Transom
Posted: Tue Jul 18, 2017 12:03 am
by R-Kid
I am looking for some help with my transom ( 27 Blackfin) . Currently it is a notched transom. I want a full transom so I can put a bracket on it. My transom has a curve in it. Will coosa flex enough? I will attach some pics thx
Re: Transom
Posted: Tue Jul 18, 2017 12:04 am
by R-Kid
My vision
Re: Transom
Posted: Tue Jul 18, 2017 2:14 am
by narfi
Thin pieces flex easily.
You can laminate multiple thin sheets into a composite curved thicker piece that wants to be that shape.
Re: Transom
Posted: Tue Jul 18, 2017 9:27 am
by bateau-webmaster
I would go with 1/4 inch if you go the Coosa route. As Narfi said thin sheets flex more easily. You could also use our
AquaPlas III Transom Board, which is more flexible than Coosa, but still very durable.
Re: Transom
Posted: Tue Jul 18, 2017 10:00 am
by R-Kid
Thanks for the replies. What material would you use? Aquaplas ? How thick should I buy. I need a total thickness of 2 3/4 inches.
Re: Transom
Posted: Tue Jul 18, 2017 1:39 pm
There is more to it than just the thickness: frames and stringers play an important role.
For the transom, build up with several thin layers of whatever material you prefer, epoxy glued.
I would use GelMagic epoxy glue and layers of Aquaplas or marine plywood. The 1/2 Aquaplas will bend, for plywood, use layers of 1/4", max. 3/8.
If you use foam, you MUST use foam with high compression strength.
