So, I use foam cleats quite a bit.
First I cut a 45 on a straight core offcut.
I try for a total of 2" or about 1.25" of flat and 0.75" of angle.
Then cut them to length. I cover the entire cleat with a fairly standard 2.1 to 1 cabosil to epoxy mix and apply.
Then I tape them so they don't move.
Next day, I apply a 4" tape the them and the applied surface.
Pics today of the cleat in profile and applied on two sides of a bench.
I just realized one of the cleats is a bit long.. still wet, will cut shorter.
Overview of cleat needs.
Cleat in profile.
Foam cleats~how to
Re: Foam cleats~how to
If you look close; you'll see I used a lot of glass scraps to laminate the back of the bench. (Green vertical lines)
A job this size creates a LOT of offcuts and throwing them all away would be evil. I generate quite a bit of waste already.
