OD18 Build
Re: OD18 Build
Yeah, I debated on it, and decided to go for the non spray rail. I am not looking to take it out the inlet, just plan on bumming around the intercoastal and barrier islands. I was also thinking about a side console, but I have not seen anyone build an od18 with the side console.
Re: OD18 Build
About the spray rails..........you will put them on sooner or later
When I built my dory I had planned on it being tiller steering. She ran nose high enough I switched and went remote. Because I had not planned on remote steering I did not have case tubes installed so I went with a side console. It has worked out just fine for me. The dories are so stable it does not matter if there is a little extra weight on one side or the other.
Re: OD18 Build
Hey Fuzz, didn't you install a side console on your dory? If so, do you mind posting a photo? I am contemplating a side console and would love to see an example. It's been a crazy, but I do have a new 24x25 metal building in the backyard to house the boat and workbenches. I am hoping to get some serious work done this year if not complete it. Pictures coming soon.
Re: OD18 Build
My console is not very fancy more just plain Jane but it has worked out for me. I am in the middle of doing some remodelling so it is a mess right now. Having the console on the side leaves a ton of room to walk fore and aft.
Re: OD18 Build
Okay cool, thanks for the photo. Got some work done. Cleats glued to stringers/frames. The bottom of the boat is completely covered in epoxy. Started mixing foam yesterday, only had a gallon of A and B, so it only covered about a third of the boat. Gotta order some more. My plan right now is to install a side console, and route cables wiring under the gunnel and have a portable fuel tank back by the stern to make everything simple and easy to get to.
I have been working on the boat for a long time now. Some guys finish, but I am seeing more and more not finishing. I am motivated to finish this year, with that being said I am not looking to put a ton of extra time into the details of the vessel. I frankly just don't have the time. I have knee surgery tomorrow which throws a wrench into boat building for 6 weeks. Hopefully after that I can really get cranking on it.
Re: OD18 Build
Nice foam work!!! Jeff
Re: OD18 Build
Looks great from here.
I would suggest you think about spray rails again. Even on flat, inside waterways, the water shoots up the sides from about midship to the stern. Just a little side wind and water comes in the back. I used ash and just epoxied them to the sides using temporary bolts to hold it until cured. I ran mine for 8 years without them and survived, but am glad I finally put them on. Would be much easier now than later...
Re: OD18 Build
Very nice. Glad to see some good coming out of this virus thing.
Re: OD18 Build
Thanks. Cape Man, I have been pondering it. I was looking at Larry B's you tube video showing the performance of the spray rails. Was the ash hard to bend? Was it a 1x2?
Users browsing this forum: Yandex [Bot] and 6 guests
