Dane your boat looks fantastic. What is your colorscheme going to be?
What is roll & tip?
FL14 - First Build Started
Ok, guys . . . here's a quick update:
The primer on the hull is now complete and I've flipped her over again and am working on completing the inside. Last night I poured the 2-part bouyancy foam in the appropriate sections. I overfilled the bow section a bit and had to trim some of the foam out so it looks a bit rough, but I added it to the aft sections and will top those off tonight The pictures show the foam just after it was poured. Among the next tasks will be to build and glass the coolers in the midseat area, plumb a chase tube for the fuel line, glass the visable floor sections, and cut and fit the seat tops . . . . all things that will go a lot faster than that darn sanding and painting stuff! LOL
Building the FL14
Thanks Mike,
THe foam was no problem to mix or pour, but judging how much it would expand or how much volume some of the areas held was a bit of a different story.
The batten in the bow end is a support for the small casting platform I'm using instead of a bow seat. This gave me some extra storage underneath and I believe will be plenty stable enough for me to stand on when sight fishing some nearby grass flats.
Dane
Dane
Building the FL14
Users browsing this forum: Ahrefs [Bot] and 7 guests
