2 part pourable foam over fresh epoxy
Posted: Sun May 02, 2021 12:28 pm
by jonnymac
I haven’t done anything yet. But how long do ya’ll think I should wait for the epoxy to cure before covering it with the expanding buoyancy foam?
Re: 2 part pourable foam over fresh epoxy
Posted: Sun May 02, 2021 12:34 pm
by jonnymac
I searched the forum for this question no results that made sense. posted the question and the suggested posts had exactly what i was looking for.
Posted: Sun May 02, 2021 5:51 pm
by TomW1
Two days would be fine. The epoxy will continue to cure even with the foam on top of it.
Posted: Sun May 02, 2021 8:46 pm
by OneWayTraffic
TomW1 wrote: ↑Sun May 02, 2021 5:51 pm
How will Amine blush affect the bond of the foam to the panel? I occasionally get visible blush, but not often.
Posted: Sun May 02, 2021 9:09 pm
by fallguy1000
OneWayTraffic wrote: ↑Sun May 02, 2021 8:46 pm
The foam doesn't need to bond to the panel, imo. It isn't structural..
Posted: Sun May 02, 2021 10:37 pm
by OneWayTraffic
fallguy1000 wrote: ↑Sun May 02, 2021 9:09 pm
True, but it would be nice if it stays put. Any extra strength is a bonus. I'm just planning to give mine a quick scrub and sand before foam, but it would be good to know how this all works.
Posted: Sun May 02, 2021 10:44 pm
by jonnymac
thanks everyone for the thoughts.
theoretically as long as the epoxy doesn’t have access to moisture it shouldn’t blush, but i would guess 2 days into cure if it was going to blush it would have by that point.
Posted: Mon May 03, 2021 4:25 pm
by TomW1
jonnymac wrote: ↑Sun May 02, 2021 10:44 pm
Yep your right.
Posted: Wed Jul 28, 2021 10:33 am
by BB Sig
Just to be clear, if jonnymac is working on the FS13, the foam is considered structural. 4mm stringers defiantly need the help!
Posted: Tue Aug 03, 2021 12:51 pm
by jonnymac
BB Sig wrote: ↑Wed Jul 28, 2021 10:33 am
for sure, the stringers and the deck need that for sure, and like all things boat building. the epoxy is now well cured and no sign of the time to pour the foam yet
Posted: Wed Aug 04, 2021 12:51 pm
by VT_Jeff
My .02 on this:
It would seem ideal to pour the foam on the epoxy wet-on-wet for a chemical bond IF the two products are compatible, but I'll assume they are not.
In that case, if you want a structural bond, I'd think you'd want to let it cure to sandable, remove any blush, and then scuff it as you would if you were adding a another coat of epoxy, wet-on-dry. I tend to wait 5 days before sanding/re-coating epoxy, which is a big reason that I try to work wet-on-wet when possible.
