Hey Biney,Biney777 wrote: ↑Wed Mar 27, 2019 4:07 pm Hi BigDreams! Welcome to the forum! A lot of good questions. I have been researching the Oars vs. Motor decision. At my primary lake if I don't have a motor my boat does not have to be inspected or licensed. So I am Really trying to make oars work! The beam on my AR15 is 72"-74". Which is just a couple inches narrower than the AD14. Using a couple different formula's one from "The Dinghy Cruising Companion" I get a suggested minimum oar length of 11.4' or 11.6' Shorter ones will of course "work". But I figured I should try and find the "right" size to start with. I have found 1 source for 11' oars with a 27" detachable blade that with shipping are $470. That is a little $$$ for my wallet. Also at that length I will need to put access hatches in my transom so that they can be stored under my seats. The sculling idea somebody already mentioned is probably the best easiest solution for both our boats. Being stubborn tho, I am going to try making a pair of long oars just to see if I can do it. I will post some pics of that process on my build thread. I am going shopping for some clean straight lumber on my way home tonight. Again welcome to the forum, and no matter which design you go with I wish you luck and hope that you keep us updated on your decision and progress!
Yes, please let me know what you find out. I guess I could use a trolling motor, but I'd really like to make do without (or at least have another option).
Thanks!
