EMC clear coat and real wood
Posted: Mon Jan 19, 2015 10:49 am
This should have been a question but now it's an "experience". I recently decided to refinish the wood exterior doors, that I am not replacing, about 10 years too late. I have spent several days sanding the top 1/16 that has deteriorated to mush after I spent several days bleaching the mold out of them. They look better but not perfect. Still serviceable.
So yesterday I pulled them down for clear coat. I had seen Joel's post about his table and how he used just a few ounces on his table and though great it's got good coverage. So I mixed up twice that for my two doors, they are 75% glass anyway, lots less surface area, and started rolling. I was then reminded if the most amazing thing. Real wood soaks up finish like a sponge. My first two coats went poof and sucked right in. The third coat was looking better so I stopped there. I let it dry over night and got up this morning and hit it with 320 and the final coat. They are looking pretty good but I've used just over half a quart on them. It's turned out to be a very expensive two doors.
I have three more that I need to do. All in the same shape except the front which is covered and has held up better. The front door is all wood, lots of surface area. So the question is should I epoxy coat them first? Instead of sealing with the most expensive finish on the planet do I used a coat or two of expoxy to seal and then clear coat?
Jason
Jason
