head for Mississippi. I think we will get a little wind and rain, that's all. Thanks for the offer of help
Doug, Misterfly, Alicia and all, I will try to do a good job posting pics for you all who are planning to build this kayak
Richard
viewtopic.php?f=12&t=62146
Thanks. Would the update be in print or online?jacquesmm wrote:Soon, probably within 3 days, we will post building notes for the SUP14. While experimenting with the assembly, we discovered a few tricks like gluing the sheer clamp ( I may call it inwale on some plans) to the side panel before assembling the hull.
I also though of more options like some stiffeners, deck beam style, for the hatches.
And a side deck brace in case somebody wants to mount accessories on the side of the cockpit or just for better support of the side deck when getting in and out of the boat. I may post a "building notes update" as soon as I draw those options.
Richard
A PDF file online. No changes, just some small options and the suggestion to glue the sheer clamp to the side before planking.
- peter-curacao
Are you also building the SUB Richard? or am I missing or misunderstanding something?Aripeka Angler wrote:Thanks. Would the update be in print or online?jacquesmm wrote:Soon, probably within 3 days, we will post building notes for the SUP14. While experimenting with the assembly, we discovered a few tricks like gluing the sheer clamp ( I may call it inwale on some plans) to the side panel before assembling the hull.
Richard,
Glad your starting a new build!! I'm considering building some version of a sit on top kayak this winter too. Looking forward to seeing yours come together.
Peter, the update is generic for small boats built in a similar fashion. It is construction tips I believe, and not model specific...peter-curacao wrote:Are you also building the SUB Richard? or am I missing or misunderstanding something?Aripeka Angler wrote:Thanks. Would the update be in print or online?jacquesmm wrote:Soon, probably within 3 days, we will post building notes for the SUP14. While experimenting with the assembly, we discovered a few tricks like gluing the sheer clamp ( I may call it inwale on some plans) to the side panel before assembling the hull.
Richard
I got a little more done this afternoon. This is the way I layed out the panels, I used a thin mdf batten to make the curves. I tacked the batten down to the panel with micro-pins at the plotted points...
I cut both panels at the same time setting the saw up to not cut the table. It is easier to cut curves when the saw is set shallow as well...
And cut...
This is everything major cut except the sole, I will start splicing the panels together in the morning...
And cut...
Richard
I miss my shop Oh btw, looking good there Richard. Going to watch this build
Completed: FL14, OD18
I have a Mirage with the turbo fins. Great for hands free fishing and pdq as well. My yak paddling buddies can't keep up with it for long.
I want to build this yak, I have a plastic SINK that is 27" wide and is very stable, this design has to be super stable. Looking forward to some realtime reports on the water.
As light as this one is, put a M-drive on it and it should fly.
frazoo
frazoo
... use a bigger hammer.
Built and Using; V12, Cheap Canoe, Modified Honker 14
Strip Canoe (failed)
V12 and Honker Gone to Boat Heaven= Don't build with cheap ply
