Thank You Jeff, I'm doing much better. I'll pass your greeting to her.Jeff wrote:Eric, you too and hope you are feeling better!! Happy Birthday to your to your 18 year old!! Jeff
I may try that next time. Thank Youtopwater wrote:If you use biaxe tape it would probably lay down better than regular tape.
Thank You!!Browndog wrote:Eric,
Have had similar problems with the tape in the past. Especially the thicker finished edge. It is helpful sometimes to trim the finished edge off of the tape prior to applying as this often allows the tape to lay down better. Also, occasionally making a slit in the tape will help it to go around curves.
Been admiring ythe progress of your build. Looking good.
