Custom Camper build from Finished Nidacore Panels
Re: Custom Camper build from Finished Nidacore Panels
Nice design. Press on
Building " Shallow Mine "
http://xf20shallowmine.blogspot.com/201 ... -mine.html
I wanted to be sure everything fit the way I deired.
I loaded the camper myself with no problem. Am satisfied with it. I was surpised how easy it was.
Very nice!! Any idea on current weight now and projected weight when finished!! Again, nice design!! Jeff
I have no idea what the weight will be and am not concerned about it for I want to make it as light as I can and still give me all the features I want. I will weigh it out when completed.
Here is the last panel added to complete the shell structure. Only have to tape some of the seams on the inside and outside.
I had to really scrounge my waste pieces to put this panel together. It has five pieces in it. Itwill not be visible on the outside when the top is added.
I only have two pieces of the 3/4 panels left. One is going to be partially used on the interior and the rest will be added someplace on the interior.
Really coming together well!!! I would have never thought of finished Nida for a camper but it is a perfect fit!!! Happy New Year, Jeff
I did a little calculating on weight. The weight of the Nida Core psnels used is 158 lbs. There was little scrap pieces so with weight of seam tape and epoxy, I will guess the shell as is now must weigh in the neighborhood of 180 lbs.
The panels for the pop top sides came from one sheet of 9 mm Mersnti ply. Another sheet of 9 mm ply will be used on the interior. That is at least another 74 lbs for a total ofabout 260 pounds so far.
The pop top opening in the shell came out not very square making it extremely dufficult to install the pop top sude panels. I decided to make the side panels an independent unit. I made a frame and am installing the panels on the frame that will later be glassed onto the shell.
jusnderer2, your camper is coming along nicely!! Nice Nida work!! Jeff
That is looking really nice.
Even with all the tools and epoxy stuff, I can still lift one end fairly easy.
