transducer chase tube size?
- BrianC
Several folks here have recommended a separate chase tube for the sonar transducer cable. What I.D. chase tube should I use to be sure that the connector will pass through the tube? I have a Garmin right now and a 3/4" I.D. tube works fine (including the 90° elbow) but I don't know the size of other brands and I want to have options later. Thanks
Re: transducer chase tube size?
I ran a separate 1.5" tube for mine. No way would my lowrance plug fit through 3/4" and the 1" curve looked like it might bind.
- BrianC
Thanks, 1.5" it is then.
Users browsing this forum: Google [Bot] and 18 guests
