Reduce weight of nested dingy
What are the risks if any of building the nested dingy with 4 mm Okume.? Would it work if I fiber glass exterior hull? I´d like to reduce weight. <IMG SRC="images/forum/icons/icon_smile.gif"> <BR><BR>Ira Okun<BR> E mail <a href="mailto:iraokun@earthlink.net" target="_new">iraokun@earthlink.net</a>
Anon,<BR><BR>If you cover 4mm wood with glass and resin, you very quickly lose any weight and cost advantage over bare 6mm wood. Glass sinks, so it´s denser than wood. Properly mixed S3 is the same density as water, so it´s also denser than wood. So you´re going to be replacing 2 mm of lightweight wood with probably the same thickness (at least) of heavier stuff.<BR><BR>Also, I haven´t seen any of the 4mm okoume, but the 6mm stuff I use is 5-ply. My guess is that the 4mm just omits a ply for the reduced thickness (anybody out there confirm this?). If this is the case, then you´d also be losing a layer of unidirectionally grained material and replacing it with material that has the grain running in 2 directions (woven cloth). Since half those fibers won´t be doing you any good structurally, you´d actually end up with a heavier and weaker boat if you used thinner wood and glassed it than if you used thicker wood and left it unglassed.<BR><BR>The bigger boats from bateu.com use bidirectional (not woven) cloth with a carefully designed lamination schedule to take advantage of the fiber orientations. This is a carefully engineered composite structure which is pretty different from just glassing over some thinner wood. That´s why they can get away with using glass cloth for structural purposes.<BR><BR>As far as just thinner wood with no glass, that´s a question for Evan (the fb11 designer) to answer.<BR><BR>Good luck,<BR><BR>Laszlo<BR><BR>
Correction to above - I meant to say biaxial, not bidirectional glass.<BR><BR>Laszlo<BR>
I did not respond because we are currently working on something related to that question.<BR>Last Thursday, I did spend the day with Jeff at WorldPanel and we agreed on selling plywood to our builders at a discounted price.<BR>Later today or tomorrow, you will see plywood links appear at our sites.<BR>What does that have to do with a lighter FB11? A lot. <BR>Because we know the exact specifications and quality of the plywood we will use, we can reduce our safety margin in hull materials.<BR>The FB11 can be built from plain fir or from quality marine ply but if you use our BS1088 Meranti marine, you don´t need it to be 6 mm (1/4"). Thinner plywood will work.<BR>The Meranti 4 mm that I saw at WorldPanel would be perfect for the job. At 4 mm, it will be stronger than cheap fir in 6 mm.<BR>Fiberglass lamination will stay the same.<BR>Now, this applies to that specific plywood. It is not valid for any 4 mm plywood.<BR>Ours is not only BS1088 but also rated at the top by Lloyds.
Jacques,<BR><BR>That is great! I always thought that you partnering with a place like world panel would be an ideal fit if the details worked out. I think you and Jeff will both gain from it. One of the "foggiest" issues for new builders is sources for good plywood. <BR><BR>Jim<BR>
Jim Wright
CC, D15, SC16, C19
CC, D15, SC16, C19
Glad to see that builders approve.<BR>I know Jeff and WorldPanel since years: they shipped plywood for us to remote places like Panama. The quality of their products is very high and Jeff understands our requirements. His office manager knows boats: Leif will build an OB19 soon. That means that those guys understand exactly what our builders need.<BR>An agreement between our companies was bound to happen, we were simply procrastinating.<BR>Another good side of this deal is that Jeff and Leif will monitor the plywood message board several times a day. They will respond to questions and I will ask them to review our plywood FAQ.<BR>I should be ready with the first web pages about plywood before the end of the week.
- fishingdan
For what it is worth, I think this is a great idea. In some areas of the country it is not easy to find the required plywood. As you know, it is very expensive to have the wood shipped (particularly a small order shipped to a home = an extra charge in many cases). At least we will be able to purchase from a trusted source that is familiar with our activities. Any group discounts that could also be passed on would be a big plus!<BR><BR>
Dan
Yes, discounts will apply and shipping costs will be a very good surprise.<BR>I have read on this board about some of builders paying more to ship 80 miles than what we will charge to ship across the country! <IMG SRC="images/forum/icons/icon_wink.gif">
Hi,<BR><BR>I would be a bit reluctant to approve the use of 4mm ply for the nesting dinghy if you were planning to use it with the sailing rig. It might be a bit too twisty when hard on the wind and really heeled over. Thicker plywood provides more stiffness.<BR><BR>Glassing 4mm will bring it up to the weight of 6mm ply very fast and won´t save you weight.<BR><BR>Otherwise it would be o.k. BUT only with a very high quality plywood as Jacques has described in his posting. Lesser quality ply just won´t have the strength required. <BR><BR>However, after using the boat for several years as a yacht tender, I can tell you that the total weight isn´t that much. Two people can easily carry it up a beach with a smile on their faces without straining, and if it´s just you alone, it´s light enough to drag up the same beach. <BR><BR>If you regularly abuse your boat like I do (dragging it up rocky beaches etc) then you would agree that the 6mm gives you that extra resistance to punctures.<BR><BR>Evan Gatehouse (the FB11 designer)
The designer should have the last word not only because he is the designer but also because he used the boat and knows its limits.<BR>No 4mm if you build the sailing version.
