Lucked out today, went down to the Home Hardware to check out cooler options, It is still winter here in Revelstoke BC so wasn't expecting alot of choice. There wasn't, out of a choice of one it was the right fit. I had 14 1/2" height to play with, it was exactly that height
As you can see it should work pretty good
Lots of other shots of my hatch configuration in my gallery at
http://gallery.bateau2.comindex.php?cat=11418
Got one question, how have any of you secured your hatches, I'm thinking leave then unfixed and secure with strong magnetic catches. Let me know if I'm missing something here or can it be that simple?
Thanks,
YD
GF 16 cooler solution and hatches
GF 16 built and loving it
You may want to buy 3 or 4 more of those coolers since they fit so well...
I did not secure the hatches on my GF18. The one I mounted my rear seat to will come open when I pull it on the highway if I don't turn the seat around. With the seat turned around, they all stay closed w/o any problems.
So long as they is no way for the air to get into the seat and "push" the hatch open, I think you'll be fine.
Jason
Jason
Hopefully fishing from my GF18
I didn't secure the hatches on mine either. Just a snug fit holds them in place. No hinges, no latches. So far so good. If I'm going to trailer on the highway, I take the hatches off and put them in the seat locker. I don't think they'll blow off, but I don't chance it.
I like to have the hatch covers free, to use the bottom as cutting boards, or to make sandwiches on. Try to keep them separate
- robbiro
more good ideas
YD
I have learned a bunch watching the build that you and Tim have going on along with Larry's running commentary and good ideas. This may be a challenge, but it will be easier because some of you have already been there and are not afraid to post a response to a problem, or to figure out an answer for yourselves and pass it along.
Looking GOOD!!!
Robbie
Looking GOOD!!!
Robbie
32.20.0983N
89.48.0787W
GF-16 FIRST LIGHT finished; D-5 Crusader '08 finished, PY 12 plans in hand
89.48.0787W
YD,
If I could add some advice on haches. I have a GF16 and I went without hinges or handles for about a year. I kept a paint can opener handy to get the hatches open and it worked fine. What I hated, was the fact that if the boat got rained on or washed, I always had to bail and sponge out the compartments. Partly because I did not put weep holes in the compartments either. But, nevertheless, I ended up buying some nice waterproof turn to lock hatches on Ebay for a real low price. I love them and do not know why I went so long without them.
Also, have you thought about where your gas tank and battery will go? I put mine in the mid seat because the boat ran much, much better. I also keep a 10ft cast net in the front which really helps to hold the nose down.
Now I'm afraid I have let the cat out of the bag and Cracker Larry will find out that I can cast a net from the deck of my Gf16 without falling in. (Private Joke).
Boat looks great.
Brian
Gf16
Boat looks great.
Brian
Gf16
Hey guys I just started building a GF16 and was wondering were to put the gas tank. I am leaning towards inside the middle seat for weight distribution. I gues my question is what set up did all others use for their fuel tank and what type of tank/ venting did you use. Thank you in advance.
Justin
Justin
Get It!
Bharbaugh; thanks for the advice, yes I have and I'm planning gas tank in the bow and battery in the middle, also I have a 45# Springer who will take over possesion of the casting deck, nose into the wind all the way
My compartments are designed to allow water in and out easy. I never fish in the rain and washing down should be easy with a quick dry out to avoid any possible rot.
Justin: Doesn't seem to be many people who have done built in gas tanks on this size of boat. I'm just using a portable 6 gal.
YD
YD
Like YD, my gas is going in the bow and the battery in the mid-seat, port side. I don't like batteries farther forward than this as you'll beat them to death with waves.
I'm also only using a 6 gallon portable to start with. If I find I need more capacity I'll throw in a second portable or get a 10-12 gallon to fit that area. I've got a 13-15 gallon that is 1-2 inches too tall to fit under the deck. It was not worth it for me to modify the boat to fit the tank.
Brian,
I put a hand grab handle in my lid and will not be connecting it with a hinge. I did get some very cool clips from a boat builder buddy of mine that will hold it in securely. I'll post some pics once I get them installed.
Tim
Brian,
Tim
