Making a gasket
Making a gasket
So, I had to make gaskets for my in sole hatches. I hope they work. I fretted and stewed and tried 15 directions.
Here is what I came up with...
A dremel tool with a fitting. A 1/4" half round cutterhead. I made a plastic insert for the dremel base and put a screw in for a guide.
Here are pictures.
I still have to glue the gasket in. Thinkin epoxy, but maybe silicone would be better if to change in future.
piperdown
Re: Making a gasket
Post by piperdown »
Very ingenious with the dremel. I take it you don't have a router?
I'd go with silicon. Eventually the gasket will fail and I for one would find it much easier removing silicon than epoxy.
Eric (aka, piperdown)
Re: Making a gasket
Oh, I have routers, but nothing with a 2" base. I think silicone or 3m 4200 is a good plan.
Think I have to paint it a bit first..which is a bit of an issue because I had planned kiwigrip, but I can't paint a rough surface.
swglenn
Re: Making a gasket
Post by swglenn »
I have used 3M Super Adhesive 77 spray for jobs like this. You will have to mask off areas you don't want the spray to get on.
Re: Making a gasket
swglenn wrote: Thu Apr 08, 2021 9:32 am I have used 3M Super Adhesive 77 spray for jobs like this. You will have to mask off areas you don't want the spray to get on.
Oh, that could be a winner, the bead/bulb is real 'floaty'.
I think it would stick on contact to the bulb and then I could put the lid on and some weight.
mattkab
Re: Making a gasket
Post by mattkab »
fallguy1000 wrote: Wed Apr 07, 2021 11:45 pm A dremel tool with a fitting. A 1/4" half round cutterhead. I made a plastic insert for the dremel base and put a screw in for a guide.
ED0CBF6C-1A7E-4402-AA27-4ED691B57A3C.jpeg893EFB7F-EA5E-43AE-B056-8DDB18329F11.jpeg1D4E0585-7ABC-4CEA-9AD1-B276AF78E86E.jpegC87687AD-2FB7-4946-BB40-97961B32EF92.jpeg
I think I'll try this on my GV-13 hatches.
Can you explain a bit more how the screw was used for a guide? I'm not following what edge it was pressing against.
Matt.
Seattle, WA.
GV-13 Build thread & Questions
Previously completed V10 & Launch
Re: Making a gasket
The Wizard base really would not allow me to make a decent guide. So I cut out and press fitted (you could hotglue) a 1/4" piece of plastic inside it.
Then I calculated the desired location of the offset and predrilled a hole.
I took a sample piece and then spotted the screw on the edge of the landing.
Then the screw on the wizard depth gauge, I always keep at a 90 degree. When I get to the end, I spin the wizard.
I have about 1/4" of clearance to the edges of the gutters.
The screw is making a small indent in the gutter landing. I don't care.
I used a small sample piece to draw the line where the edge is and then split the head distance for the predrilling for the screw.
The first cut is a bit of a plunge. Move slowly with pressure on the screw. Make a final go around cleanup pass. This would work with wood. I plan to paint the gutters first.
mattkab
Re: Making a gasket
Post by mattkab »
This is super helpful, thanks!!!!
Matt.
Seattle, WA.
Re: Making a gasket
Post by Jeff »
Well done FG!!! Really nice work!! Jeff
VT_Jeff
Re: Making a gasket
Post by VT_Jeff »
Pretty Slick!
Users browsing this forum: Kenfyoozed and 1 guest
