Here you go. It was built in Germany.
https://forums.bateau2.com/viewtopic.ph ... te#p286178
He hasn't posted anything for 7 years...
Panga 20 Build
Re: Panga 20 Build
Re: Panga 20 Build
Thanks. That's exactly what I was looking for.
Re: Panga 20 Build
The other important thing about the angle is it is measured to design waterline; not hull bottom.
But Mertens makes it easy and 13 is a good figure with a scosh of tuck against say Yamaha's standard of 12.
Re: Panga 20 Build
How do I prevent these waves when I'm pulling the filling board? Seams like I just keep creating more work.
Re: Panga 20 Build
Gotta change the pull directions each time. You will habe three directions basically or four. 45s and the way you are going and 90s...more or less. And may not be perfectly 45s; let the board find the hull a bit
Re: Panga 20 Build
I also like using guide powder because you can quickly see high spots and avoid dipping into the lows
Re: Panga 20 Build
Can quickfair be thinned a little? Seams like it's getting a little thick after a few minutes.
Re: Panga 20 Build
I do not think you can thin it. I have never heard of anyone doing it. Maybe try smaller batches and get it spread out quicker.FluidDynamic wrote: ↑Sat Apr 13, 2019 1:39 pm Can quickfair be thinned a little? Seams like it's getting a little thick after a few minutes.
Re: Panga 20 Build
You need to wash the surfaces to avoid getting dusts into the compound or it will thicken quickly.
Also, I never do more than 3 oz at a time.
Re: Panga 20 Build
I was mixing 10 ounces. I see now it was too much to spread. I'll mix a smaller batch.
