Eric's C21
Re: Eric's C21
No , Jeff you may want to get tracking going. UPS just came in the door with other things but not that.
Re: Eric's C21
Eric, they say they arrived (USPS not UPS) at your most recent ship to address. They will be in a cardboard tube, with plastic end-caps.
Re: Eric's C21
Hey Guys It just came in. Thank Y'all
After a quick look I think the Tessilmare 30mm kit will look just fine. I need to get one measurement to confirm the kit will cover what I want.
Re: Eric's C21
I mixed a 6 ounce batch and got about 1/4 of the bottom surface coated. I'm gonna grab a sandwich and see if I can get the first coat done today.
Re: Eric's C21
Another 6 oz mix finished half of bottom.
Temp. is climbing, I'm at 79 degrees now, going to try one more pour.
Re: Eric's C21
Wow Eric, you're pushing down the accelerator!
Re: Eric's C21
Yea, Also pushing my luck Daniel. Shop temp has reached 84 degrees at end of third 6 oz. batch.
Mixture started to get thick at the end and I had to throw another 1.5 oz mix to reach the same distance as other side.
What that tells me is I need to stop, I almost pushed the last batch too far.
Last batch:
I'll pick up here in the morning.
Last batch:
Re: Eric's C21
Ouch, still very hot down there! Here the last two nights has reached 50 degrees
keep up the good work!
Re: Eric's C21
Went to work this morning, I got the bottom fished with first coat.
Started down the first side also. This is how far a 6 ounce mix went (6 oz. epoxy to 6 oz. fairing mix).
Re: Eric's C21
Eric, looks great and nice clean work!!! Did you receive the rub rail samples? Hope all of you are getting ready for Hurricane Matthew!! Jeff
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
