I have a friend who used to work for Martin-Baker - they make ejection seats for fighter planes. We were having this very same conversation and he said the reason they still aluminium is because they are working with a known quantity and it is much more repeatable than composites. I thought that was interesting.Evan_Gatehouse wrote: ↑Mon Nov 02, 2020 4:31 pm It's actually technically challenging to make foam cores with REPEATABLE material properties. Even the best cores vary by +/- quite a few %. That sort of expertise does not come cheap. If you struggle to pay for the materials, maybe it's just not going to happen....
Lakesurfer - you may enjoy reading parts of the Gougeon Manuel on epoxy. Maybe it will give you some ideas. Maybe it will also help you to understand how epoxy resin really revolutionised wooden boat building and was the missing link that took a superb boat building material that wasn’t superb because it could rot, to one that really now has pretty much everything going for it!
Read the appendix C for starters. Maybe like many of us on this forum who started out sceptical of wood because we had been brainwashed, you will change your mind and come to realise what the rest of us - and many, many great boat builders did as well - that wood is a pretty darn good material and a whole lot simpler than all your alternative suggestions...
https://www.westsystem.com/wp-content/u ... 1205-1.pdf
This from appendix C...
I have a 20 year old plywood and epoxy OD 18 - Built from plans on this site - and it had water under the sole for 5 years - and it doesn’t have an ounce of rot because everything was epoxy coated. I live next to a boat yard that has plenty of fiberglass boats in various states of disrepair that have soggy osmosis riddled hulls.
Ultimately if you own a boat - whatever it is made of - you have to look after it in a manner appropriate to what it is made of...
