CS25 Flair
CS25 Flair
I'm very interested in building the CS25. Is there a view of the bow other than the study plans that shows the amount of flair.
Now, that's the best way to show it.
The flare is as much as we could produce from sheet plywood without getting into cold molding.
It requires 2 or 3 slits to take that shape, the plans show where to cut the slits and how far.
Thanks for the response. I have several more questions, 1-Are there any major concerns in regard to stability if I were to add a small tower to the boat. 2-are there any estimates on speed based on the maximum recommended HP. 3-I would like to put recessed tabs on the boat, are there any foreseable problems doing this without having to modify the hull. 4-Will there be a design of this boat with a jackshaft configuration. 5-The beam is listed as 8'6, I assume that is at the bow. What is the beam at the stern. 6-Does the kit include all wood needed to build the boat including the sole and center console
