I understand the principles behing both types of hulls.
My question is.... for YOU personally..... what is the draw for a displacement hull over a planing hull. I have never had one.
Planing vs displacement
Re: Planing vs displacement
Going slow, steady, far, and cheap. And going big.
And, there is middle ground.
Get caught one time 100 miles offshore and have 25 foot lumps blow up. You will become a fan of full displacement hulls in a hurry
The one thing I really like with displacement hulls is that I usually find running them to be extremely relaxed. Unless conditions are absolutely terrible, even moderately rough seas off the west coast feel pretty manageable. If you have any shelter at all, then getting where you want to go just takes patience.
I used to do rough crossings of a little channel about fifteen miles across and something like a hundred miles long, basically in line with the prevailing winds, every two or three weeks. I did that for five years. I often thought that if I just had a double ender salmon troller, I'd be doing it without stress, instead of gritting my teeth and launching off every wave at twenty knots until I couldn't stop visualizing the bulkheads separating from the hull and slowed to a crawl for a while.
That said, time is money, and whenever I think I might just want a converted troller, I do the math on fuel to a given location and remember that often you can get a diesel sportfish there at 20 knots for nearly the same money, in a third the time.
Ugh. I honestly can't imagine. Even 25' in a boat like Skoota would be terrifying if they are random or rogue and I'd be sick.
A displacement hull will use less gas and get you where you want to go sooner or later. A planning hull will get you there faster but use more gas. As far as ride in rough water a displacement hull is superior, a planning hull will need to slow down in the same conditions.
Great answers and thank you all.
Next question.
Specifically the HMD.....
In wind, waves and current..... does a hmd still move in the direction you want it to?
Next question... if i already have a 15"shaft motor, could you put it on a jack plate to get it low enough?
Next question.
Jackplate I don't know. Wind, waves and current...depends on the wind, the waves and the current.
There's spots around here with a ten knot current. Even without wind or waves, you're waiting for a tide change. A good friend has a fifty foot Monk cruiser; he can run it all day for a hundred bucks in diesel but he has to plan around the tides.
iCatfishtoon wrote: ↑Sun Jun 13, 2021 8:16 pm Great answers and thank you all.
Next question.
Specifically the HMD..... is
A displacement boat is limited by the conditions it is in. It is usually limited to a max speed of 6-8mph so if wind and currents are both against it can barely have forward way on. But generally in answer to your question is yes, you will have control in most conditions. There are some areas of the US where you would have to wait for the incoming or outgoing tide to make the passage but in general a displacement boat can go any where.
A jack plate only moves in one position and that is up and then down. So my best advice would probably be sell the 15" and buy a new 20" shaft. You could cut down the transom for the 15" but is it set up for remote steering.
Well good luck to you. The HMD is a good boat.
Users browsing this forum: Ahrefs [Bot] and 9 guests
