FS14 Keel Skigg Do I need it?
Posted: Sun Oct 29, 2017 1:27 pm
by Capt UB
At that point I can/could install keel/skigg, question is do I need it?
I would rather run more tape down the center line.
Re: FS14 Keel Skigg Do I need it?
Posted: Sun Oct 29, 2017 1:44 pm
by silentneko
If memory serves the keel runner is not for protection, it's for proper tracking and performance. Some guys do 2 smaller ones instead of the larger down the middle.
Posted: Sun Oct 29, 2017 1:53 pm
by Capt UB
The skig is only a 1" x 1" x 96". Not much there! I think on the FS14 it's for protection. ??
Posted: Sun Oct 29, 2017 2:37 pm
by Eric1
I'm willing to bet it needs to be there for tracking.
Posted: Sun Oct 29, 2017 5:06 pm
by Jeff
Capt UB, Eric is correct but we do have several builders who has decided not to add!! Up to you, Jeff
Posted: Sun Oct 29, 2017 5:20 pm
It's for protection and to improve tracking but you will loose a little bit of top speed.
For those who plan to use small engine and/or sail in strong winds, I recommend it.
In all other cases, you can do without it.
Posted: Sun Oct 29, 2017 6:36 pm
by Capt UB
jacquesmm wrote: ↑Sun Oct 29, 2017 5:20 pm
I will be using a 9.8-15 hp on the FS14, just don't plan on doing any sailing....
Thank you, Bob.
Posted: Sun Oct 29, 2017 6:59 pm
To me sailing includes moving around with a boat whatever the power but it must be a literal translation from Dutch or French. Let's say rowing.
Posted: Tue Nov 07, 2017 1:42 pm
by deuce_454
Mine doesn't have a skeg.. and it slides quite a bit when turning... if i were to build another id install a skeg
Posted: Tue Nov 07, 2017 2:17 pm
by Capt UB
deuce_454 wrote: ↑Tue Nov 07, 2017 1:42 pm
Do you have a photo of the transom showing the bottom of the boat and ob cav. plate?
Do you have the cav. plate inline with the bottom of the boat?
I think I read you had a Tohatsu 20, about 95 lbs. Are you running with foil on the ob?
Is it a long shaft?
And were are your build photo's????? No photos!
Bob
Posted: Tue Nov 07, 2017 11:03 pm
by TomW1
Capt I would put it on. It will help you from drifting in turns and will help maintain straight line cruising.
Posted: Wed Nov 08, 2017 8:32 am
by deuce_454
i think photobucket killed 3.rd party hosting if their photos ...
i can email them if you want?
Posted: Wed Nov 08, 2017 9:24 am
by Capt UB
deuce_454 wrote: ↑Wed Nov 08, 2017 8:32 am
No. Just wanted to see your ob setup and transom. I had the same problem with my 15.4 NMZ Gheenoe when turning. I had the ob tilted back to much and was using a foil. I had to install a riser (not a jackplate) to go up 2". Transom was 15", my ob was a short shaft at 17"! There was too much moter under the boat!
I'll see how my setup works out, if not I'll add a skigg/keel. I'm too far into the fairing to add now. Need to get boat wet and get some tight lines!
