Hey can anyone help with a question about stringers for the C19, I just started and realized the stringers are to big to be made from a single 8ft length of ply. But my plans don't have anything about building them in pieces. What am I missing?
Thanks
C19 build.....
C19 build.....
Re: C19 build.. Stringers!
All our stringers are made in several pieces from 2 layers.
Look at your plans, nesting drawing. The seams between the 2 layers are offset.
Glue then 2 layers together and you have one long stringer.
Re: C19 build.. Stringers!d
I don't have a plan labeled "nesting drawing" is it missing?
The only plan I have referencing stringers is "structure- stringers & transom."
It shows the stringers as two pieces. There is a reference BL 1'-8" and BL10 which I also cannot find.
Thanks!
Thanks!
Ok I'm definitely missing plan D210/7 expanded panels- nesting. Is there an electronic copy I can have emailed?
Re: C19 build..
Ok stringers sorted, next issue is transom angle. The instructions say there's a diagram for the transom supports on jig that give the correct angle, which I'm not seeing. I guess I can fudge it using the angle on the back of the stringers..
Can someone fill me in here please
The angle of the stringers and the side panels will define the transom angle.
Re: C19 build..
Great thanks guys! I'm hoping to raise molds this week, I'm sure you'll be hearing from me. Hopefully I'll get some pics up.
Re: C19 build..
Help required for mold heights! Am I to assume I can use the distance from bottom of molds to baseline in plans as my reference? Example can I pretend the top of my jig is the baseline and line up molds the specified distance from that point?
Re: C19 build..
Another question guys, what hardwood is recommended for transom? Can't I use plywood and resin?
- BB Sig
Re: C19 build..
I don't know about the molds but the transom uses plywood and epoxy glue. The plans will give the thickness of the transom and what thickness to use.
