I actually do have an old radial arm saw and I have a dado set for the table saw that I can fly on the radial arm as well (just gotta stand off to one side in case a tooth goes). I would never cut the tenon on the table saw. That move is against my religion. I don't have a sled either.Aripeka Angler wrote: ↑Thu Apr 09, 2020 10:10 pm That’s nice looking lumber.
Do you have an old school radial arm saw?
The safest way to cut the tenon is on a radial arm saw.
Crank up the blade to the correct height, set a stop and make multiple passes. Flip and repeat, easy.
BTW, If you cut the tenon on the table saw, be friggen careful. It’s dangerous if you don’t have a great grasp of table saws.
Quick demo while I was drinking my morning coffee lol...
And I am well honed on saw safety. I worked in milling at Andersen Windows for about 12 years. I am a master of the cutoff saw; don't ask. I worked as a glorified slave on Weinig's and I forget who made the fancy as hell tenoners. I also worked on a wartime Mattison moulder. I also was an offbearer on a laser operated Portland Rip Saw that had like 4-6 blades that moved based on laser lines set by the operator. That is where I learned to work like a fucker. My body still aches from those days I am quite sure and that is how I wore out the hip as well. I can tell you there were two guys in the plant faster than me. Harold and Oly, both operators. But fast did a number on my joints. Running two four inch boards 16' long at inch and 9 thickness as fast as you can is not for the weak.
