Making a gasket
Posted: Wed Apr 07, 2021 11:45 pm
by fallguy1000
So, I had to make gaskets for my in sole hatches. I hope they work. I fretted and stewed and tried 15 directions.
Here is what I came up with...
A dremel tool with a fitting. A 1/4" half round cutterhead. I made a plastic insert for the dremel base and put a screw in for a guide.
Here are pictures.
I still have to glue the gasket in. Thinkin epoxy, but maybe silicone would be better if to change in future.
Re: Making a gasket
Posted: Thu Apr 08, 2021 8:37 am
by piperdown
Very ingenious with the dremel. I take it you don't have a router?
I'd go with silicon. Eventually the gasket will fail and I for one would find it much easier removing silicon than epoxy.
Re: Making a gasket
Posted: Thu Apr 08, 2021 9:21 am
by fallguy1000
Oh, I have routers, but nothing with a 2" base. I think silicone or 3m 4200 is a good plan.
Think I have to paint it a bit first..which is a bit of an issue because I had planned kiwigrip, but I can't paint a rough surface.
Re: Making a gasket
Posted: Thu Apr 08, 2021 9:32 am
by swglenn
I have used 3M Super Adhesive 77 spray for jobs like this. You will have to mask off areas you don't want the spray to get on.
Re: Making a gasket
Posted: Thu Apr 08, 2021 9:48 am
by fallguy1000
swglenn wrote: ↑Thu Apr 08, 2021 9:32 am
Oh, that could be a winner, the bead/bulb is real 'floaty'.
I think it would stick on contact to the bulb and then I could put the lid on and some weight.
Re: Making a gasket
Posted: Thu Apr 08, 2021 12:43 pm
by mattkab
fallguy1000 wrote: ↑Wed Apr 07, 2021 11:45 pm
ED0CBF6C-1A7E-4402-AA27-4ED691B57A3C.jpeg893EFB7F-EA5E-43AE-B056-8DDB18329F11.jpeg1D4E0585-7ABC-4CEA-9AD1-B276AF78E86E.jpegC87687AD-2FB7-4946-BB40-97961B32EF92.jpeg
I think I'll try this on my GV-13 hatches.
Can you explain a bit more how the screw was used for a guide? I'm not following what edge it was pressing against.
Re: Making a gasket
Posted: Thu Apr 08, 2021 2:33 pm
by fallguy1000
The Wizard base really would not allow me to make a decent guide. So I cut out and press fitted (you could hotglue) a 1/4" piece of plastic inside it.
Then I calculated the desired location of the offset and predrilled a hole.
I took a sample piece and then spotted the screw on the edge of the landing.
Then the screw on the wizard depth gauge, I always keep at a 90 degree. When I get to the end, I spin the wizard.
I have about 1/4" of clearance to the edges of the gutters.
The screw is making a small indent in the gutter landing. I don't care.
I used a small sample piece to draw the line where the edge is and then split the head distance for the predrilling for the screw.
The first cut is a bit of a plunge. Move slowly with pressure on the screw. Make a final go around cleanup pass. This would work with wood. I plan to paint the gutters first.
Re: Making a gasket
Posted: Thu Apr 08, 2021 2:42 pm
by mattkab
This is super helpful, thanks!!!!
Re: Making a gasket
Posted: Thu Apr 08, 2021 2:51 pm
by Jeff
Well done FG!!! Really nice work!! Jeff
Re: Making a gasket
Posted: Thu Apr 08, 2021 4:38 pm
by VT_Jeff
Pretty Slick!
Re: Making a gasket
Posted: Thu Apr 08, 2021 5:03 pm
by piperdown
fallguy1000 wrote: ↑Thu Apr 08, 2021 9:21 am
Ah, yeah, the smallest router I have has a 3" base.
Slick setup you came up with.
Re: Making a gasket
Posted: Fri Apr 09, 2021 12:23 am
by Evan_Gatehouse
Rubber cement works well on rubber gaskets.
