Is that a chair in front?
I'd put a 10 degree angle on the seat to make it 90-100.
A flat seat is hard to stay in if you get a chopor hit a wake. But you can also have the cushions made fat in front to support the rider.
Panga 20 Build
Re: Panga 20 Build
Nice work on your console!!! Jeff
Re: Panga 20 Build
It is a chair, there is a slight angle towards console, but hard to see in pics.
Re: Panga 20 Build
I mean the base of the chair should be at 10 degrees versus 0. If you have it all done; get a custom cushion made and have them add thicker foam to the chair front. Same result. Otherwise, the chair is a slider..FluidDynamic wrote: ↑Wed Nov 18, 2020 10:27 pm It is a chair, there is a slight angle towards console, but hard to see in pics.
I see the back. That part is good.
On my boat, I am going with the foam option versus the angle.
The foam in the front of this bench is 1" thicker. Just enough to keep you from sliding forward.
Re: Panga 20 Build
The console is a little more time consuming than I originally thought. Still pushing ahead.
Re: Panga 20 Build
Nice console!!! Jeff
Re: Panga 20 Build
Looks awesome. It is a bit of a surprise how long the "other things" take to get how you want them. Build on!
Re: Panga 20 Build
Absolutely. One of the most time consuming things is fairing inside radii.
Re: Panga 20 Build
Small pieces at a time. I feel like this thing is never going to be done. Can't wait until I dont use epoxy products anymore.
Users browsing this forum: Ahrefs [Bot] and 12 guests
