It's not just the bottom that you have to worry about. Since I have been making test runs on a local lake, I have gotten a lot of dings and scrapes on the sides of my GV11. The launch ramp has a dock with galvanized steel framing and no padding of any kind. Even using fenders, the boat bumps the dock here and there as waves from water skiers hit it.
A quick pass with some 320 sandpaper, a few swipes with an artists paint brush and it looks as good as it did before (at least from a distance). I figure this effort will diminish as time goes by and the boat will just have to accumulate dings until I feel like fixing them.
I believe if you are going to use the boat as nature intended, you just have to consider the finish as work in progress.
Jerry
Care of paint job
I'm going to build a GF18 and I don't want to paint it, but I think that if I ever intend to sell the boat, it had better have a nice paint job. It'll be hard enough selling a home-built boat, but one that's just varnished will be even harder. Of course, maybe I should wait to paint it when I hope to sell it, and live with a varnish exterior until then.
See any problem tryint to paint a boat that's been varnished? Would I have to strip the varnish off?
Jason
Jason
Just got back from fishing with a buddy in my Canoe. I painted it with water based Latex paint. I found a primer at Lowes for priming slick surfaces for paint such as tile and fiberglass. I used this and then rolled and brushed on the Latex. I Used a low gloss paint to dimish the imperfect fairing job I did on the inside. I USE the canoe and when I get to shore I don't want to be bothered with worriying about scratching a $23.00/qt paint. My landings consist of rowing as hard as I can so I glide as far up on shore as I can. No need to get my feet wet that way. I drag it out and don't worry abot the scratches. It has a layer of 6oz. glass on the bottom, and I haven't come close to scratching into it. I figure I'll just sand off a layer of paint at the end of each season, and put on a coat of $6.00 paint. I have bought the plans for th GF16. The one thing I will do differently is put a layer of 6oz. glass tape over the rub rail. This takes most of the beating and without glass it dents rather easily. Havent' decided on what paint I'll use yet.
