The Silver Tip System 3 Yacht Primer they sell in the store here is a very good one. Goes on under most finish paints.
LM18 SSI GA
Re: LM18 SSI GA
Re: LM18 SSI GA
I’ll put my second in for the Silver Tip Yacht Primer. It really goes on nicely. Haven’t seen you ask yet but I’ll also highly recommend EMC Quantum 99 topcoat. Considered a top side coating but EMC tech said constant immersion in fresh water is fine and so is short stints in salt. Mine’s been on a fresh water lift with weekly use since December and I’m completely satisfied.
Re: LM18 SSI GA
Thanks I’ll look into that paint , silver tip ordered from bbcGuyP wrote: ↑Fri Jun 11, 2021 11:59 pm I’ll put my second in for the Silver Tip Yacht Primer. It really goes on nicely. Haven’t seen you ask yet but I’ll also highly recommend EMC Quantum 99 topcoat. Considered a top side coating but EMC tech said constant immersion in fresh water is fine and so is short stints in salt. Mine’s been on a fresh water lift with weekly use since December and I’m completely satisfied.
Re: LM18 SSI GA
Are there any issues with boring the pilot holes out bigger, backfill with epoxy/wood flour putty, then re-drilling the pilot holes through the cured putty?
Re: LM18 SSI GA
No that is a standard practice. Tom
Re: LM18 SSI GA
Primer finish looks great. I’m a big fan of southern yellow pine too. I used it structurally (laminated ribs, hogg, keel, floorboards) in a 16’ glued lapstrake. It was a plan from a British fella, George Whitsock). In an email I mentioned the mahogany he specified was expensive around here. He replied the properties are similar of SYP but it’s hard to find where he hangs out. We’re covered up with it down here.
Users browsing this forum: Bing [Bot] and 6 guests
