TW28 Questions for Jacques
Jeff
Post by Jeff »
This question just arrived via email: "Hi there, I have been looking around for awhile for a boat build project and have come across your TW28 and have to say I do like the lines. Like the box keel a lot and the fact its stitch and glue as well. I live in Victoria Australia, with the thought of on day; taking a trip across the ditch to NZ in my own boat. It's a 1250nm trip and can get rough lol the dirty little Tasman sea. Would this design by ok for this. Or do you have a slightly larger design along the same lines. Look forward to hear from you. Regards Ted" Jeff
jacquesmm
Re: TW28 Questions for Jacques
Post by jacquesmm »
No larger version at this time but some builders have scaled up the TW28. It is easy to do in metric, 10% up is a good and safe way to scale.
As for the behavior at sea, the TW28 will behave like all trawler boats of that size, a little better in my opinion.
For long distance, you could add a stay sail and paravanes.
I would go for paravanes.
Tritonute
New Poster
New Poster
Post by Tritonute »
Hi Jacques
Thank you for your reply
If I am to lengthen the TW28 by 10% to 31ft do I add 10% to the beam as well ??
Plus would I still use 50 hp as a standard engine size, but would be able to add extra tankage for fuel.
Thank you for having this forum as I believe it is a great thing to have.
Ted
jacquesmm
Post by jacquesmm »
You would scale all the dimensions by 10%. That is easy and correct.
You will automatically have larger fuel tanks.
You can also install a larger engine but a 50 HP will move the larger hull without problems.
Those 4 cylinders natural go up to 80 HP in different brands.
Tritonute
New Poster
New Poster
Post by Tritonute »
Hi Jeff,
Thank you for the reply.
One question can you add 10% to the 10%. Just a thought.
As would love a boat of approx 35-36ft.
Ted
fallguy1000
Post by fallguy1000 »
After some point, the scantlings and laminate schedule fall out of design safety factors.
If a designer designs a boat with a safety margin in the hull thickness, bulkhead spacings, and glass schedule, at some point in a length a/o beam increase, the boat falls out of spec.
Adding to a boat's dimension is not arbitrary.
viewtopic.php?f=12&t=62495
jacquesmm
Post by jacquesmm »
Correct. Scaling by 10% is the maximum I recommend.
Peekhomer
New Poster
New Poster
Post by Peekhomer »
Ok, here is my question. I have a saw mill and access to white oak for frames and planking. Is there any reason why I cannot put a solid keel under the TW28, steam frames and Carvel plank the hull?
TomW1
Post by TomW1 »
Peekhomer wrote: Fri Jul 23, 2021 6:03 pm Ok, here is my question. I have a saw mill and access to white oak for frames and planking. Is there any reason why I cannot put a solid keel under the TW28, steam frames and Carvel plank the hull?
You are no longer building a stitch and glue boat and loosing the advantages of doing so. It will weigh many times more than the design weight of TW28. Every thing will be need to be redesigned. Stringer and frame placement, etc.
jacquesmm
Post by jacquesmm »
Correct. This is not a wooden boat. There are no fasteners, the box keel is part of the hull. Even if it was, the keel is a hollow box keel.
