Hello,
Recently purchased the FS14LS plans, however, I intend to build them using the foam sandwich construction method. I also have the foam sandwich plans for the PH15.
I contacted Boat Builder Central to obtain foam plans for the FS14LS and Jeff rapidly responded that Jacques is working part time for the moment.
Im wondering if I can use the same lamination/material selection as the PH15 foam version and adapt it to the FS14LS?
PH15 calls for 1/2 in H80 foam for hull, deck, sole and stringers and h130 for the transom.
Would the same foam materials from the PH15 work for the FS14LS?
Ive posted this another thread as id like to order materials ASAP.
thank you
-Mark
PH15 foam Plans adapted to the FS14LS?
Re: PH15 foam Plans adapted to the FS14LS?
Please, do not cross post.
I did email the foam specs for the FS14LS. Do not use the PH15 foam specs.
What I did send are lamination specs with a brief note. I assume that you understand the basics of foam sandwich.
See our foam sandwich tutorial in the HowTo section, in particular, the notes about inserts and hardwar4e installation.
