OD18 Build
Re: OD18 Build
What Fuzz said...
Re: OD18 Build
Are you sure you don't have the panels mixed up? Can't really tell from here and my plans are stored at home, but I think you may have the top panel on the bottom...
Re: OD18 Build
I do think that's your issue. Look at this pic. The upper panel is thinner at the bow than the lower.
Here's just the lower panel on mine.
Re: OD18 Build
By Golly I do think CapeMan has hit on it. It does look like you have the top panel on the bottom?
Re: OD18 Build
Always loved puzzles Hopefully you have just tacked the panel to the chine
Re: OD18 Build
Okay, I can confidently say that the panels are put on in the correct order. Y'all were freaking me out for second. I haven't had a chance to tack on the port side upper panel. Once I do, I will roll it out of the garage and take a picture. It was hard to take a photo cause the garage was shut and it's super dark on my street. If it wouldn't get dark at 5pm, I could probably get more done on the boat. Thanks for advice, I will keep the pictures coming on this little hiccup, but I think I will be slapping on an extra piece to each panel.
And for the record the chine, lower panel, transom, and the bow(being only the chine and lower panel) are epoxy filleted in. Did any of you guys tab some of the molds to the panels?
Re: OD18 Build
Fuzz, I clamped 2 sheets of plywood when I made my panel cuts.
Re: OD18 Build
Glad the panels are on correct. Cut a filler and move on, no big deal. It is really hard to screw up things to the point they can not be fixed with this building method
If you tab the frames in it will help keep them in place for the flip. You will have a little clean up to do but by that time you will know it is nothing but a thing
Keep posting those pictures.............we love watching a boat come together
Re: OD18 Build
If I remember correctly, I believe I did. Not a lot but enough to keep them in place. Leave a gap and then just cut them loose when your done sand smooth and continue on.Bbolton2 wrote: Did any of you guys tab some of the molds to the panels?
You can see in this picture where I tabbed them:
Completed: FL14, OD18
