Well, Im officially 1 week into this project!! So far so good. no problems yet for this first timer.
I did decide to eliminate the curve from the bow transom, as well as change the front deck a little. Its about 4 inches longer so it sits a little higher at the bow. Ill be mounting a pedistal chair on the deck, as well as a bow mounted trolling motor.
I posted pics in my gallery.
http://gallery.bateau2.com/thumbnails.php?album=624
Im open for advise or comments or any tips that may be helpful during the build of this boat.
--- Brad
04ness' GF14
04ness' GF14
GF14 in progress!
bmc229@aol.com
bmc229@aol.com
- robbiro
Brad, She looks like a boat Good progress for the first week. Keep up the posts. Ask anything you don't know. Do this before you cut, I am going to have to cut the curve out of my bow and I am almost through with the top side before glassing the bottom, It should be fum..
Keep on Buildin'
Robbie
Keep on Buildin'
Robbie
32.20.0983N
89.48.0787W
GF-16 FIRST LIGHT finished; D-5 Crusader '08 finished, PY 12 plans in hand
89.48.0787W
Has been 1month already! I had a 10 day period that I couldn't build. My wife just graduated lawschool.
so far all has gone well. although Im going to come up short on epoxy. Ill have to order more. I guess its just beginners waste? I had about 3 small batches go to waste, but I thought I was being frugal with it
The outside glass i squeeged' pretty well, but I think I got alittle thick on the inside glass (some puddling in the corners)
I still have alot of bare wood to saturate. I did one extra frame to make a step up to the front deck,( so that took extra and wound up with larger than normal fillets to tab to hull)
After all is done, I will have used 4 1/2 to 5 Gal total
-- Brad
http://forums.bateau2.comthumbnails.php?album=624
-- Brad
GF14 in progress!
bmc229@aol.com
bmc229@aol.com
bottom runners are glued, as well as spray rails. for the spray rails I epoxied the blank pine stock to the hull, It will be easier to shape and taper with a plane and sander when its in place.
I got my first taste of the quick-fair today.was having trouble at first using plastic "bondo type" spreaders, but I switched to the metal 10" drywall knife and it was a completely different job!! had I used the drywall knife first, it probably would have taken only one application.
will get the bottom ready for paint, then flip and complete the inside, decks seats etc..
-- Brad
-- Brad
GF14 in progress!
bmc229@aol.com
bmc229@aol.com
Well, its been almost a year since my last post. BOAT IS READY TO SPLASH!! I modified a utility trailer to haul the boat because some places I go have no ramp. The boat sits on a bunk with rollers almost like a boat trailer. The bunk sits on the utility trailer. we fabricated rollers and a mount for an atv winch to pull the boat and bunk up onto the trailer.
My next pics should show the boat wet.
Its been a long build. I learned alot, there are many things I would do different. But now I can say I BUILT A BOAT!!
--- Brad
--- Brad
GF14 in progress!
bmc229@aol.com
bmc229@aol.com
- tech_support
pics are in my gallery. hopefully it will be floating in the next pics I post!
--Brad
--Brad
GF14 in progress!
bmc229@aol.com
bmc229@aol.com
- chicagoross
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Yandex [Bot] and 19 guests
