Eric's C21
- glossieblack
Re: Eric's C21
Lovely, keep at it.
Re: Eric's C21
Thanks Mate!
Re: Eric's C21
That's several hundred feet of cleats, isn't it? Very neat work, good thing you took pictures!
Re: Eric's C21
Lord yes it is. Thanks Pee Wee.
I removed the dams this morning. It was a success, the tops are filled nice and level.
In order to strike a line forward of what I've done I had to modify the end of my level.
Small piece of G10 mounted to the underside of my level.
The single screw allows me to match the curvature of the hull well enough to get this done.
If you do this note: You need to drill your hole off center of the extruded aluminum.
The extrusion has a "T" shape in the center for strength.
The application:
The result:
I thought about the next step, after this, over the week end. I think I'm going to cut and fit a temporary floor next.
I haven't decided which way to finish the boat yet. This will allow me to play with ideas. That's all for now.
I hope everyone is having a good Monday.
Re: Eric's C21
Neat and clean like always.
Putting the deck down will change things a bunch and let to see stuff a little different. Good move dropping it in there for planning.
Re: Eric's C21
As always, really well done Eric!!!! Jeff
Re: Eric's C21
Nice work Eric!! You always think outside the box, I like it!
-Reid
-Reid
- Steven Wright
- Steven Wright
Re: Eric's C21
Slick trick! Can't wait to see what you conjure up for the layout.
Re: Eric's C21
Thanks a lot Jeff, Reid and Dan!
Re: Eric's C21
That's an interesting trick. Love it!
