Morning All
Thanks Jaysen, Dan
Jacques / Jeff / Guys
Reefie seems to have removed himself from the data base !
Am I reading this correct ? On the Lines And Camber drawing, Profile it seems to show a station to the right of 0 making 0 - !!!
But there is not a station drawing for this... Am I missing something ?
If you start at 9+ there are 21 stations this includes 0 - and then the radius for the bow....
I luckily printed of Reefie's mold drawings he shows 21 stations...
Any help appreciated as mold materials arriving Monday. Let the fun start !!!
Les
LB26
Re: LB26
Hi Guys
Any feed back from my posting on Sunday ?
Morning All
Thanks Jaysen, Dan
Les
Morning All
Thanks Jaysen, Dan
Les
Re: LB26
He is still in the system. As noted, you should be able to find him using the user search feature in the PM “To” field.
Re: LB26
0- may refer to the bow mould.
Do you have this file?
LB26_M_LS.PDF
LB26_M_LS.PDF
Re: LB26
I did not see that question, sorry. You must be looking at the lines drawing .
See the notes: you have 10 standard stations marked with numbers like 1,2, 3 etc. That is enough to build a good jig for a stiff core material like strip plank or plywood core.
Then, you have intermediate stations marked 1+, 2+ etc. They go in between the standard stations, spaced half. That is for those who want to build a very tightly spaced jig for foam sandwich. Forward of 0, the profile drawing shows an extra small station. You do not need that one on the jig. It would be complicated to plank the foam around that one. Do not use it: your jig stops at station 0.
Users browsing this forum: Bing [Bot] and 8 guests
