I purchased the trial kit. What is the best thing to make/build to get a handle on this process?
Thanks,
Got the Trial kit. What Next...
Regards
Bala
Regards
Bala
Dont drink it
Take two pieces of scrap plywood and make angled joint (say 90 degree to keep it simple). Make a fillet, and glass over it, then fair the joint. Do both sides and you will have made a cross section of one our smaller boats.
Then build a boat
Then build a boat
- Knottybuoyz
I used some of the epoxy & glass in mine to fix the fender on a buddy's 4 Wheeler and some of the epoxy to try a resin infusion. You could use some ply scraps to make a joint and fillet and glass that to see how it works.
Yours Aye! Rick
If you have enough fiberglass I would:
1. Epoxy a piece of glass to a flat surface.
2. Build a small open box or at least a wood joint from 2 scrap boards (stitching the seams would be another good exercise)
a) Spot weld the seams together with epoxy/wood flour. After the spot weld cures, radius an edge and then go back and fill in one seam with epoxy/woodflour
b) laminate some tape over the seam.
c) Build a fillet on an inside seam with wood flour
d) Laminate some fiberglass over the inside joint & fillet. Preferably working "wet on wet"
3. Fair out the taped seams using the epoxy/blended filler.
4. Spray some rattle can primer over your faired surface so you can see how well the fairing job looks.
