SK14 in TX
OrangeQuest
Re: SK14 in TX
Post by OrangeQuest »
You are coming along nicely! Very clean tidy work.
KurtActual
Re: SK14 in TX
Post by KurtActual »
Forgive me if I missed it, but do the plans let you decide the deck size, or was that something you modified?
AggieGirl
Re: SK14 in TX
Post by AggieGirl »
KurtActual wrote: Tue Nov 03, 2020 3:06 pm Forgive me if I missed it, but do the plans let you decide the deck size, or was that something you modified?
I modified the deck size. What I had to do was adjust the frame and placement of the stringers. I moved stringer B forward to give a longer deck. The CNC kit gives you extra length on the deck pieces so I was able to customize to the dimensions I wanted.
Not sure if that makes sense so here's a sketch of what I did. Always happy to help someone else out so hopefully this answers your question :)
AggieGirl
Re: SK14 in TX
Post by AggieGirl »
Got the skegs put on tonight. Decided to go with two 1" x 1" x 6' pieces of cedar. We used CA glue to get the boards in place then added a fillet and sealed with epoxy. I didn't put any fiberglass on it, the boards weren't big enough to do any good glassing so just passed on that.
AggieGirl
Re: SK14 in TX
Post by AggieGirl »
Finished fairing the hull and got the graphite on. We did 2 layers of the CL graphite mix and added some milled fiberglass for extra strength. (Lots of oysters in south Texas so I need all the strength I can get!!)
Pictures below.
gstanfield
Re: SK14 in TX
Post by gstanfield »
Good progress, you'll be fishing it by spring.
Then again, you don't have much of a winter down there so you may be fishing it long before what we call spring up here!
G
Current build: FL14 (+10%)
Re: SK14 in TX
Post by Jeff »
Nice work AggieGirl!!! Jeff
cape man
Re: SK14 in TX
Post by cape man »
Without any glass the skegs are pretty vulnerable, especially if you hit oysters. You might consider putting an aluminum shoe on them. I used a 1/8" x 1" strip. Rough up the glued side, etch it with pool acid or alcohol, and glue it down with thickened epoxy. Another CL tip...
KurtActual
Re: SK14 in TX
Thanks for sharing your mods to the plan AG.
VT_Jeff
Re: SK14 in TX
Post by VT_Jeff »
Looking great!
