Is it acceptable to cut the mid seat frames down, space them evenly between the A and stern seat frames, and put a sole down to create a small cockpit in the FS12? Bracing the sides with 3 inch frames of course. Appears to be ok on her "big sisters", the 14 and 17, but I just wanted to be sure. If it is cool to do so, is there a change required to the butt blocks, or can they be replaced with double lamination like the long panels on some of the other designs?
Thanks!!
FS12 sole
Re: FS12 sole
Yes, you can do that: reduce the height of the frames to 3" and put a sole over it.
I see not reason to change the butt blocks.
Your boat will not be self bailing, she is too small.
Re: FS12 sole
i did it on the fs14 and absolutely love the flat floor.... i also moved the rear frame back a foot.. not sure how that works in the fs12 though
Re: FS12 sole
Reduce the height of the stringers to 3"?jacquesmm wrote:Yes, you can do that: reduce the height of the frames to 3" and put a sole over it.
Not being self bailing is fine I reckon, just means I'd need to drain the sole into the bilge and pump it out, ja? The FS14_LS is really my boat of choice but I've determined - after much pondering and mentally rearranging things - that I really only have the build and storage space for 12 feet LOA for the time being. So my plan is to make the FS12 into a really micro flats boat!
Now for how to carry my 11' switch rod on it...
Re: FS12 sole
That boat is really too small to talk about bilges.
Frames and stringers should be minimum 3" high. Foam the "bilges", put a sole on top.
I don't design a sole unless we can put one in there with some benefits. Here, it will not be self bailing, it will raise the center of gravity and make the already low seats even lower.
Re: FS12 sole
How about this: put a sole on top of the stringers between the rear and front frame. Leave the mid frames under the sole. Then, to stiffen the sides, add some vertical frames every 24" made from 1x2's on edge. Build a string rubrail laminated and on the inside, run an sheer clamp over the vertical frames.
I can't design it, I am very busy with something else but that is not too complicated.
Re: FS12 sole
Yeah, that's exactly what I'm thinking: framing on the sides and decks/gunwales to complete the "box". Basically as you designed it, just with the omission of the seat and addition of a sole and gunwales.
So, when you say it's too small to speak of bilges, I'll want water to drain somewhere, correct? If the sole will be below the DWL then I need to pump it out. So I'm thinking I'll leave the compartment between the stringers at the stern open (un-foamed) and call it a bilge....
Sound workable?
Thanks Jacques!!!
Sound workable?
Thanks Jacques!!!
Re: FS12 sole
No boat that small can self bail, sole or not. It's not physically possible. It doesn't have the volume. All small boats just have a drain plug or 2. If you need to drain water underway, you put the boat on a half plane, pull the plug and the water runs out. Easy.
On the trailer leave the plug out. You will just make it heavier with a sole, it won't self bail.
Re: FS12 sole
Ah ha! Copy that. Thanks Cracker L.
Re: FS12 sole
I also need to mention to put the plug back in after the water runs out, but before you stop the boat. That's very importantIf you need to drain water underway, you put the boat on a half plane, pull the plug and the water runs out. Easy.
Users browsing this forum: Bing [Bot] and 16 guests
