Wish i knew this before already removed glass, filled between plies and reglassed. LearningEvan_Gatehouse wrote: ↑Wed Dec 16, 2020 7:36 pm I would just cut/grind the area of 1 side glass at the joint. No need to remove all the glass.
is it just an overshoot or it has negative effect if i use butt blocks inside surfaces of side hulls? My panels are 10% bigger as you know.
