Page 1 of 4
CH14 underway
Posted: Sun Aug 07, 2016 2:33 pm
by MartinV
I've finally started building the CH14. Got the 100% mahogany ply Friday, transferred the dimensions yesterday and cut and joint the panels (on 1 side) today. I'll try and post some pictures later. What I came across:
- I've read about a builders who's glassfibre butt blocks failed and it was mentioned it was because he didn't fill the space between the panels. In order to prevent that (and breakage when turning over to do the other side),I've placed all panels on the floor with approx 5 mm in between, put some weights on them to fix their positions, filled with putty and glassed one side. Results will be in tomorrow
- My order of resin and glass tape hasn't arrived yet, so I had to make due with some leftover epoxy and some home cut strips of glass from a large piece of fabric, even tried the PE foil for a smoother finish
Re: CH14 underway
Posted: Mon Aug 08, 2016 9:27 am
by pee wee
Very nice! That sounds like some premium plywood, are you planning to do a clear finish on part of your boat?
Re: CH14 underway
Posted: Tue Aug 09, 2016 2:25 pm
by MartinV
I do! The inside of the hull. I didn't pre-order Okoume ply and this was the only thing in stock. Now I've got some epoxy on it, it's very nice! The rest of my stuff came in late today, so the only thing I could do on the hull was the glass tape butt block on the other side.
However, I did buy a piece of ash at the local saw mill and nearly finished a yoke with some free plans I got from the internet. Pics to follow
Re: CH14 underway
Posted: Thu Aug 11, 2016 3:19 pm
by MartinV
I've attached all panels and took my time to line everything up. I tried to ommit the tie rips and use duct tape, but the panels created too much tension, so I had to use tie rips. I spotwelded the panels with epoxy glue and hope to remove the tie rips tomorrow and start making fillets on the inside.
I had to use a lashing to hold the centre spreader in place.
Re: CH14 underway
Posted: Thu Aug 11, 2016 3:44 pm
by Jeff
MartinV, Looks really nice!! Jeff
Re: CH14 underway
Posted: Sat Aug 13, 2016 12:40 pm
by MartinV
I've removed all tie rips and am surprised to experience the strength of spot welding. I've also finished the seams on the inside, but it left me wondering about some stuff:
- doing the inside of the bow annex stern is very difficult, as it is very narrow. What would be the best way to approach such tight angles?
- on the other hand, how do you get a nice fillet on very wide angles, like around the middle of the canoe?
Anyway, I'm going to flip it tomorrow, sand the outside and tape it.
Re: CH14 underway
Posted: Sat Aug 13, 2016 2:22 pm
by Cracker Larry
I think I would stand the boat on one end and make a wood flour epoxy mix just loose enough to pour, and pour it in. Let it cure, then flip and repeat. Let gravity do the work.
Re: CH14 underway
Posted: Sat Aug 13, 2016 3:25 pm
by Jeff
Good recommendation CR!! Jeff
Re: CH14 underway
Posted: Sat Aug 13, 2016 4:51 pm
by BrianC
MartinV wrote:...how do you get a nice fillet on very wide angles, like around the middle of the canoe?
As was suggested on another thread, an old CD work great when you need a large radius fillet.
Re: CH14 underway
Posted: Sun Aug 14, 2016 5:30 am
by MartinV
Will an mp3 work as well?
