Hb 20 stringers
Hb 20 stringers
Just starting to cut out the stringers for the hb20 from the nesting I make out 4 stringers, I thought that there was only 2 in the middle. and only cleats on the outside panels if someone can put me right that would be great. Thanks John.
Re: Hb 20 stringers
Only a guess, but many stringers are laminated or two glued to make one. Perhaps check the building notes.
Re: Hb 20 stringers
And you have to stagger the joints. I asked about this on the HB16 a few months ago.
Re: Hb 20 stringers
Thanks boys for your help the stringers have to be laminated and glued together with staggered
joints . Cheers John.
Re: Hb 20 stringers
Reward us with a picture or two!
Re: Hb 20 stringers
Hi boys back with a query again by the way fallguy1000 am working out how to post photos . My query being on the hb20 cutting out the stringers have found that the three cuts at bow end of the stringers doesn’t s mirror the side panel cut out. Have checked measurements on plans a number of times seem to be ok, any ideas where I am going wrong. Thanks John.
Re: Hb 20 stringers
Go to and click the attachments tab jist below where you write the words.
click
Add a file
click
Add a file
Re: Hb 20 stringers
John the stingers won't mirror the side panels as they will be shorter. Just cut them per plan and you will be fine.Johnhb20 wrote: ↑Sun Aug 15, 2021 12:46 am Hi boys back with a query again by the way fallguy1000 am working out how to post photos . My query being on the hb20 cutting out the stringers have found that the three cuts at bow end of the stringers doesn’t s mirror the side panel cut out. Have checked measurements on plans a number of times seem to be ok, any ideas where I am going wrong. Thanks John.
Re: Hb 20 stringers
Thanks fallguy1000 will set up some cutouts and take some photos still to cold here to cure epoxy will be right in about 3 weeks.
Thanks for your come back Tom I knew the stringers would be a bit shorter with the meeting up of the transom and bow sheets , but the angles of the stringers don't match the outside panels angles. But will continue as per plan and put it together and enjoy the the project.
Thanks Guys.
Thanks Guys.
