Gel coat over epoxy primer
- peter-curacao
Hi Guys I'm ready to finish the bottom on the flyer, I was thinking gel coat but when I was in the shop reading the label it says do not apply over paint, does That mean I can't apply it over epoxy primer either?
Re: Gel coat over epoxy primer
For some reason I thought gel couldn't go over epoxy... or is it polyester can't go over epoxy? I'm to young to be this old.
Most folks say you can not gelcoat over epoxy. But I have read where a few folks claim they have done it and it worked just fine. Having never tried it I KNOW nothing
Gel coat will bond to epoxy. I think the reason people may think it doesn't is that polyester is not as good for mechanical bonding as epoxy is. That doesn't mean it won't bond - just that it won't bond as well as epoxy. For small repairs in gel coat I would have no issue doing a fiber repair with epoxy and then applying polyester gel coat to match the original finish. Over an entire hull though I wouldn't do it. Gel coat is normally slightly porous and over a large area constantly under water you may end up with it delaminating. Probably not immediately, but maybe sooner than you'd like. Plus, gel coat is not easy to apply nicely - even by spraying - and will need flatting and polishing to achieve a nice finish. If it were me, I would go for a few coats of a decent highish build epoxy primer then either just paint with a good marine topcoat, tinted/graphite epoxy, or antifoul/coppercoat depending on how long it is likely to stay in the water for.
- topwater
I wouldn't put gelcoat any where near that boat Ever see a production boat with osmosis blisters on the bottom
Plus it really not that hard of a coating, if you put it on too thick it cracks, if there is any flex it cracks , if you hit somthing
or drop something it chips . Gelcoat sucks , the reason they use it it's cheap and looks pretty for awhile. IMHO.
Novi 23 finally launched !
- peter-curacao
Okay Gentleman thx for the answers this gave me a whole other inside on gel coat therefore I will omit the idea of gel coat.
I was thinking graphite also but I want a matt finish on the bottom so probably I will grab for anti fauling again
Peter do a test with graphite. After it cures wet sand it and feel how slick it is!peter-curacao wrote: ↑Sat Sep 23, 2017 9:33 am Okay Gentleman thx for the answers this gave me a whole other inside on gel coat therefore I will omit the idea of gel coat.
- peter-curacao
Eric Thx but I just finished with the anti faulingEric1 wrote: ↑Sat Sep 23, 2017 3:45 pmPeter do a test with graphite. After it cures wet sand it and feel how slick it is!peter-curacao wrote: ↑Sat Sep 23, 2017 9:33 am Okay Gentleman thx for the answers this gave me a whole other inside on gel coat therefore I will omit the idea of gel coat.
I saw it! You don't play around!peter-curacao wrote: ↑Sat Sep 23, 2017 3:52 pmEric Thx but I just finished with the anti faulingEric1 wrote: ↑Sat Sep 23, 2017 3:45 pmPeter do a test with graphite. After it cures wet sand it and feel how slick it is!peter-curacao wrote: ↑Sat Sep 23, 2017 9:33 am Okay Gentleman thx for the answers this gave me a whole other inside on gel coat therefore I will omit the idea of gel coat.
- Evan_Gatehouse
It is possible to spray gelcoat in a mold and apply epoxy layers over it. But not always successfully! Barry Carroll, US builder of a bunch of production Mumm / Farr 30s, 36, CM1200 tried this with very poor results.
Much easier to just epoxy primer and paint. Gelcoat is really designed to spray into a female mold and have polyester layers added over it. Nobody working with epoxy high performance boats uses gelcoat; they all use paint.
SK17,MM21/MT24
SK17,MM21/MT24
