I am about to pull the trigger on the sk14, but want to make sure i will be able to transport it in my truck bed with a bed extension rail.
My main concern is it being able to fit between the wheel wells. I have a 2005 2nd generation Tacoma pre runner, has anyone fit the sk14 in
a tacoma? Thanks
Truck Bed?
Re: Truck Bed?
No I have not. My SK14 is 49" at it's widest, so you can check. That width is at the top of the sheer of course, which is a foot or so above the keel. Mine has an outboard on the stern and trolling motor with battery on the nose, so would be way too much for me to handle in my truck bed. I use an inexpensive Academy trailer for transport, works well. I do use a bed extender for my canoe and think w/o the motors I could man handle the boat on that way. At 71 years old I could do it mind you, except that my back is, as luck would have it, 71 years old too
BTW I love the little boat. It ran 11 mph with the 5 horse motor and my wife on board with me last week. Easy to launch and load, quick to wash and put away.
Re: Truck Bed?
Florida36, I think it will fit. Take Dougster's measurements and see how wide your bed is between the wheel wells. Jeff
Re: Truck Bed?
fyi, if you find she is too wide; I have in the past made a simple stand up bed with 2x4s to get above the wells. This is dang handy to stow stuff under done right.
Re: Truck Bed?
Thanks for all the feedback, I'm really looking forward to this build!
So i measured the width between my wheel wells and its 45", the wheel wells start 18'' back from the front of the
bed and go back to 42'' from the front of the bed. I would greatly appreciate it if some one could measure the width at 18'' and 42'' from the bow and the stern. This would help me determine if i can fit it, and if it needs to be bow or stern forward in the bed.
Ive found that the my local lumber yard carries marine plywood, so i will be able to get that stuff there.
Re: Truck Bed?
I do not recommend building the boat with Roseburg plywood. I am using it for interior and a few tops at 3/4", but personally would not use for a hull.Florida36 wrote: ↑Sat Oct 17, 2020 9:29 am Thanks for all the feedback, I'm really looking forward to this build!
Re: Truck Bed?
I think it will fit bow on but not stern first.
Width at 18" from bow: 20 1/2"
Width at 42" from bow: 37 1/2" (approx--battery in the way, hard to measure well)
Width at 48" from bow: 38"
Seems like the nose will fit easily between the wheel wells.
Re: Truck Bed?
Awesome thanks for the measurements! That gives me the green light.
The place i found has ocoume, so i think that's what i will be using. Is that a good choice for the hull? Will a long shaft 4hp mercury work on it, or would I be better off selling it and getting a short shaft?
Re: Truck Bed?
Okoume is great. That's what I used. Long shaft can work I think by simply cutting the transom taller. Oet's hear about that from others.
Re: Truck Bed?
If you already have the outboard you will be able to build the transom so it is a perfect fit.
Users browsing this forum: Bing [Bot] and 8 guests
