Page 5 of 6
Re: SK14 in Cape Cod
Posted: Mon Feb 22, 2021 10:44 am
by VT_Jeff
That is very good to know! How fast can you go with just the kicker?
Posted: Mon Feb 22, 2021 3:26 pm
by Fuzzytrout
a couple more questions!
what do most people do here, just glue up a thicker board to clamp to? or just use a spacer after the transom is finished? remove those and through bolt it? there are some holes on the back too that look like they are for a through bolt.
I totally forget i left my transom like an inch or so tall so i could cut it down to the proper height.
the plate above the prop have to be level with the bottom of the boat ?
EH vermont is too cold for me. i would need too much bourbon to keep warm my sanding would be less then ideal
Posted: Mon Feb 22, 2021 4:37 pm
VT_Jeff wrote: ↑Mon Feb 22, 2021 10:42 am
Ditto! Vermont is lovely this time of year. Bring your sander, I'll provide everything else!
It's a bidding war
Come in summer. I have Fesstool sanders and will take you fishing afterwards
A spacer will work but a full width clamping board would be better. I never trust the clamps. I have had the motor work lose so I drill holes and bolt them on. It is not much more work for the security.
Posted: Tue Feb 23, 2021 12:21 am
by BrianC
Fuzzytrout wrote: ↑Mon Feb 22, 2021 3:26 pm
...what do most people do here, just glue up a thicker board to clamp to? or just use a spacer after the transom is finished? remove those and through bolt it? there are some holes on the back too that look like they are for a through bolt.
Here is what I did to both thicken up the transom and to keep the motor positioned properly:
Posted: Tue Feb 23, 2021 6:56 am
by Fuzzytrout
OOOH I like it! I'll probably do something like that for the clamps, and then still use two through bolts in the lower holes from the rear of the engine.
I remember reading a couple builds on here that had cavitation issues.
so should this be level with the bottom of the hull? or just a tiny bit below?
Posted: Tue Feb 23, 2021 7:12 am
by Fuzzytrout
Fuzz wrote: ↑Mon Feb 22, 2021 4:37 pm
It's a bidding war
be careful what you wish for. I'd sand a hull for a shot at a big ole alaskan native rainbow, a steelhead, some salmon, a grayling, a halibut,
just about anything. I need inspiration and photo references for paintings!
Posted: Thu Mar 18, 2021 11:59 am
by Fuzzytrout
Posted: Fri Mar 26, 2021 8:59 am
by Fuzzytrout
Posted: Fri Mar 26, 2021 9:30 am
by Jeff
Very well done!!! Congrats, Jeff
Posted: Fri Mar 26, 2021 10:07 am
by VT_Jeff
That's outstanding, and about ready for the season. Boat looks great, you really did some nice work, very impressed!
